root/radiance/ray/src/rt/aed.c
Revision: 2.3
Committed: Sat Feb 22 02:07:28 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.2: +57 -5 lines
5 * aed.c - driver for AED 512 terminal.
6 */
7
8 /* ====================================================================
9 * The Radiance Software License, Version 1.0
10 *
11 * Copyright (c) 1990 - 2002 The Regents of the University of California,
12 * through Lawrence Berkeley National Laboratory. All rights reserved.
13 *
14 * Redistribution and use in source and binary forms, with or without
15 * modification, are permitted provided that the following conditions
16 * are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 *
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in
23 * the documentation and/or other materials provided with the
24 * distribution.
25 *
26 * 3. The end-user documentation included with the redistribution,
27 * if any, must include the following acknowledgment:
28 * "This product includes Radiance software
29 * (http://radsite.lbl.gov/)
30 * developed by the Lawrence Berkeley National Laboratory
31 * (http://www.lbl.gov/)."
32 * Alternately, this acknowledgment may appear in the software itself,
33 * if and wherever such third-party acknowledgments normally appear.
34 *
35 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
36 * and "The Regents of the University of California" must
37 * not be used to endorse or promote products derived from this
38 * software without prior written permission. For written
39 * permission, please contact [email protected].
40 *
41 * 5. Products derived from this software may not be called "Radiance",
42 * nor may "Radiance" appear in their name, without prior written
43 * permission of Lawrence Berkeley National Laboratory.
44 *
45 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
46 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
47 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
48 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
49 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
50 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
51 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
52 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
53 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
54 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
55 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
56 * SUCH DAMAGE.
57 * ====================================================================
58 *
59 * This software consists of voluntary contributions made by many
60 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
61 * information on Lawrence Berkeley National Laboratory, please see
62 * <http://www.lbl.gov/>.
63 */
64
65 #include <stdio.h>
66
67 #include "driver.h"
68
69 #include "color.h"
70
71
72 /* AED command characters */
73
74 #define AEDFMT "1888N" /* Format string to send to AED */
75 #define CSTAT 0100 /* Console status: lower case */
76 #define SCT 75 /* Set color lookup table */
77 #define SEC 67 /* Set color for vector drawing */
78 #define MOV 81 /* Set CAP (current access pointer) to x, y */
79 #define OPT 40 /* Miscellaneous terminal control */
80 #define SEN 71 /* Set encoding types */
81 #define RST 48 /* Reset terminal */
82 #define FFD 12 /* Clear screen */
83 #define EJC 85 /* Enable Joystick cursor positioning */
84 #define DJC 100 /* Disable Joystick cursor positioning */
85 #define SCC 99 /* Set Cursor Colors */
86 #define SCP 93 /* Set Cursor Parameters */
87 #define DFR 111 /* Draw Filled Rectangle */
88 #define RCP 106 /* Read Cursor Position */
89 #define ESC 27 /* Escape starts a command sequence */
90 #define SCS 96 /* Set Console Status */
91 #define END 1 /* Ctrl-A used to terminate command mode */
92
93 #define BLK 0 /* color table entry for black */
94 #define WHT 7 /* color table entry for white */
95
96 #define command(c) (putc(ESC, stdout), putc(c, stdout))
97 #define byte(b) putc(b, stdout)
98 #define string(s) fputs(s, stdout)
99 #define flush() fflush(stdout)
100
101 #define GAMMA 2.5 /* exponent for color correction */
102
103 #define NCOLORS 248 /* our color table size */
104 #define MINPIX 8 /* minimum hardware color */
105
106 #define NCOLS 512 /* maximum # columns for output */
107 #define NROWS 483-COMHT /* maximum # rows for output */
108 #define COMHT 16 /* height of command line */
109 #define COMCW 63 /* maximum chars on command line */
110
111 int aed_close(), aed_clear(), aed_paintr(),
112 aed_getcur(), aed_comout(), aed_errout();
113
114 static struct driver aed_driver = {
115 aed_close, aed_clear, aed_paintr, aed_getcur,
116 aed_comout, NULL, NULL,
117 1.0, NCOLS, NROWS
118 };
119
120
121 struct driver *
122 aed_init(name, id) /* open AED */
123 char *name, *id;
124 {
125 if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
126 eputs("cannot access terminal\n");
127 return(NULL);
128 }
129 command(RST); /* reset AED */
130 longwait(2);
131 command(OPT);
132 byte(6); byte(1); /* AED command set */
133 command(SEN);
134 string(AEDFMT);
135 command(SCS); /* set console status */
136 byte(CSTAT);
137 command(SCC); /* set cursor type */
138 byte(BLK); byte(WHT); byte(15);
139 command(SCP);
140 byte('+'); byte(0); byte(1);
141 make_gmap(GAMMA); /* make color map */
142 erract[USER].pf = /* set error vector */
143 erract[SYSTEM].pf =
144 erract[INTERNAL].pf =
145 erract[CONSISTENCY].pf = aed_errout;
146 erract[COMMAND].pf = aed_errout;
147 if (erract[WARNING].pf != NULL)
148 erract[WARNING].pf = aed_errout;
149 return(&aed_driver);
150 }
151
152
153 static
154 aed_close() /* close AED */
155 {
156 erract[USER].pf = /* reset error vector */
157 erract[SYSTEM].pf =
158 erract[INTERNAL].pf =
159 erract[CONSISTENCY].pf = eputs;
160 erract[COMMAND].pf = NULL;
161 if (erract[WARNING].pf != NULL)
162 erract[WARNING].pf = wputs;
163 aedsetcap(0, 0); /* go to bottom */
164 command(SEC);
165 byte(WHT); /* white text */
166 byte(END);
167 byte('\n'); /* scroll */
168 flush();
169 ttydone();
170 }
171
172
173 static
174 aed_clear(x, y) /* clear AED */
175 int x, y;
176 {
177 command(FFD);
178 new_ctab(NCOLORS); /* init color table */
179 flush();
180 }
181
182
183 static
184 aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
185 COLOR col;
186 int xmin, ymin, xmax, ymax;
187 {
188 extern int anewcolr();
189 int ndx;
190
191 ndx = get_pixel(col, anewcolr); /* calls anewcolr() */
192 command(SEC); /* draw rectangle */
193 byte(ndx+MINPIX);
194 aedsetcap(xmin, ymin+COMHT);
195 command(DFR);
196 aedcoord(xmax-1, ymax+(-1+COMHT));
197 flush();
198 }
199
200
201 static int
202 aed_getcur(xp, yp) /* get cursor position */
203 int *xp, *yp;
204 {
205 int com;
206
207 command(EJC); /* enable cursor */
208 com = getch(); /* get key */
209 command(DJC); /* disable cursor */
210 aedgetcap(xp, yp); /* get cursor position */
211 *yp -= COMHT; /* convert coordinates */
212 return(com); /* return key hit */
213 }
214
215
216 static
217 aed_comout(out) /* output to command line */
218 register char *out;
219 {
220 static int newl = 1;
221 static int inmsg = 0;
222
223 while (*out) {
224 if (newl) { /* new line */
225 command(SEC);
226 byte(BLK);
227 aedsetcap(0, 0);
228 command(DFR);
229 aedcoord(NCOLS-1, COMHT-1);
230 aedsetcap(1, 4);
231 command(SEC); /* white text */
232 byte(WHT);
233 byte(END);
234 newl = 0;
235 }
236 switch (*out) {
237 case '\n': /* end of line */
238 newl = 1;
239 /* fall through */
240 case '\r':
241 inmsg = 0;
242 byte('\r');
243 break;
244 case '\b': /* back space */
245 if (inmsg > 0 && --inmsg < COMCW)
246 byte('\b');
247 break;
248 default: /* character */
249 if (inmsg++ < COMCW)
250 byte(*out);
251 break;
252 }
253 out++;
254 }
255 flush();
256 }
257
258
259 static
260 aed_errout(msg) /* print an error message */
261 char *msg;
262 {
263 aed_comout(msg);
264 if (*msg && msg[strlen(msg)-1] == '\n')
265 longwait(2);
266 }
267
268
269 /*
270 * aedsetcap - sets AED's current access pointer to (x, y).
271 */
272
273 static
274 aedsetcap(x, y)
275 register int x, y;
276 {
277 command(MOV);
278 aedcoord(x, y);
279 }
280
281 /*
282 * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
283 */
284
285 static
286 aedcoord(x, y)
287 register int x, y;
288 {
289 byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
290 byte(x & 0xff);
291 byte(y & 0xff);
292 }
293
294
295 static
296 aedgetcap(xp, yp) /* get cursor postion */
297 int *xp, *yp;
298 {
299 register int c;
300 /* get cursor postition */
301 command(RCP);
302 flush();
303 c = getch();
304 *xp = (c & 0x30) << 4;
305 *yp = (c & 0x3) << 8;
306 *xp |= getch();
307 *yp |= getch();
308 }
309
310
311 static
312 anewcolr(index, r, g, b) /* enter a color into our table */
313 int index;
314 int r, g, b;
315 {
316 command(SCT);
317 byte((index+MINPIX)&255);
318 byte(1);
319 byte(r);
320 byte(g);
321 byte(b);
322 flush();
323 }
324
325
326 static
327 longwait(t) /* longer wait */
328 int t;
329 {
330 flush();
331 sleep(t);
332 }
