--- ray/src/rt/SConscript 2010/05/27 19:32:13 1.12 +++ ray/src/rt/SConscript 2016/03/18 22:58:46 1.18 @@ -18,80 +18,80 @@ persist = env.Object(source="persist.c") ambio = env.Object(source="ambio.c") rayfifo = env.Object(source="rayfifo.c") raypwin = env.Object(source="raypwin.c") -raycalls = env.Object(source="raycalls.c') +raycalls = env.Object(source="raycalls.c") +pmaptype = env.Object(source="pmaptype.c") +pmapparm = env.Object(source="pmapparm.c") # source and object dependencies RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c raytrace.c renderopts.c''') + [ambio] - +PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c + pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c ''' + ) + [pmaptype, pmapparm] SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c o_face.c o_cone.c o_instance.c o_mesh.c''') - MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c - m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric] - + m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' + ) + [dielectric] MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') - SUP = Split('func.c noise3.c data.c') # build libraries -rsrc = RAY + SURF + MAT + MOD + SUP +rsrc = RAY + PMAP + SURF + MAT + MOD + SUP env.Command('Version.c', 'VERSION', vstamp.build_version_c) env.Depends('Version.c', rsrc) Version = env.Object(source=['Version.c']) -rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) +env.version = Version # make it remotely accessible +tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) -#if os.name == 'nt': # XXX until we get around fork() and friends -# rcsrc = Split('raycalls.c') -#else: rcsrc = Split('raycalls.c raypcalls.c') -rcsrc = Split('raycalls.c $RAD_PCALLS') -rclib = env.Library(target=radlib('raycalls'), source=rcsrc) +rclib = env.Library(target=radlib('raycalls'), + source=Split('raycalls.c $RAD_PCALLS')) Default(rclib) -fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', - 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror'] -# build executables -lasrc = ['lookamb.c', ambio] -lookamb = env.Program(target=radbin('lookamb'), source=lasrc, - LIBS=['rtio', 'rtpic']) -Default(lookamb) -env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) - rtmain = env.Object(source=['rtmain.c'], CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) -rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls] -rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, - LIBS=fullib + mlib - ) -Default(rtrace) -env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) -rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] -rpict = env.Program(target=radbin('rpict'), source=rpsrc, - LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib) -Default(rpict) -env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)]) +# build executables +PROGS = [ +('mkpmap', ['mkpmap.c', Version], + ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]), +('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version], + ['rtrad', '$RAD_SOCKETLIB', mlib]), +('lookamb', ['lookamb.c', ambio], ['rtrad', mlib]), +('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], + ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]), +('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls], + ['rttrace', 'rtrad'] + mlib), +('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist], + ['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib), +] +for p in PROGS: + prog = env.Program(target=radbin(p[0]), source = p[1], LIBS = p[2]), + Default(prog) + env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)]) +# we need RVOBJS for any derived viewers, such as winrview +if os.name == 'nt': RV_DEF = ['WIN_RVIEW'] +else: RV_DEF = [] +rvmain = env.Object(source='rvmain.c', + CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) +rvobjs = [rvmain] +for src in Split('''rview.c rv2.c rv3.c + devtable.c devcomm.c colortab.c editline.c'''): + rvobjs.append(env.Object(source=src, + CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF)) +env['RVOBJS'] = rvobjs + if env.has_key('X11LIB'): # lots of special requirements for rvu x11incls = [env['X11INCLUDE']] + env['CPPPATH'] x11 = env.Object(source='x11.c', CPPPATH=x11incls) x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) - rvmain = env.Object(source='rvmain.c', - CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) - rv3 = env.Object(source='rv3.c', - CCFLAGS=env['CCFLAGS'] - ) - - devsrc = Split('devtable.c devcomm.c colortab.c editline.c') - rvobjs = [x11, x11twind, rv3, rvmain, rlib] - rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs + rvxobjs = [x11, x11twind] + rvsrc = rvobjs + rvxobjs rvu = env.Program(target=radbin('rvu'), source=rvsrc, LIBPATH=env['LIBPATH'] + [env['X11LIB']], - LIBS = (['rtscene', rclib, 'rttrace', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', - 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror', - 'X11'] + mlib) - #LIBS=fullib + ['X11', rclib] + mlib + LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib) ) Default(rvu) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) @@ -99,3 +99,4 @@ if env.has_key('X11LIB'): # lots of special requiremen LIBFILES = Split('rayinit.cal') env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) +# vim: set syntax=python:
