root/radiance/ray/src/rt/SConscript
Revision: 1.19
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 7 months ago) by schorsch
Changes since 1.18: +8 -2 lines
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4 from build_utils import vstamp
5
6 Import('env') # inherit from parent
7
8 mlib = env['RAD_MLIB']
9
10 # compose paths
11 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
12 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
13
14 # custom compile flags
15 dielectric = env.Object(source='dielectric.c',
16 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
17
18 duphead = env.Object(source="duphead.c")
19 persist = env.Object(source="persist.c")
20 ambio = env.Object(source="ambio.c")
21 rayfifo = env.Object(source="rayfifo.c")
22 raypwin = env.Object(source="raypwin.c")
23 raycalls = env.Object(source="raycalls.c")
24 pmaptype = env.Object(source="pmaptype.c")
25 pmapparm = env.Object(source="pmapparm.c")
26
27
28 # source and object dependencies
29 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
30 raytrace.c renderopts.c''') + [ambio]
31 PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c
32 pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c
33 oocbuild.c ooccache.c oocnn.c oocmorton.c oococt.c oocsort.c
34 pmcontrib2.c pmapkdt.c pmutil.c
35 ''') + [pmaptype, pmapparm]
36 # not ready yet: pmapooc.c
37 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
38 o_face.c o_cone.c o_instance.c o_mesh.c''')
39 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
40 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c '''
41 ) + [dielectric]
42 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
43 SUP = Split('func.c noise3.c data.c')
44
45 # build libraries
46 rsrc = RAY + PMAP + SURF + MAT + MOD + SUP
47 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
48 env.Depends('Version.c', rsrc)
49 Version = env.Object(source=['Version.c'])
50 env.version = Version # make it remotely accessible
51 tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
52
53 rclib = env.Library(target=radlib('raycalls'),
54 source=Split('raycalls.c $RAD_PCALLS'))
55 Default(rclib)
56
57 rtmain = env.Object(source=['rtmain.c'],
58 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
59
60 # build executables
61 PROGS = [
62 ('mkpmap', ['mkpmap.c', Version],
63 ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
64 ('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version],
65 ['rtrad', '$RAD_SOCKETLIB', mlib]),
66 ('lookamb', ['lookamb.c', ambio], ['rtrad', mlib]),
67 ('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version],
68 ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
69 ('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls],
70 ['rttrace', 'rtrad'] + mlib),
71 ('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist],
72 ['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib),
73 ]
74 for p in PROGS:
75 prog = env.Program(target=radbin(p[0]), source = p[1], LIBS = p[2]),
76 Default(prog)
77 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)])
78
79 # we need RVOBJS for any derived viewers, such as winrview
80 if os.name == 'nt': RV_DEF = ['WIN_RVIEW']
81 else: RV_DEF = []
82 rvmain = env.Object(source='rvmain.c',
83 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
84 rvobjs = [rvmain]
85 for src in Split('''rview.c rv2.c rv3.c
86 devtable.c devcomm.c colortab.c editline.c'''):
87 rvobjs.append(env.Object(source=src,
88 CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF))
89 env['RVOBJS'] = rvobjs
90
91 if env.has_key('X11LIB'): # lots of special requirements for rvu
92 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
93 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
94 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
95 rvxobjs = [x11, x11twind]
96 rvsrc = rvobjs + rvxobjs
97 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
98 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
99 LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib)
100 )
101 Default(rvu)
102 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
103
104 LIBFILES = Split('rayinit.cal')
105 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
106
107 # vim: set syntax=python:
108 # vi: set ts=4 sw=4 :
