1 |
import os |
2 |
from build_utils import vstamp |
3 |
4 |
Import('env') # inherit from parent |
5 |
6 |
mlib = env['RAD_MLIB'] |
7 |
8 |
# compose paths |
9 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
10 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
11 |
12 |
# custom compile flags |
13 |
dielectric = env.Object(source='dielectric.c', |
14 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) |
15 |
16 |
duphead = env.Object(source="duphead.c") |
17 |
persist = env.Object(source="persist.c") |
18 |
ambio = env.Object(source="ambio.c") |
19 |
rayfifo = env.Object(source="rayfifo.c") |
20 |
raypwin = env.Object(source="raypwin.c") |
21 |
raycalls = env.Object(source="raycalls.c") |
22 |
pmaptype = env.Object(source="pmaptype.c") |
23 |
pmapparm = env.Object(source="pmapparm.c") |
24 |
25 |
26 |
# source and object dependencies |
27 |
RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c |
28 |
raytrace.c renderopts.c''') + [ambio] |
29 |
PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c |
30 |
pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c ''' |
31 |
) + [pmaptype, pmapparm] |
32 |
33 |
SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c |
34 |
o_face.c o_cone.c o_instance.c o_mesh.c''') |
35 |
36 |
MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c |
37 |
m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' |
38 |
) + [dielectric] |
39 |
40 |
MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') |
41 |
42 |
SUP = Split('func.c noise3.c data.c') |
43 |
44 |
# build libraries |
45 |
rsrc = RAY + PMAP + SURF + MAT + MOD + SUP |
46 |
env.Command('Version.c', 'VERSION', vstamp.build_version_c) |
47 |
env.Depends('Version.c', rsrc) |
48 |
Version = env.Object(source=['Version.c']) |
49 |
env.version = Version # make it remotely accessible |
50 |
rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) |
51 |
52 |
#if os.name == 'nt': # XXX until we get around fork() and friends |
53 |
# rcsrc = Split('raycalls.c') |
54 |
#else: rcsrc = Split('raycalls.c raypcalls.c') |
55 |
rcsrc = Split('raycalls.c $RAD_PCALLS') |
56 |
rclib = env.Library(target=radlib('raycalls'), source=rcsrc) |
57 |
Default(rclib) |
58 |
59 |
fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', |
60 |
'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror'] |
61 |
# build executables |
62 |
mkpmap = env.Program(target=radbin('mkpmap'), |
63 |
source = Split('mkpmap.c') + [Version], |
64 |
LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]), |
65 |
Default(mkpmap) |
66 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', mkpmap)]) |
67 |
68 |
pmapdump = env.Program(target=radbin('pmapdump'), |
69 |
source = Split('pmapdump.c') + [pmaptype, pmapparm, Version], |
70 |
LIBS= fullib + ['$RAD_SOCKETLIB', mlib]), |
71 |
Default(pmapdump) |
72 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', pmapdump)]) |
73 |
74 |
lasrc = ['lookamb.c', ambio] |
75 |
lookamb = env.Program(target=radbin('lookamb'), source=lasrc, |
76 |
LIBS=['rtio', 'rtpic', 'rtmath', mlib]) |
77 |
Default(lookamb) |
78 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) |
79 |
80 |
rcontrib = env.Program(target=radbin('rcontrib'), |
81 |
source = Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], |
82 |
83 |
# LIBS= ['rttrace','rtscene','rtpic','rtargs','rtfunc','rtio', |
84 |
# 'rtproc','rtcont', |
85 |
# 'rtmem', 'rtpath', 'rtmath','rtnet','rterror','$RAD_SOCKETLIB',mlib]), |
86 |
Default(rcontrib) |
87 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rcontrib)]) |
88 |
89 |
90 |
rtmain = env.Object(source=['rtmain.c'], |
91 |
CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) |
92 |
rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls] |
93 |
rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, |
94 |
LIBS=fullib + ['rtnet'] + mlib |
95 |
96 |
Default(rtrace) |
97 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) |
98 |
99 |
rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] |
100 |
rpict = env.Program(target=radbin('rpict'), source=rpsrc, |
101 |
LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib) |
102 |
Default(rpict) |
103 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)]) |
104 |
105 |
if env.has_key('X11LIB'): # lots of special requirements for rvu |
106 |
x11incls = [env['X11INCLUDE']] + env['CPPPATH'] |
107 |
x11 = env.Object(source='x11.c', CPPPATH=x11incls) |
108 |
x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) |
109 |
rvmain = env.Object(source='rvmain.c', |
110 |
CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) |
111 |
rv3 = env.Object(source='rv3.c', |
112 |
CCFLAGS=env['CCFLAGS'] |
113 |
114 |
115 |
devsrc = Split('devtable.c devcomm.c colortab.c editline.c') |
116 |
rvobjs = [x11, x11twind, rv3, rvmain, rlib] |
117 |
rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs |
118 |
rvu = env.Program(target=radbin('rvu'), source=rvsrc, |
119 |
LIBPATH=env['LIBPATH'] + [env['X11LIB']], |
120 |
LIBS = (['rtscene', rclib, 'rttrace', 'rtnet', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', |
121 |
'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror', |
122 |
'X11'] + mlib) |
123 |
#LIBS=fullib + ['X11', rclib] + mlib |
124 |
125 |
Default(rvu) |
126 |
env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) |
127 |
128 |
LIBFILES = Split('rayinit.cal') |
129 |
env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) |
130 |
131 |
# vim: set syntax=python: |
