| 1 |
import os
| 2 |
from build_utils import vstamp
| 3 |
| 4 |
Import('env') # inherit from parent
| 5 |
| 6 |
mlib = env['RAD_MLIB']
| 7 |
| 8 |
# compose paths
| 9 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
| 10 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
| 11 |
| 12 |
# custom compile flags
| 13 |
dielectric = env.Object(source='dielectric.c',
| 14 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
| 15 |
| 16 |
duphead = env.Object(source="duphead.c")
| 17 |
persist = env.Object(source="persist.c")
| 18 |
ambio = env.Object(source="ambio.c")
| 19 |
| 20 |
| 21 |
# source and object dependencies
| 22 |
RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
| 23 |
raytrace.c renderopts.c''') + [ambio]
| 24 |
| 25 |
SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
| 26 |
o_face.c o_cone.c o_instance.c o_mesh.c''')
| 27 |
| 28 |
MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
| 29 |
m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric]
| 30 |
| 31 |
MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
| 32 |
| 33 |
SUP = Split('func.c noise3.c data.c')
| 34 |
| 35 |
# build libraries
| 36 |
rsrc = RAY + SURF + MAT + MOD + SUP
| 37 |
env.Command('Version.c', 'VERSION', vstamp.build_version_c)
| 38 |
env.Depends('Version.c', rsrc)
| 39 |
Version = env.Object(source='Version.c')
| 40 |
rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
| 41 |
| 42 |
if os.name == 'nt': # XXX until we get around fork() and friends
| 43 |
rcsrc = Split('raycalls.c')
| 44 |
else: rcsrc = Split('raycalls.c raypcalls.c')
| 45 |
rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
| 46 |
Default(rclib)
| 47 |
| 48 |
fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror']
| 49 |
# build executables
| 50 |
lasrc = ['lookamb.c', ambio]
| 51 |
lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
| 52 |
LIBS=['rtio', 'rtpic'])
| 53 |
Default(lookamb)
| 54 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], lookamb)])
| 55 |
| 56 |
rtmain = env.Object(source=['rtmain.c'],
| 57 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
| 58 |
rtsrc = ['rtrace.c', duphead, persist, rtmain]
| 59 |
rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
| 60 |
LIBS=fullib + ['rtproc'] + mlib) # rtproc for win_nice()
| 61 |
Default(rtrace)
| 62 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rtrace)])
| 63 |
| 64 |
rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
| 65 |
rpict = env.Program(target=radbin('rpict'), source=rpsrc,
| 66 |
LIBS=fullib+['rtnet']+mlib)
| 67 |
Default(rpict)
| 68 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rpict)])
| 69 |
| 70 |
if env.has_key('X11LIB'): # lots of special requirements for rvu
| 71 |
x11incls = [env['X11INCLUDE']] + env['CPPPATH']
| 72 |
x11 = env.Object(source='x11.c', CPPPATH=x11incls)
| 73 |
x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
| 74 |
rvmain = env.Object(source='rvmain.c',
| 75 |
CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
| 76 |
rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED
| 77 |
CCFLAGS=env['CCFLAGS'] + [env.get('RAD_SPEED', '')])
| 78 |
| 79 |
devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
| 80 |
rvobjs = [x11, x11twind, rv3, rvmain, rlib]
| 81 |
rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
| 82 |
rvu = env.Program(target=radbin('rvu'), source=rvsrc,
| 83 |
LIBPATH=env['LIBPATH'] + [env['X11LIB']],
| 84 |
LIBS=fullib + ['X11'] + mlib)
| 85 |
Default(rvu)
| 86 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rvu)])
| 87 |
| 88 |
LIBFILES = Split('rayinit.cal')
| 89 |
env.Append(RAD_RLIBINSTALL=[env.Install(env['RAD_RLIBDIR'], LIBFILES)])
| 90 |
