| 1 |
greg |
1.1 |
#ifndef lint
| 2 |
greg |
2.7 |
static const char RCSid[] = "$Id: aed.c,v 2.6 2004/03/30 16:13:00 schorsch Exp $";
| 3 |
greg |
1.1 |
#endif
| 4 |
| 5 |
* aed.c - driver for AED 512 terminal.
| 6 |
greg |
2.3 |
| 7 |
| 8 |
greg |
2.4 |
#include "copyright.h"
| 9 |
greg |
1.1 |
| 10 |
#include <stdio.h>
| 11 |
| 12 |
schorsch |
2.5 |
#include "rterror.h"
| 13 |
#include "color.h"
| 14 |
greg |
1.1 |
#include "driver.h"
| 15 |
| 16 |
| 17 |
/* AED command characters */
| 18 |
| 19 |
#define AEDFMT "1888N" /* Format string to send to AED */
| 20 |
#define CSTAT 0100 /* Console status: lower case */
| 21 |
#define SCT 75 /* Set color lookup table */
| 22 |
#define SEC 67 /* Set color for vector drawing */
| 23 |
#define MOV 81 /* Set CAP (current access pointer) to x, y */
| 24 |
#define OPT 40 /* Miscellaneous terminal control */
| 25 |
#define SEN 71 /* Set encoding types */
| 26 |
#define RST 48 /* Reset terminal */
| 27 |
#define FFD 12 /* Clear screen */
| 28 |
#define EJC 85 /* Enable Joystick cursor positioning */
| 29 |
#define DJC 100 /* Disable Joystick cursor positioning */
| 30 |
#define SCC 99 /* Set Cursor Colors */
| 31 |
#define SCP 93 /* Set Cursor Parameters */
| 32 |
#define DFR 111 /* Draw Filled Rectangle */
| 33 |
#define RCP 106 /* Read Cursor Position */
| 34 |
#define ESC 27 /* Escape starts a command sequence */
| 35 |
#define SCS 96 /* Set Console Status */
| 36 |
#define END 1 /* Ctrl-A used to terminate command mode */
| 37 |
| 38 |
#define BLK 0 /* color table entry for black */
| 39 |
#define WHT 7 /* color table entry for white */
| 40 |
| 41 |
#define command(c) (putc(ESC, stdout), putc(c, stdout))
| 42 |
#define byte(b) putc(b, stdout)
| 43 |
#define string(s) fputs(s, stdout)
| 44 |
#define flush() fflush(stdout)
| 45 |
| 46 |
greg |
1.3 |
#define GAMMA 2.5 /* exponent for color correction */
| 47 |
greg |
1.1 |
| 48 |
greg |
1.3 |
#define NCOLORS 248 /* our color table size */
| 49 |
greg |
1.2 |
#define MINPIX 8 /* minimum hardware color */
| 50 |
greg |
1.1 |
| 51 |
#define NCOLS 512 /* maximum # columns for output */
| 52 |
greg |
1.6 |
#define NROWS 483-COMHT /* maximum # rows for output */
| 53 |
greg |
1.1 |
#define COMHT 16 /* height of command line */
| 54 |
#define COMCW 63 /* maximum chars on command line */
| 55 |
| 56 |
schorsch |
2.5 |
static void aed_errout(char*);
| 57 |
static void longwait(int t);
| 58 |
static void aedgetcap(int *xp, int *yp);
| 59 |
static void aedsetcap(int x, int y);
| 60 |
schorsch |
2.6 |
static dr_newcolrf_t anewcolr;
| 61 |
schorsch |
2.5 |
static void aedcoord(int x, int y);
| 62 |
schorsch |
2.6 |
| 63 |
static dr_closef_t aed_close;
| 64 |
static dr_clearf_t aed_clear;
| 65 |
static dr_paintrf_t aed_paintr;
| 66 |
static dr_getcurf_t aed_getcur;
| 67 |
static dr_comoutf_t comout;
| 68 |
greg |
1.1 |
| 69 |
static struct driver aed_driver = {
| 70 |
aed_close, aed_clear, aed_paintr, aed_getcur,
| 71 |
greg |
1.7 |
aed_comout, NULL, NULL,
| 72 |
greg |
1.6 |
1.0, NCOLS, NROWS
| 73 |
greg |
1.1 |
| 74 |
| 75 |
| 76 |
struct driver *
| 77 |
greg |
1.5 |
aed_init(name, id) /* open AED */
| 78 |
char *name, *id;
| 79 |
greg |
1.1 |
| 80 |
if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
| 81 |
gregl |
2.2 |
eputs("cannot access terminal\n");
| 82 |
greg |
1.1 |
return(NULL);
| 83 |
| 84 |
command(RST); /* reset AED */
| 85 |
longwait(2);
| 86 |
command(OPT);
| 87 |
byte(6); byte(1); /* AED command set */
| 88 |
command(SEN);
| 89 |
string(AEDFMT);
| 90 |
command(SCS); /* set console status */
| 91 |
byte(CSTAT);
| 92 |
command(SCC); /* set cursor type */
| 93 |
byte(BLK); byte(WHT); byte(15);
| 94 |
command(SCP);
| 95 |
byte('+'); byte(0); byte(1);
| 96 |
greg |
1.4 |
make_gmap(GAMMA); /* make color map */
| 97 |
gregl |
2.2 |
erract[USER].pf = /* set error vector */
| 98 |
erract[SYSTEM].pf =
| 99 |
erract[INTERNAL].pf =
| 100 |
erract[CONSISTENCY].pf = aed_errout;
| 101 |
erract[COMMAND].pf = aed_errout;
| 102 |
if (erract[WARNING].pf != NULL)
| 103 |
erract[WARNING].pf = aed_errout;
| 104 |
greg |
1.1 |
return(&aed_driver);
| 105 |
| 106 |
| 107 |
| 108 |
schorsch |
2.5 |
static void
| 109 |
aed_close(void) /* close AED */
| 110 |
greg |
1.1 |
| 111 |
gregl |
2.2 |
erract[USER].pf = /* reset error vector */
| 112 |
erract[SYSTEM].pf =
| 113 |
| 114 |
erract[CONSISTENCY].pf = eputs;
| 115 |
erract[COMMAND].pf = NULL;
| 116 |
| 117 |
erract[WARNING].pf = wputs;
| 118 |
greg |
1.1 |
aedsetcap(0, 0); /* go to bottom */
| 119 |
command(SEC);
| 120 |
byte(WHT); /* white text */
| 121 |
byte(END);
| 122 |
byte('\n'); /* scroll */
| 123 |
flush();
| 124 |
ttydone();
| 125 |
| 126 |
| 127 |
| 128 |
static
| 129 |
aed_clear(x, y) /* clear AED */
| 130 |
int x, y;
| 131 |
| 132 |
command(FFD);
| 133 |
greg |
1.4 |
new_ctab(NCOLORS); /* init color table */
| 134 |
greg |
1.3 |
flush();
| 135 |
greg |
1.1 |
| 136 |
| 137 |
| 138 |
schorsch |
2.5 |
static void
| 139 |
greg |
1.1 |
aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
| 140 |
COLOR col;
| 141 |
int xmin, ymin, xmax, ymax;
| 142 |
| 143 |
greg |
1.3 |
int ndx;
| 144 |
| 145 |
greg |
1.4 |
ndx = get_pixel(col, anewcolr); /* calls anewcolr() */
| 146 |
greg |
1.3 |
command(SEC); /* draw rectangle */
| 147 |
byte(ndx+MINPIX);
| 148 |
greg |
1.1 |
aedsetcap(xmin, ymin+COMHT);
| 149 |
command(DFR);
| 150 |
aedcoord(xmax-1, ymax+(-1+COMHT));
| 151 |
flush();
| 152 |
| 153 |
| 154 |
| 155 |
static int
| 156 |
aed_getcur(xp, yp) /* get cursor position */
| 157 |
int *xp, *yp;
| 158 |
| 159 |
int com;
| 160 |
| 161 |
command(EJC); /* enable cursor */
| 162 |
com = getch(); /* get key */
| 163 |
command(DJC); /* disable cursor */
| 164 |
aedgetcap(xp, yp); /* get cursor position */
| 165 |
*yp -= COMHT; /* convert coordinates */
| 166 |
return(com); /* return key hit */
| 167 |
| 168 |
| 169 |
| 170 |
schorsch |
2.5 |
static void
| 171 |
greg |
1.1 |
aed_comout(out) /* output to command line */
| 172 |
register char *out;
| 173 |
| 174 |
static int newl = 1;
| 175 |
static int inmsg = 0;
| 176 |
| 177 |
while (*out) {
| 178 |
if (newl) { /* new line */
| 179 |
command(SEC);
| 180 |
byte(BLK);
| 181 |
aedsetcap(0, 0);
| 182 |
command(DFR);
| 183 |
aedcoord(NCOLS-1, COMHT-1);
| 184 |
aedsetcap(1, 4);
| 185 |
command(SEC); /* white text */
| 186 |
byte(WHT);
| 187 |
byte(END);
| 188 |
newl = 0;
| 189 |
| 190 |
switch (*out) {
| 191 |
case '\n': /* end of line */
| 192 |
newl = 1;
| 193 |
/* fall through */
| 194 |
case '\r':
| 195 |
inmsg = 0;
| 196 |
byte('\r');
| 197 |
break;
| 198 |
case '\b': /* back space */
| 199 |
if (inmsg > 0 && --inmsg < COMCW)
| 200 |
byte('\b');
| 201 |
break;
| 202 |
default: /* character */
| 203 |
if (inmsg++ < COMCW)
| 204 |
byte(*out);
| 205 |
break;
| 206 |
| 207 |
out++;
| 208 |
| 209 |
flush();
| 210 |
| 211 |
| 212 |
| 213 |
schorsch |
2.5 |
static void
| 214 |
greg |
1.1 |
aed_errout(msg) /* print an error message */
| 215 |
char *msg;
| 216 |
| 217 |
aed_comout(msg);
| 218 |
if (*msg && msg[strlen(msg)-1] == '\n')
| 219 |
longwait(2);
| 220 |
| 221 |
| 222 |
| 223 |
| 224 |
* aedsetcap - sets AED's current access pointer to (x, y).
| 225 |
| 226 |
| 227 |
schorsch |
2.5 |
static void
| 228 |
greg |
1.1 |
aedsetcap(x, y)
| 229 |
register int x, y;
| 230 |
| 231 |
command(MOV);
| 232 |
aedcoord(x, y);
| 233 |
| 234 |
| 235 |
| 236 |
* aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
| 237 |
| 238 |
| 239 |
schorsch |
2.5 |
static void
| 240 |
greg |
1.1 |
aedcoord(x, y)
| 241 |
register int x, y;
| 242 |
| 243 |
byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
| 244 |
byte(x & 0xff);
| 245 |
byte(y & 0xff);
| 246 |
| 247 |
| 248 |
| 249 |
schorsch |
2.5 |
static void
| 250 |
greg |
1.1 |
aedgetcap(xp, yp) /* get cursor postion */
| 251 |
int *xp, *yp;
| 252 |
| 253 |
register int c;
| 254 |
/* get cursor postition */
| 255 |
command(RCP);
| 256 |
flush();
| 257 |
c = getch();
| 258 |
*xp = (c & 0x30) << 4;
| 259 |
*yp = (c & 0x3) << 8;
| 260 |
*xp |= getch();
| 261 |
*yp |= getch();
| 262 |
| 263 |
| 264 |
| 265 |
schorsch |
2.5 |
static void
| 266 |
greg |
1.3 |
anewcolr(index, r, g, b) /* enter a color into our table */
| 267 |
int index;
| 268 |
int r, g, b;
| 269 |
greg |
1.1 |
| 270 |
greg |
1.3 |
command(SCT);
| 271 |
byte((index+MINPIX)&255);
| 272 |
byte(1);
| 273 |
byte(r);
| 274 |
byte(g);
| 275 |
byte(b);
| 276 |
flush();
| 277 |
greg |
1.1 |
| 278 |
| 279 |
| 280 |
schorsch |
2.5 |
static void
| 281 |
greg |
1.1 |
longwait(t) /* longer wait */
| 282 |
int t;
| 283 |
| 284 |
flush();
| 285 |
sleep(t);
| 286 |
