1 |
import os |
2 |
from build_utils import vstamp |
3 |
4 |
Import('env') # inherit from parent |
5 |
6 |
mlib = env['RAD_MLIB'] |
7 |
8 |
# compose paths |
9 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
10 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
11 |
12 |
# custom compile flags |
13 |
dielectric = env.Object(source='dielectric.c', |
14 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) |
15 |
16 |
duphead = env.Object(source="duphead.c") |
17 |
persist = env.Object(source="persist.c") |
18 |
ambio = env.Object(source="ambio.c") |
19 |
rayfifo = env.Object(source="rayfifo.c") |
20 |
raypwin = env.Object(source="raypwin.c") |
21 |
raycalls = env.Object(source="raycalls.c") |
22 |
pmaptype = env.Object(source="pmaptype.c") |
23 |
pmapparm = env.Object(source="pmapparm.c") |
24 |
25 |
26 |
# source and object dependencies |
27 |
RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c |
28 |
raytrace.c renderopts.c''') + [ambio] |
29 |
PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c |
30 |
pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c ''' |
31 |
) + [pmaptype, pmapparm] |
32 |
SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c |
33 |
o_face.c o_cone.c o_instance.c o_mesh.c''') |
34 |
MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c |
35 |
m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' |
36 |
) + [dielectric] |
37 |
MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') |
38 |
SUP = Split('func.c noise3.c data.c') |
39 |
40 |
# build libraries |
41 |
rsrc = RAY + PMAP + SURF + MAT + MOD + SUP |
42 |
env.Command('Version.c', 'VERSION', vstamp.build_version_c) |
43 |
env.Depends('Version.c', rsrc) |
44 |
Version = env.Object(source=['Version.c']) |
45 |
env.version = Version # make it remotely accessible |
46 |
tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) |
47 |
48 |
rclib = env.Library(target=radlib('raycalls'), |
49 |
source=Split('raycalls.c $RAD_PCALLS')) |
50 |
Default(rclib) |
51 |
52 |
rtmain = env.Object(source=['rtmain.c'], |
53 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) |
54 |
55 |
# build executables |
56 |
PROGS = [ |
57 |
('mkpmap', ['mkpmap.c', Version], |
58 |
['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]), |
59 |
('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version], |
60 |
['rtrad', '$RAD_SOCKETLIB', mlib]), |
61 |
('lookamb', ['lookamb.c', ambio], ['rtrad', mlib]), |
62 |
('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], |
63 |
64 |
('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls], |
65 |
['rttrace', 'rtrad'] + mlib), |
66 |
('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist], |
67 |
['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib), |
68 |
69 |
for p in PROGS: |
70 |
prog = env.Program(target=radbin(p[0]), source = p[1], LIBS = p[2]), |
71 |
Default(prog) |
72 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)]) |
73 |
74 |
# we need RVOBJS for any derived viewers, such as winrview |
75 |
if os.name == 'nt': RV_DEF = ['WIN_RVIEW'] |
76 |
else: RV_DEF = [] |
77 |
rvmain = env.Object(source='rvmain.c', |
78 |
CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) |
79 |
rvobjs = [rvmain] |
80 |
for src in Split('''rview.c rv2.c rv3.c |
81 |
devtable.c devcomm.c colortab.c editline.c'''): |
82 |
rvobjs.append(env.Object(source=src, |
83 |
CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF)) |
84 |
env['RVOBJS'] = rvobjs |
85 |
86 |
if env.has_key('X11LIB'): # lots of special requirements for rvu |
87 |
x11incls = [env['X11INCLUDE']] + env['CPPPATH'] |
88 |
x11 = env.Object(source='x11.c', CPPPATH=x11incls) |
89 |
x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) |
90 |
rvxobjs = [x11, x11twind] |
91 |
rvsrc = rvobjs + rvxobjs |
92 |
rvu = env.Program(target=radbin('rvu'), source=rvsrc, |
93 |
LIBPATH=env['LIBPATH'] + [env['X11LIB']], |
94 |
LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib) |
95 |
96 |
Default(rvu) |
97 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) |
98 |
99 |
LIBFILES = Split('rayinit.cal') |
100 |
env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) |
101 |
102 |
# vim: set syntax=python: |
