root/radiance/ray/src/rt/aed.c
Revision: 1.3
Committed: Tue Oct 3 11:10:02 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.2: +20 -25 lines
Improved color table allocation, second cut.
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * aed.c - driver for AED 512 terminal.
9 *
10 * 2/2/87
11 */
12
13 #include <stdio.h>
14
15 #include "driver.h"
16
17 #include "color.h"
18
19
20 /* AED command characters */
21
22 #define AEDFMT "1888N" /* Format string to send to AED */
23 #define CSTAT 0100 /* Console status: lower case */
24 #define SCT 75 /* Set color lookup table */
25 #define SEC 67 /* Set color for vector drawing */
26 #define MOV 81 /* Set CAP (current access pointer) to x, y */
27 #define OPT 40 /* Miscellaneous terminal control */
28 #define SEN 71 /* Set encoding types */
29 #define RST 48 /* Reset terminal */
30 #define FFD 12 /* Clear screen */
31 #define EJC 85 /* Enable Joystick cursor positioning */
32 #define DJC 100 /* Disable Joystick cursor positioning */
33 #define SCC 99 /* Set Cursor Colors */
34 #define SCP 93 /* Set Cursor Parameters */
35 #define DFR 111 /* Draw Filled Rectangle */
36 #define RCP 106 /* Read Cursor Position */
37 #define ESC 27 /* Escape starts a command sequence */
38 #define SCS 96 /* Set Console Status */
39 #define END 1 /* Ctrl-A used to terminate command mode */
40
41 #define BLK 0 /* color table entry for black */
42 #define WHT 7 /* color table entry for white */
43
44 #define command(c) (putc(ESC, stdout), putc(c, stdout))
45 #define byte(b) putc(b, stdout)
46 #define string(s) fputs(s, stdout)
47 #define flush() fflush(stdout)
48
49 #define GAMMA 2.5 /* exponent for color correction */
50
51 #define NCOLORS 248 /* our color table size */
52 #define MINPIX 8 /* minimum hardware color */
53
54 #define NCOLS 512 /* maximum # columns for output */
55 #define NROWS 512-COMHT /* maximum # rows for output */
56 #define COMHT 16 /* height of command line */
57 #define COMCW 63 /* maximum chars on command line */
58
59 int anewcolr();
60
61 int aed_close(), aed_clear(), aed_paintr(),
62 aed_getcur(), aed_comout(), aed_errout();
63
64 static struct driver aed_driver = {
65 aed_close, aed_clear, aed_paintr, aed_getcur,
66 aed_comout, NULL,
67 NCOLS, NROWS
68 };
69
70
71 struct driver *
72 aed_init(name) /* open AED */
73 char *name;
74 {
75 if (ttyset(&aed_driver, fileno(stdin)) < 0) { /* set tty driver */
76 stderr_v("cannot access terminal\n");
77 return(NULL);
78 }
79 command(RST); /* reset AED */
80 longwait(2);
81 command(OPT);
82 byte(6); byte(1); /* AED command set */
83 command(SEN);
84 string(AEDFMT);
85 command(SCS); /* set console status */
86 byte(CSTAT);
87 command(SCC); /* set cursor type */
88 byte(BLK); byte(WHT); byte(15);
89 command(SCP);
90 byte('+'); byte(0); byte(1);
91 make_cmap(GAMMA); /* make color map */
92 errvec = aed_errout; /* set error vector */
93 cmdvec = aed_errout;
94 if (wrnvec != NULL)
95 wrnvec = aed_errout;
96 return(&aed_driver);
97 }
98
99
100 static
101 aed_close() /* close AED */
102 {
103 errvec = stderr_v; /* reset error vector */
104 cmdvec = NULL;
105 if (wrnvec != NULL)
106 wrnvec = stderr_v;
107 aedsetcap(0, 0); /* go to bottom */
108 command(SEC);
109 byte(WHT); /* white text */
110 byte(END);
111 byte('\n'); /* scroll */
112 flush();
113 ttydone();
114 }
115
116
117 static
118 aed_clear(x, y) /* clear AED */
119 int x, y;
120 {
121 command(FFD);
122 new_ctab(NCOLORS, anewcolr); /* init color table */
123 flush();
124 }
125
126
127 static
128 aed_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
129 COLOR col;
130 int xmin, ymin, xmax, ymax;
131 {
132 int ndx;
133
134 ndx = get_pixel(col); /* may call anewcolr() */
135 command(SEC); /* draw rectangle */
136 byte(ndx+MINPIX);
137 aedsetcap(xmin, ymin+COMHT);
138 command(DFR);
139 aedcoord(xmax-1, ymax+(-1+COMHT));
140 flush();
141 }
142
143
144 static int
145 aed_getcur(xp, yp) /* get cursor position */
146 int *xp, *yp;
147 {
148 int com;
149
150 command(EJC); /* enable cursor */
151 com = getch(); /* get key */
152 command(DJC); /* disable cursor */
153 aedgetcap(xp, yp); /* get cursor position */
154 *yp -= COMHT; /* convert coordinates */
155 return(com); /* return key hit */
156 }
157
158
159 static
160 aed_comout(out) /* output to command line */
161 register char *out;
162 {
163 static int newl = 1;
164 static int inmsg = 0;
165
166 while (*out) {
167 if (newl) { /* new line */
168 command(SEC);
169 byte(BLK);
170 aedsetcap(0, 0);
171 command(DFR);
172 aedcoord(NCOLS-1, COMHT-1);
173 aedsetcap(1, 4);
174 command(SEC); /* white text */
175 byte(WHT);
176 byte(END);
177 newl = 0;
178 }
179 switch (*out) {
180 case '\n': /* end of line */
181 newl = 1;
182 /* fall through */
183 case '\r':
184 inmsg = 0;
185 byte('\r');
186 break;
187 case '\b': /* back space */
188 if (inmsg > 0 && --inmsg < COMCW)
189 byte('\b');
190 break;
191 default: /* character */
192 if (inmsg++ < COMCW)
193 byte(*out);
194 break;
195 }
196 out++;
197 }
198 flush();
199 }
200
201
202 static
203 aed_errout(msg) /* print an error message */
204 char *msg;
205 {
206 aed_comout(msg);
207 if (*msg && msg[strlen(msg)-1] == '\n')
208 longwait(2);
209 }
210
211
212 /*
213 * aedsetcap - sets AED's current access pointer to (x, y).
214 */
215
216 static
217 aedsetcap(x, y)
218 register int x, y;
219 {
220 command(MOV);
221 aedcoord(x, y);
222 }
223
224 /*
225 * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
226 */
227
228 static
229 aedcoord(x, y)
230 register int x, y;
231 {
232 byte(((x >> 4) & 0x30) | ((y >> 8) & 0x3));
233 byte(x & 0xff);
234 byte(y & 0xff);
235 }
236
237
238 static
239 aedgetcap(xp, yp) /* get cursor postion */
240 int *xp, *yp;
241 {
242 register int c;
243 /* get cursor postition */
244 command(RCP);
245 flush();
246 c = getch();
247 *xp = (c & 0x30) << 4;
248 *yp = (c & 0x3) << 8;
249 *xp |= getch();
250 *yp |= getch();
251 }
252
253
254 static
255 anewcolr(index, r, g, b) /* enter a color into our table */
256 int index;
257 int r, g, b;
258 {
259 command(SCT);
260 byte((index+MINPIX)&255);
261 byte(1);
262 byte(r);
263 byte(g);
264 byte(b);
265 flush();
266 }
267
268
269 static
270 longwait(t) /* longer wait */
271 int t;
272 {
273 flush();
274 sleep(t);
275 }
