root/radiance/ray/src/rt/SConscript
Revision: 1.20
Committed: Tue Jan 9 00:08:57 2018 UTC (7 years, 6 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 1.19: +26 -15 lines
SCons Option to build Pmap with OOC data on unix
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4 from build_utils import vstamp
5
6 Import('env') # inherit from parent
7
8 mlib = env['RAD_MLIB']
9
10 # compose paths
11 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
12 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
13
14 # custom compile flags
15 dielectric = env.Object(source='dielectric.c',
16 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
17
18 duphead = env.Object(source="duphead.c")
19 persist = env.Object(source="persist.c")
20 ambio = env.Object(source="ambio.c")
21 rayfifo = env.Object(source="rayfifo.c")
22 raypwin = env.Object(source="raypwin.c")
23 raycalls = env.Object(source="raycalls.c")
24
25 CCFLAGS = env.get('CCFLAGS',[])
26 if env.get('PMAP_OOC', 0) not in (0,'0','','n','no','false',False,None):
27 PMD = Split('ooccache.c oocnn.c oocmorton.c oococt.c oocsort.c oocbuild.c')
28 OOC_CCFLAGS = env.get('CCFLAGS',[]) + ['-DPMAP_OOC']
29 for src in Split('''pmapdata.c pmapio.c pmapopt.c '''):
30 obj = env.Object(source=src, CCFLAGS=OOC_CCFLAGS)
31 PMD.append(obj)
32 pmaptype = env.Object(source="pmaptype.c", CCFLAGS=OOC_CCFLAGS)
33 pmapparm = env.Object(source="pmapparm.c", CCFLAGS=OOC_CCFLAGS)
34 else:
35 PMD = Split('''pmapdata.c pmapio.c pmapopt.c ''')
36 OOC_CCFLAGS = env.get('CCFLAGS',[])
37 pmaptype = env.Object(source="pmaptype.c")
38 pmapparm = env.Object(source="pmapparm.c")
39
40 # source and object dependencies
41 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
42 raytrace.c renderopts.c''') + [ambio]
43 PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c
44 pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapdiag.c
45 pmcontrib2.c pmutil.c
46 ''') + [pmaptype, pmapparm]
47 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
48 o_face.c o_cone.c o_instance.c o_mesh.c''')
49 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
50 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c '''
51 ) + [dielectric]
52 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
53 SUP = Split('func.c noise3.c data.c')
54
55 # build libraries
56 rsrc = RAY + PMAP + PMD + SURF + MAT + MOD + SUP
57 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
58 env.Depends('Version.c', rsrc)
59 Version = env.Object(source=['Version.c'])
60 env.version = Version # make it remotely accessible
61 tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
62
63 rclib = env.Library(target=radlib('raycalls'),
64 source=Split('raycalls.c $RAD_PCALLS'))
65 Default(rclib)
66
67 rtmain = env.Object(source=['rtmain.c'],
68 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
69
70 # build executables
71 PROGS = [
72 ('mkpmap', ['mkpmap.c', Version], CCFLAGS,
73 ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
74 ('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version], OOC_CCFLAGS,
75 ['rtrad', '$RAD_SOCKETLIB', mlib]),
76 ('lookamb', ['lookamb.c', ambio], CCFLAGS, ['rtrad', mlib]),
77 ('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], CCFLAGS,
78 ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
79 ('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls],
80 CCFLAGS, ['rttrace', 'rtrad'] + mlib),
81 ('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist], CCFLAGS,
82 ['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib),
83 ]
84 for p in PROGS:
85 prog = env.Program(target=radbin(p[0]), source = p[1],
86 CCFLAGS = p[2], LIBS = p[3]),
87 Default(prog)
88 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)])
89
90 # we need RVOBJS for any derived viewers, such as winrview
91 if os.name == 'nt': RV_DEF = ['WIN_RVIEW']
92 else: RV_DEF = []
93 rvmain = env.Object(source='rvmain.c',
94 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
95 rvobjs = [rvmain]
96 for src in Split('''rview.c rv2.c rv3.c
97 devtable.c devcomm.c colortab.c editline.c'''):
98 rvobjs.append(env.Object(source=src,
99 CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF))
100 env['RVOBJS'] = rvobjs
101
102 if env.has_key('X11LIB'): # lots of special requirements for rvu
103 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
104 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
105 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
106 rvxobjs = [x11, x11twind]
107 rvsrc = rvobjs + rvxobjs
108 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
109 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
110 LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib)
111 )
112 Default(rvu)
113 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
114
115 LIBFILES = Split('rayinit.cal')
116 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
117
118 # vim: set syntax=python:
119 # vi: set ts=4 sw=4 :
