1 |
import os |
2 |
3 |
Import('env') # inherit from parent |
4 |
5 |
mlib = env['RAD_MLIB'] |
6 |
7 |
# compose paths |
8 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
9 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
10 |
11 |
# custom compile flags |
12 |
dielectric = env.Object(source='dielectric.c', |
13 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) |
14 |
# custom C file generation |
15 |
#env.CFile(target='Version.c', source='VERSION', env=build_radversion) |
16 |
17 |
duphead = env.Object(source="duphead.c") |
18 |
persist = env.Object(source="persist.c") |
19 |
ambio = env.Object(source="ambio.c") |
20 |
21 |
22 |
# source and object dependencies |
23 |
RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c |
24 |
raytrace.c renderopts.c Version.c''') + [ambio] |
25 |
26 |
SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c |
27 |
o_face.c o_cone.c o_instance.c o_mesh.c''') |
28 |
29 |
MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c |
30 |
m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric] |
31 |
32 |
MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') |
33 |
34 |
SUP = Split('func.c noise3.c data.c') |
35 |
36 |
# build libraries |
37 |
rsrc = RAY + SURF + MAT + MOD + SUP |
38 |
rlib = env.Library(target=radlib('rttrace'), source=rsrc) |
39 |
40 |
if os.name == 'nt': # XXX until we get around fork() and friends |
41 |
rcsrc = Split('raycalls.c') |
42 |
else: rcsrc = Split('raycalls.c raypcalls.c') |
43 |
rclib = env.Library(target=radlib('raycalls'), source=rcsrc) |
44 |
Default(rclib) |
45 |
46 |
fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror'] |
47 |
# build executables |
48 |
lasrc = ['lookamb.c', ambio] |
49 |
lookamb = env.Program(target=radbin('lookamb'), source=lasrc, |
50 |
LIBS=['rtio', 'rtpic']) |
51 |
Default(lookamb) |
52 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], lookamb)]) |
53 |
54 |
rtmain = env.Object(source=['rtmain.c'], |
55 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) |
56 |
rtsrc = ['rtrace.c', duphead, persist, rtmain] |
57 |
rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, |
58 |
LIBS=fullib + ['rtproc'] + mlib) # rtproc for win_nice() |
59 |
Default(rtrace) |
60 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rtrace)]) |
61 |
62 |
rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] |
63 |
rpict = env.Program(target=radbin('rpict'), source=rpsrc, |
64 |
LIBS=fullib+['rtnet']+mlib) |
65 |
Default(rpict) |
66 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rpict)]) |
67 |
68 |
if env.has_key('X11LIB'): # lots of special requirements for rview |
69 |
x11incls = [env['X11INCLUDE']] + env['CPPPATH'] |
70 |
x11 = env.Object(source='x11.c', CPPPATH=x11incls) |
71 |
x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) |
72 |
rvmain = env.Object(source='rvmain.c', |
73 |
CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) |
74 |
rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED |
75 |
CCFLAGS=env['CCFLAGS'] + [env.get('RAD_SPEED', '')]) |
76 |
77 |
devsrc = Split('devtable.c devcomm.c colortab.c editline.c') |
78 |
rvobjs = [x11, x11twind, rv3, rvmain, rlib] |
79 |
rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs |
80 |
rview = env.Program(target=radbin('rview'), source=rvsrc, |
81 |
LIBPATH=env['LIBPATH'] + [env['X11LIB']], |
82 |
LIBS=fullib + ['X11'] + mlib) |
83 |
Default(rview) |
84 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rview)]) |
85 |
86 |
LIBFILES = Split('rayinit.cal') |
87 |
env.Append(RAD_RLIBINSTALL=[env.Install(env['RAD_RLIBDIR'], LIBFILES)]) |
88 |
