root/radiance/ray/src/rt/SConscript
Revision: 1.3
Committed: Thu Jan 1 10:57:46 2004 UTC (20 years, 5 months ago) by schorsch
Integrated new source occlusion testing routines into SCons build.
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = env['RAD_MLIB']
6
7 # compose paths
8 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
9 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
10
11 # custom compile flags
12 dielectric = env.Object(source='dielectric.c',
13 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
14 # custom C file generation
15 #env.CFile(target='Version.c', source='VERSION', env=build_radversion)
16
17 duphead = env.Object(source="duphead.c")
18 persist = env.Object(source="persist.c")
19 ambio = env.Object(source="ambio.c")
20
21
22 # source and object dependencies
23 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
24 raytrace.c renderopts.c Version.c''') + [ambio]
25
26 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
27 o_face.c o_cone.c o_instance.c o_mesh.c''')
28
29 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
30 m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric]
31
32 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
33
34 SUP = Split('func.c noise3.c data.c')
35
36 # build libraries
37 rsrc = RAY + SURF + MAT + MOD + SUP
38 rlib = env.Library(target=radlib('rttrace'), source=rsrc)
39
40 if os.name == 'nt': # XXX until we get around fork() and friends
41 rcsrc = Split('raycalls.c')
42 else: rcsrc = Split('raycalls.c raypcalls.c')
43 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
44 Default(rclib)
45
46 fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror']
47 # build executables
48 lasrc = ['lookamb.c', ambio]
49 lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
50 LIBS=['rtio', 'rtpic'])
51 Default(lookamb)
52 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], lookamb)])
53
54 rtmain = env.Object(source=['rtmain.c'],
55 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
56 rtsrc = ['rtrace.c', duphead, persist, rtmain]
57 rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
58 LIBS=fullib + ['rtproc'] + mlib) # rtproc for win_nice()
59 Default(rtrace)
60 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rtrace)])
61
62 rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
63 rpict = env.Program(target=radbin('rpict'), source=rpsrc,
64 LIBS=fullib+['rtnet']+mlib)
65 Default(rpict)
66 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rpict)])
67
68 if env.has_key('X11LIB'): # lots of special requirements for rview
69 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
70 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
71 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
72 rvmain = env.Object(source='rvmain.c',
73 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
74 rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED
75 CCFLAGS=env['CCFLAGS'] + [env.get('RAD_SPEED', '')])
76
77 devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
78 rvobjs = [x11, x11twind, rv3, rvmain, rlib]
79 rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
80 rview = env.Program(target=radbin('rview'), source=rvsrc,
81 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
82 LIBS=fullib + ['X11'] + mlib)
83 Default(rview)
84 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rview)])
85
86 LIBFILES = Split('rayinit.cal')
87 env.Append(RAD_RLIBINSTALL=[env.Install(env['RAD_RLIBDIR'], LIBFILES)])
88
