root/Development/ray/src/rt/VERSION
Mon Aug 31 20:49:01 2020 UTC (5 years, 3 months ago) by greg
Diff to previous 2.31
Version for official 5.3 release
Tue Oct 9 17:57:17 2018 UTC (7 years, 1 month ago) by greg
Diff to previous 2.30
Moving on to version 5.3a
Mon Oct 8 20:04:09 2018 UTC (7 years, 1 month ago) by greg
Diff to previous 2.29
Preparation for 5.2 release
Sat Aug 26 16:07:22 2017 UTC (8 years, 3 months ago) by greg
Changes since 2.28: +1 -1 lines
Diff to previous 2.28
Thu Aug 17 21:52:49 2017 UTC (8 years, 3 months ago) by greg
Diff to previous 2.27
Official version prep
Fri Sep 25 23:01:12 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 2.26
Starting now on 5.1 alpha
Fri Sep 18 18:29:00 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 2.25
Changes for 5.0 release
Tue Feb 24 19:39:26 2015 UTC (10 years, 9 months ago) by greg
Diff to previous 2.24
Wed Nov 12 17:50:58 2014 UTC (11 years ago) by greg
Changes since 2.23: +1 -1 lines
Diff to previous 2.23
Post-patch return to 4.3 alpha
Wed Nov 12 17:42:35 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2P2
Diff to previous 2.22
Notes for 4.2.2 patch release
Mon Sep 15 22:56:29 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21
Returning to your regularly scheduled programming...
Mon Sep 15 16:49:08 2014 UTC (11 years, 2 months ago) by greg
Diff to previous 2.20
Updates for patch release
Fri Aug 1 01:10:59 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.19
Started 4.3 alpha
Thu Jul 31 18:19:14 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2
Diff to previous 2.18
Official release preparation
Thu Jun 19 16:28:17 2014 UTC (11 years, 5 months ago) by greg
Diff to previous 2.17
Upgraded version to beta
Wed Dec 28 18:39:36 2011 UTC (13 years, 11 months ago) by greg
Diff to previous 2.16
Added pre-emptive check for distant glow sources
Tue Oct 25 22:53:14 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.15: +1 -1 lines
Diff to previous 2.15
Added files needed by cmake
Tue May 18 00:35:57 2010 UTC (15 years, 6 months ago) by greg
Diff to previous 2.14
Version update
Fri Mar 12 19:15:25 2010 UTC (15 years, 8 months ago) by greg
Diff to previous 2.13
Ready 4.0 release
Wed Apr 30 21:48:02 2008 UTC (17 years, 7 months ago) by greg
Diff to previous 2.12
Post 3.9 release changes
Wed Apr 30 21:10:39 2008 UTC (17 years, 7 months ago) by greg
Preparation for 3.9 release
Tue Oct 17 21:52:43 2006 UTC (19 years, 1 month ago) by greg
Version changes for 3.8 release
Mon Aug 22 21:54:41 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R7P2
Mon Aug 22 16:07:26 2005 UTC (20 years, 3 months ago) by greg
Fri Aug 5 18:03:23 2005 UTC (20 years, 4 months ago) by greg
Moving on to version 3.8 (again)
Fri Aug 5 17:24:53 2005 UTC (20 years, 4 months ago) by greg
CVS Tags: rad3R7P1
Changes for 3.7.1 patch release
Wed Jul 27 05:34:17 2005 UTC (20 years, 4 months ago) by greg
Onward to 3.8a
Sun Jul 24 19:53:08 2005 UTC (20 years, 4 months ago) by greg
Mon Oct 25 17:07:35 2004 UTC (21 years, 1 month ago) by greg
CVS Tags: rad3R6P1
Fixed Mark Stock's abort error caused by source & mist combination
Thu Oct 21 16:06:45 2004 UTC (21 years, 1 month ago) by greg
Update for 3.6 official release
Wed Apr 23 16:02:00 2003 UTC (22 years, 7 months ago) by greg
Updated version number to 3.6a
Sat Feb 22 02:07:28 2003 UTC (22 years, 9 months ago) by greg
