| 1 |
from __future__ import division, print_function, unicode_literals |
| 2 |
| 3 |
import os |
| 4 |
from build_utils import vstamp |
| 5 |
| 6 |
Import('env') # inherit from parent |
| 7 |
| 8 |
mlib = env['RAD_MLIB'] |
| 9 |
| 10 |
# compose paths |
| 11 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
| 12 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
| 13 |
| 14 |
# custom compile flags |
| 15 |
dielectric = env.Object(source='dielectric.c', |
| 16 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) |
| 17 |
| 18 |
duphead = env.Object(source="duphead.c") |
| 19 |
persist = env.Object(source="persist.c") |
| 20 |
ambio = env.Object(source="ambio.c") |
| 21 |
rayfifo = env.Object(source="rayfifo.c") |
| 22 |
raypwin = env.Object(source="raypwin.c") |
| 23 |
raycalls = env.Object(source="raycalls.c") |
| 24 |
| 25 |
CCFLAGS = env.get('CCFLAGS',[]) |
| 26 |
if env.get('PMAP_OOC', 0) not in (0,'0','','n','no','false',False,None): |
| 27 |
PMD = Split('ooccache.c oocnn.c oocmorton.c oococt.c oocsort.c oocbuild.c') |
| 28 |
OOC_CCFLAGS = env.get('CCFLAGS',[]) + ['-DPMAP_OOC'] |
| 29 |
for src in Split('''pmapdata.c pmapio.c pmapopt.c '''): |
| 30 |
obj = env.Object(source=src, CCFLAGS=OOC_CCFLAGS) |
| 31 |
PMD.append(obj) |
| 32 |
pmaptype = env.Object(source="pmaptype.c", CCFLAGS=OOC_CCFLAGS) |
| 33 |
pmapparm = env.Object(source="pmapparm.c", CCFLAGS=OOC_CCFLAGS) |
| 34 |
else: |
| 35 |
PMD = Split('''pmapdata.c pmapio.c pmapopt.c ''') |
| 36 |
OOC_CCFLAGS = env.get('CCFLAGS',[]) |
| 37 |
pmaptype = env.Object(source="pmaptype.c") |
| 38 |
pmapparm = env.Object(source="pmapparm.c") |
| 39 |
| 40 |
# source and object dependencies |
| 41 |
RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c |
| 42 |
raytrace.c renderopts.c''') + [ambio] |
| 43 |
PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c |
| 44 |
pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapdiag.c |
| 45 |
pmcontrib2.c pmutil.c |
| 46 |
''') + [pmaptype, pmapparm] |
| 47 |
SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c |
| 48 |
o_face.c o_cone.c o_instance.c o_mesh.c''') |
| 49 |
MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c |
| 50 |
m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' |
| 51 |
) + [dielectric] |
| 52 |
MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') |
| 53 |
SUP = Split('func.c noise3.c data.c') |
| 54 |
| 55 |
# build libraries |
| 56 |
rsrc = RAY + PMAP + PMD + SURF + MAT + MOD + SUP |
| 57 |
env.Command('Version.c', 'VERSION', vstamp.build_version_c) |
| 58 |
env.Depends('Version.c', rsrc) |
| 59 |
Version = env.Object(source=['Version.c']) |
| 60 |
env.version = Version # make it remotely accessible |
| 61 |
tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) |
| 62 |
| 63 |
rclib = env.Library(target=radlib('raycalls'), |
| 64 |
source=Split('raycalls.c $RAD_PCALLS')) |
| 65 |
Default(rclib) |
| 66 |
| 67 |
rtmain = env.Object(source=['rtmain.c'], |
| 68 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) |
| 69 |
| 70 |
# build executables |
| 71 |
PROGS = [ |
| 72 |
('mkpmap', ['mkpmap.c', Version], CCFLAGS, |
| 73 |
['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]), |
| 74 |
('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version], OOC_CCFLAGS, |
| 75 |
['rtrad', '$RAD_SOCKETLIB', mlib]), |
| 76 |
('lookamb', ['lookamb.c', ambio], CCFLAGS, ['rtrad', mlib]), |
| 77 |
('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], CCFLAGS, |
| 78 |
| 79 |
('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls], |
| 80 |
CCFLAGS, ['rttrace', 'rtrad'] + mlib), |
| 81 |
('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist], CCFLAGS, |
| 82 |
['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib), |
| 83 |
| 84 |
for p in PROGS: |
| 85 |
prog = env.Program(target=radbin(p[0]), source = p[1], |
| 86 |
CCFLAGS = p[2], LIBS = p[3]), |
| 87 |
Default(prog) |
| 88 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)]) |
| 89 |
| 90 |
# we need RVOBJS for any derived viewers, such as winrview |
| 91 |
if os.name == 'nt': RV_DEF = ['WIN_RVIEW'] |
| 92 |
else: RV_DEF = [] |
| 93 |
rvmain = env.Object(source='rvmain.c', |
| 94 |
CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) |
| 95 |
rvobjs = [rvmain] |
| 96 |
for src in Split('''rview.c rv2.c rv3.c |
| 97 |
devtable.c devcomm.c colortab.c editline.c'''): |
| 98 |
rvobjs.append(env.Object(source=src, |
| 99 |
CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF)) |
| 100 |
env['RVOBJS'] = rvobjs |
| 101 |
| 102 |
if env.has_key('X11LIB'): # lots of special requirements for rvu |
| 103 |
x11incls = [env['X11INCLUDE']] + env['CPPPATH'] |
| 104 |
x11 = env.Object(source='x11.c', CPPPATH=x11incls) |
| 105 |
x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) |
| 106 |
rvxobjs = [x11, x11twind] |
| 107 |
rvsrc = rvobjs + rvxobjs |
| 108 |
rvu = env.Program(target=radbin('rvu'), source=rvsrc, |
| 109 |
LIBPATH=env['LIBPATH'] + [env['X11LIB']], |
| 110 |
LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib) |
| 111 |
| 112 |
Default(rvu) |
| 113 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) |
| 114 |
| 115 |
LIBFILES = Split('rayinit.cal') |
| 116 |
env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) |
| 117 |
| 118 |
# vim: set syntax=python: |
| 119 |
# vi: set ts=4 sw=4 : |
