--- ray/src/rt/SConscript 2004/10/21 15:47:13 1.6 +++ ray/src/rt/SConscript 2016/03/05 13:24:58 1.16 @@ -16,55 +16,89 @@ dielectric = env.Object(source='dielectric.c', duphead = env.Object(source="duphead.c") persist = env.Object(source="persist.c") ambio = env.Object(source="ambio.c") +rayfifo = env.Object(source="rayfifo.c") +raypwin = env.Object(source="raypwin.c") +raycalls = env.Object(source="raycalls.c") +pmaptype = env.Object(source="pmaptype.c") +pmapparm = env.Object(source="pmapparm.c") # source and object dependencies RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c raytrace.c renderopts.c''') + [ambio] +PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c + pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c ''' + ) + [pmaptype, pmapparm] SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c o_face.c o_cone.c o_instance.c o_mesh.c''') MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c - m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric] + m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' + ) + [dielectric] MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') SUP = Split('func.c noise3.c data.c') # build libraries -rsrc = RAY + SURF + MAT + MOD + SUP +rsrc = RAY + PMAP + SURF + MAT + MOD + SUP env.Command('Version.c', 'VERSION', vstamp.build_version_c) env.Depends('Version.c', rsrc) Version = env.Object(source=['Version.c']) +env.version = Version # make it remotely accessible rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) -if os.name == 'nt': # XXX until we get around fork() and friends - rcsrc = Split('raycalls.c') -else: rcsrc = Split('raycalls.c raypcalls.c') +#if os.name == 'nt': # XXX until we get around fork() and friends +# rcsrc = Split('raycalls.c') +#else: rcsrc = Split('raycalls.c raypcalls.c') +rcsrc = Split('raycalls.c $RAD_PCALLS') rclib = env.Library(target=radlib('raycalls'), source=rcsrc) Default(rclib) -fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror'] +fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', + 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror'] # build executables +mkpmap = env.Program(target=radbin('mkpmap'), + source = Split('mkpmap.c') + [Version], + LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]), +Default(mkpmap) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', mkpmap)]) + +pmapdump = env.Program(target=radbin('pmapdump'), + source = Split('pmapdump.c') + [pmaptype, pmapparm, Version], + LIBS= fullib + ['$RAD_SOCKETLIB', mlib]), +Default(pmapdump) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', pmapdump)]) + lasrc = ['lookamb.c', ambio] lookamb = env.Program(target=radbin('lookamb'), source=lasrc, - LIBS=['rtio', 'rtpic']) + LIBS=['rtio', 'rtpic', 'rtmath', mlib]) Default(lookamb) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) +rcontrib = env.Program(target=radbin('rcontrib'), + source = Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], + LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]), +# LIBS= ['rttrace','rtscene','rtpic','rtargs','rtfunc','rtio', +# 'rtproc','rtcont', +# 'rtmem', 'rtpath', 'rtmath','rtnet','rterror','$RAD_SOCKETLIB',mlib]), +Default(rcontrib) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rcontrib)]) + + rtmain = env.Object(source=['rtmain.c'], CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) -rtsrc = ['rtrace.c', duphead, persist, rtmain] +rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls] rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, - LIBS=fullib + mlib + LIBS=fullib + ['rtnet'] + mlib ) Default(rtrace) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] rpict = env.Program(target=radbin('rpict'), source=rpsrc, - LIBS=fullib+['rtnet']+mlib) + LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib) Default(rpict) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)]) @@ -74,8 +108,8 @@ if env.has_key('X11LIB'): # lots of special requiremen x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) rvmain = env.Object(source='rvmain.c', CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) - rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED - CCFLAGS=env['CCFLAGS'] + ['$RAD_SPEED'] + rv3 = env.Object(source='rv3.c', + CCFLAGS=env['CCFLAGS'] ) devsrc = Split('devtable.c devcomm.c colortab.c editline.c') @@ -83,10 +117,15 @@ if env.has_key('X11LIB'): # lots of special requiremen rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs rvu = env.Program(target=radbin('rvu'), source=rvsrc, LIBPATH=env['LIBPATH'] + [env['X11LIB']], - LIBS=fullib + ['X11'] + mlib) + LIBS = (['rtscene', rclib, 'rttrace', 'rtnet', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', + 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror', + 'X11'] + mlib) + #LIBS=fullib + ['X11', rclib] + mlib + ) Default(rvu) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) LIBFILES = Split('rayinit.cal') env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) +# vim: set syntax=python:
