--- ray/src/rt/SConscript 2004/01/01 20:54:46 1.4 +++ ray/src/rt/SConscript 2004/11/05 22:15:43 1.7 @@ -1,4 +1,5 @@ import os +from build_utils import vstamp Import('env') # inherit from parent @@ -11,8 +12,6 @@ def radlib(name): return os.path.join(env['RAD_BUILDLI # custom compile flags dielectric = env.Object(source='dielectric.c', CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) -# custom C file generation -#env.CFile(target='Version.c', source='VERSION', env=build_radversion) duphead = env.Object(source="duphead.c") persist = env.Object(source="persist.c") @@ -21,7 +20,7 @@ ambio = env.Object(source="ambio.c") # source and object dependencies RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c - raytrace.c renderopts.c Version.c''') + [ambio] + raytrace.c renderopts.c''') + [ambio] SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c o_face.c o_cone.c o_instance.c o_mesh.c''') @@ -35,7 +34,10 @@ SUP = Split('func.c noise3.c data.c') # build libraries rsrc = RAY + SURF + MAT + MOD + SUP -rlib = env.Library(target=radlib('rttrace'), source=rsrc) +env.Command('Version.c', 'VERSION', vstamp.build_version_c) +env.Depends('Version.c', rsrc) +Version = env.Object(source=['Version.c']) +rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) if os.name == 'nt': # XXX until we get around fork() and friends rcsrc = Split('raycalls.c') @@ -43,27 +45,29 @@ else: rcsrc = Split('raycalls.c raypcalls.c') rclib = env.Library(target=radlib('raycalls'), source=rcsrc) Default(rclib) -fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror'] +fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtio', 'rtmath', + 'rtargs', 'rtpath', 'rtcont', 'rtmem', 'rterror'] # build executables lasrc = ['lookamb.c', ambio] lookamb = env.Program(target=radbin('lookamb'), source=lasrc, LIBS=['rtio', 'rtpic']) Default(lookamb) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], lookamb)]) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) rtmain = env.Object(source=['rtmain.c'], CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) rtsrc = ['rtrace.c', duphead, persist, rtmain] rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, - LIBS=fullib + ['rtproc'] + mlib) # rtproc for win_nice() + LIBS=fullib + mlib + ) Default(rtrace) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rtrace)]) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] rpict = env.Program(target=radbin('rpict'), source=rpsrc, LIBS=fullib+['rtnet']+mlib) Default(rpict) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rpict)]) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)]) if env.has_key('X11LIB'): # lots of special requirements for rvu x11incls = [env['X11INCLUDE']] + env['CPPPATH'] @@ -72,7 +76,8 @@ if env.has_key('X11LIB'): # lots of special requiremen rvmain = env.Object(source='rvmain.c', CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED - CCFLAGS=env['CCFLAGS'] + [env.get('RAD_SPEED', '')]) + CCFLAGS=env['CCFLAGS'] + ['$RAD_SPEED'] + ) devsrc = Split('devtable.c devcomm.c colortab.c editline.c') rvobjs = [x11, x11twind, rv3, rvmain, rlib] @@ -81,8 +86,8 @@ if env.has_key('X11LIB'): # lots of special requiremen LIBPATH=env['LIBPATH'] + [env['X11LIB']], LIBS=fullib + ['X11'] + mlib) Default(rvu) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rvu)]) + env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) LIBFILES = Split('rayinit.cal') -env.Append(RAD_RLIBINSTALL=[env.Install(env['RAD_RLIBDIR'], LIBFILES)]) +env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
