root/radiance/ray/src/rt/aed.c
Revision: 1.2
Committed: Mon Oct 2 17:12:34 1989 UTC (35 years, 9 months ago) by greg
Changes since 1.1: +18 -89 lines
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * aed.c - driver for AED 512 terminal.
9 *
10 * 2/2/87
11 */
12
13 #include <stdio.h>
14
15 #include "driver.h"
16
17 #include "color.h"
18
19
20 /* AED command characters */
21
22 #define AEDFMT "1888N" /* Format string to send to AED */
23 #define CSTAT 0100 /* Console status: lower case */
24 #define SCT 75 /* Set color lookup table */
25 #define SEC 67 /* Set color for vector drawing */
26 #define MOV 81 /* Set CAP (current access pointer) to x, y */
27 #define OPT 40 /* Miscellaneous terminal control */
28 #define SEN 71 /* Set encoding types */
29 #define RST 48 /* Reset terminal */
30 #define FFD 12 /* Clear screen */
31 #define EJC 85 /* Enable Joystick cursor positioning */
32 #define DJC 100 /* Disable Joystick cursor positioning */
33 #define SCC 99 /* Set Cursor Colors */
34 #define SCP 93 /* Set Cursor Parameters */
35 #define DFR 111 /* Draw Filled Rectangle */
36 #define RCP 106 /* Read Cursor Position */
37 #define ESC 27 /* Escape starts a command sequence */
38 #define SCS 96 /* Set Console Status */
39 #define END 1 /* Ctrl-A used to terminate command mode */
40
41 #define BLK 0 /* color table entry for black */
42 #define WHT 7 /* color table entry for white */
43
44 #define command(c) (putc(ESC, stdout), putc(c, stdout))
45 #define byte(b) putc(b, stdout)
46 #define string(s) fputs(s, stdout)
47 #define flush() fflush(stdout)
48
49 #define GAMMA 2.2 /* exponent for color correction */
50
51 #define NCOLORS 244 /* our color table size */
52 #define MINPIX 8 /* minimum hardware color */
53
54 #define NCOLS 512 /* maximum # columns for output */
55 #define NROWS 512-COMHT /* maximum # rows for output */
56 #define COMHT 16 /* height of command line */
57 #define COMCW 63 /* maximum chars on command line */
58
59 static COLR colrmap[256]; /* our color map */
60
61 static COLR colrtbl[NCOLORS]; /* our color table */
62
63 static int colres = 64; /* color resolution */
64
65 int aed_close(), aed_clear(), aed_paintr(),
66 aed_getcur(), aed_comout(), aed_errout();
67
68 static struct driver aed_driver = {
69 aed_close, aed_clear, aed_paintr, aed_getcur,
70 aed_comout, NULL,
71 NCOLS, NROWS
72 };
73
74
75 struct driver *
76 aed_init(name) /* open AED */
77 char *name;
78 {
79 if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
80 stderr_v("cannot access terminal\n");
81 return(NULL);
82 }
83 command(RST); /* reset AED */
84 longwait(2);
85 command(OPT);
86 byte(6); byte(1); /* AED command set */
87 command(SEN);
88 string(AEDFMT);
89 command(SCS); /* set console status */
90 byte(CSTAT);
91 command(SCC); /* set cursor type */
92 byte(BLK); byte(WHT); byte(15);
93 command(SCP);
94 byte('+'); byte(0); byte(1);
95 make_cmap(GAMMA); /* make color map */
96 errvec = aed_errout; /* set error vector */
97 cmdvec = aed_errout;
98 if (wrnvec != NULL)
99 wrnvec = aed_errout;
100 return(&aed_driver);
101 }
102
103
104 static
105 aed_close() /* close AED */
106 {
107 errvec = stderr_v; /* reset error vector */
108 cmdvec = NULL;
109 if (wrnvec != NULL)
110 wrnvec = stderr_v;
111 aedsetcap(0, 0); /* go to bottom */
112 command(SEC);
113 byte(WHT); /* white text */
114 byte(END);
115 byte('\n'); /* scroll */
116 flush();
117 ttydone();
118 }
119
120
121 static
122 aed_clear(x, y) /* clear AED */
123 int x, y;
124 {
125 command(FFD);
126 maketab(); /* init color table */
127 longwait(1);
128 }
129
130
131 static
132 aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
133 COLOR col;
134 int xmin, ymin, xmax, ymax;
135 {
136 command(SEC); /* draw rectangle */
137 byte(get_pixel(col)+MINPIX);
138 aedsetcap(xmin, ymin+COMHT);
139 command(DFR);
140 aedcoord(xmax-1, ymax+(-1+COMHT));
141 flush();
142 }
143
144
145 static int
146 aed_getcur(xp, yp) /* get cursor position */
147 int *xp, *yp;
148 {
149 int com;
150
151 command(EJC); /* enable cursor */
152 com = getch(); /* get key */
153 command(DJC); /* disable cursor */
154 aedgetcap(xp, yp); /* get cursor position */
155 *yp -= COMHT; /* convert coordinates */
156 return(com); /* return key hit */
157 }
158
159
160 static
161 aed_comout(out) /* output to command line */
162 register char *out;
163 {
164 static int newl = 1;
165 static int inmsg = 0;
166
167 while (*out) {
168 if (newl) { /* new line */
169 command(SEC);
170 byte(BLK);
171 aedsetcap(0, 0);
172 command(DFR);
173 aedcoord(NCOLS-1, COMHT-1);
174 aedsetcap(1, 4);
175 command(SEC); /* white text */
176 byte(WHT);
177 byte(END);
178 newl = 0;
179 }
180 switch (*out) {
181 case '\n': /* end of line */
182 newl = 1;
183 /* fall through */
184 case '\r':
185 inmsg = 0;
186 byte('\r');
187 break;
188 case '\b': /* back space */
189 if (inmsg > 0 && --inmsg < COMCW)
190 byte('\b');
191 break;
192 default: /* character */
193 if (inmsg++ < COMCW)
194 byte(*out);
195 break;
196 }
197 out++;
198 }
199 flush();
200 }
201
202
203 static
204 aed_errout(msg) /* print an error message */
205 char *msg;
206 {
207 aed_comout(msg);
208 if (*msg && msg[strlen(msg)-1] == '\n')
209 longwait(2);
210 }
211
212
213 /*
214 * aedsetcap - sets AED's current access pointer to (x, y).
215 */
216
217 static
218 aedsetcap(x, y)
219 register int x, y;
220 {
221 command(MOV);
222 aedcoord(x, y);
223 }
224
225 /*
226 * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
227 */
228
229 static
230 aedcoord(x, y)
231 register int x, y;
232 {
233 byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
234 byte(x & 0xff);
235 byte(y & 0xff);
236 }
237
238
239 static
240 aedgetcap(xp, yp) /* get cursor postion */
241 int *xp, *yp;
242 {
243 register int c;
244 /* get cursor postition */
245 command(RCP);
246 flush();
247 c = getch();
248 *xp = (c & 0x30) << 4;
249 *yp = (c & 0x3) << 8;
250 *xp |= getch();
251 *yp |= getch();
252 }
253
254
255 static
256 maketab() /* reinitialize the color table */
257 {
258 extern COLR *get_ctab();
259 register COLR *ctab;
260 register int i;
261
262 ctab = get_ctab(NCOLORS); /* get colors */
263 command(SCT); /* set color table */
264 byte(MINPIX); /* starting index */
265 byte(NCOLORS&255); /* number of colors (0==256) */
266 for (i = 0; i < NCOLORS; i++) {
267 byte(ctab[i][RED]);
268 byte(ctab[i][GRN]);
269 byte(ctab[i][BLU]);
270 }
271 }
272
273
274 static
275 longwait(t) /* longer wait */
276 int t;
277 {
278 flush();
279 sleep(t);
280 }
