root/radiance/ray/src/rt/SConscript
Revision: 1.16
Committed: Sat Mar 5 13:24:58 2016 UTC (9 years, 2 months ago) by schorsch
Changes since 1.15: +22 -5 lines
1 import os
2 from build_utils import vstamp
3
4 Import('env') # inherit from parent
5
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11
12 # custom compile flags
13 dielectric = env.Object(source='dielectric.c',
14 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16 duphead = env.Object(source="duphead.c")
17 persist = env.Object(source="persist.c")
18 ambio = env.Object(source="ambio.c")
19 rayfifo = env.Object(source="rayfifo.c")
20 raypwin = env.Object(source="raypwin.c")
21 raycalls = env.Object(source="raycalls.c")
22 pmaptype = env.Object(source="pmaptype.c")
23 pmapparm = env.Object(source="pmapparm.c")
24
25
26 # source and object dependencies
27 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
28 raytrace.c renderopts.c''') + [ambio]
29 PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c
30 pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c '''
31 ) + [pmaptype, pmapparm]
32
33 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
34 o_face.c o_cone.c o_instance.c o_mesh.c''')
35
36 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
37 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c '''
38 ) + [dielectric]
39
40 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
41
42 SUP = Split('func.c noise3.c data.c')
43
44 # build libraries
45 rsrc = RAY + PMAP + SURF + MAT + MOD + SUP
46 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
47 env.Depends('Version.c', rsrc)
48 Version = env.Object(source=['Version.c'])
49 env.version = Version # make it remotely accessible
50 rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
51
52 #if os.name == 'nt': # XXX until we get around fork() and friends
53 # rcsrc = Split('raycalls.c')
54 #else: rcsrc = Split('raycalls.c raypcalls.c')
55 rcsrc = Split('raycalls.c $RAD_PCALLS')
56 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
57 Default(rclib)
58
59 fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
60 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror']
61 # build executables
62 mkpmap = env.Program(target=radbin('mkpmap'),
63 source = Split('mkpmap.c') + [Version],
64 LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]),
65 Default(mkpmap)
66 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', mkpmap)])
67
68 pmapdump = env.Program(target=radbin('pmapdump'),
69 source = Split('pmapdump.c') + [pmaptype, pmapparm, Version],
70 LIBS= fullib + ['$RAD_SOCKETLIB', mlib]),
71 Default(pmapdump)
72 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', pmapdump)])
73
74 lasrc = ['lookamb.c', ambio]
75 lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
76 LIBS=['rtio', 'rtpic', 'rtmath', mlib])
77 Default(lookamb)
78 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)])
79
80 rcontrib = env.Program(target=radbin('rcontrib'),
81 source = Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version],
82 LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]),
83 # LIBS= ['rttrace','rtscene','rtpic','rtargs','rtfunc','rtio',
84 # 'rtproc','rtcont',
85 # 'rtmem', 'rtpath', 'rtmath','rtnet','rterror','$RAD_SOCKETLIB',mlib]),
86 Default(rcontrib)
87 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rcontrib)])
88
89
90 rtmain = env.Object(source=['rtmain.c'],
91 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
92 rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls]
93 rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
94 LIBS=fullib + ['rtnet'] + mlib
95 )
96 Default(rtrace)
97 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)])
98
99 rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
100 rpict = env.Program(target=radbin('rpict'), source=rpsrc,
101 LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib)
102 Default(rpict)
103 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)])
104
105 if env.has_key('X11LIB'): # lots of special requirements for rvu
106 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
107 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
108 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
109 rvmain = env.Object(source='rvmain.c',
110 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
111 rv3 = env.Object(source='rv3.c',
112 CCFLAGS=env['CCFLAGS']
113 )
114
115 devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
116 rvobjs = [x11, x11twind, rv3, rvmain, rlib]
117 rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
118 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
119 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
120 LIBS = (['rtscene', rclib, 'rttrace', 'rtnet', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
121 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror',
122 'X11'] + mlib)
123 #LIBS=fullib + ['X11', rclib] + mlib
124 )
125 Default(rvu)
126 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
127
128 LIBFILES = Split('rayinit.cal')
129 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
130
131 # vim: set syntax=python:
