| 1 |
import os |
| 2 |
from build_utils import vstamp |
| 3 |
| 4 |
Import('env') # inherit from parent |
| 5 |
| 6 |
mlib = env['RAD_MLIB'] |
| 7 |
| 8 |
# compose paths |
| 9 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
| 10 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
| 11 |
| 12 |
# custom compile flags |
| 13 |
dielectric = env.Object(source='dielectric.c', |
| 14 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) |
| 15 |
| 16 |
duphead = env.Object(source="duphead.c") |
| 17 |
persist = env.Object(source="persist.c") |
| 18 |
ambio = env.Object(source="ambio.c") |
| 19 |
| 20 |
| 21 |
# source and object dependencies |
| 22 |
RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c |
| 23 |
raytrace.c renderopts.c''') + [ambio] |
| 24 |
| 25 |
SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c |
| 26 |
o_face.c o_cone.c o_instance.c o_mesh.c''') |
| 27 |
| 28 |
MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c |
| 29 |
m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric] |
| 30 |
| 31 |
MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') |
| 32 |
| 33 |
SUP = Split('func.c noise3.c data.c') |
| 34 |
| 35 |
# build libraries |
| 36 |
rsrc = RAY + SURF + MAT + MOD + SUP |
| 37 |
env.Command('Version.c', 'VERSION', vstamp.build_version_c) |
| 38 |
env.Depends('Version.c', rsrc) |
| 39 |
Version = env.Object(source=['Version.c']) |
| 40 |
rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) |
| 41 |
| 42 |
if os.name == 'nt': # XXX until we get around fork() and friends |
| 43 |
rcsrc = Split('raycalls.c') |
| 44 |
else: rcsrc = Split('raycalls.c raypcalls.c') |
| 45 |
rclib = env.Library(target=radlib('raycalls'), source=rcsrc) |
| 46 |
Default(rclib) |
| 47 |
| 48 |
fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtio', 'rtmath', |
| 49 |
'rtargs', 'rtpath', 'rtcont', 'rtmem', 'rterror'] |
| 50 |
# build executables |
| 51 |
lasrc = ['lookamb.c', ambio] |
| 52 |
lookamb = env.Program(target=radbin('lookamb'), source=lasrc, |
| 53 |
LIBS=['rtio', 'rtpic']) |
| 54 |
Default(lookamb) |
| 55 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) |
| 56 |
| 57 |
rtmain = env.Object(source=['rtmain.c'], |
| 58 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) |
| 59 |
rtsrc = ['rtrace.c', duphead, persist, rtmain] |
| 60 |
rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, |
| 61 |
LIBS=fullib + mlib |
| 62 |
| 63 |
Default(rtrace) |
| 64 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) |
| 65 |
| 66 |
rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] |
| 67 |
rpict = env.Program(target=radbin('rpict'), source=rpsrc, |
| 68 |
LIBS=fullib+['rtnet']+mlib) |
| 69 |
Default(rpict) |
| 70 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)]) |
| 71 |
| 72 |
if env.has_key('X11LIB'): # lots of special requirements for rvu |
| 73 |
x11incls = [env['X11INCLUDE']] + env['CPPPATH'] |
| 74 |
x11 = env.Object(source='x11.c', CPPPATH=x11incls) |
| 75 |
x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) |
| 76 |
rvmain = env.Object(source='rvmain.c', |
| 77 |
CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) |
| 78 |
rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED |
| 79 |
CCFLAGS=env['CCFLAGS'] + ['$RAD_SPEED'] |
| 80 |
| 81 |
| 82 |
devsrc = Split('devtable.c devcomm.c colortab.c editline.c') |
| 83 |
rvobjs = [x11, x11twind, rv3, rvmain, rlib] |
| 84 |
rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs |
| 85 |
rvu = env.Program(target=radbin('rvu'), source=rvsrc, |
| 86 |
LIBPATH=env['LIBPATH'] + [env['X11LIB']], |
| 87 |
LIBS=fullib + ['X11'] + mlib) |
| 88 |
Default(rvu) |
| 89 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) |
| 90 |
| 91 |
LIBFILES = Split('rayinit.cal') |
| 92 |
env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) |
| 93 |
