root/radiance/ray/src/rt/SConscript
Revision: 1.18
Committed: Fri Mar 18 22:58:46 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 1.17: +14 -10 lines
create a seperate grouping for the files needed by rvu display drivers
# User Rev Content
1 schorsch 1.1 import os
2 schorsch 1.5 from build_utils import vstamp
3 schorsch 1.1
4     Import('env') # inherit from parent
5
6 schorsch 1.2 mlib = env['RAD_MLIB']
7 schorsch 1.1
8     # compose paths
9 schorsch 1.2 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11 schorsch 1.1
12     # custom compile flags
13 schorsch 1.2 dielectric = env.Object(source='dielectric.c',
14     CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16     duphead = env.Object(source="duphead.c")
17     persist = env.Object(source="persist.c")
18     ambio = env.Object(source="ambio.c")
19 greg 1.12 rayfifo = env.Object(source="rayfifo.c")
20     raypwin = env.Object(source="raypwin.c")
21 greg 1.13 raycalls = env.Object(source="raycalls.c")
22 schorsch 1.16 pmaptype = env.Object(source="pmaptype.c")
23     pmapparm = env.Object(source="pmapparm.c")
24 schorsch 1.2
25 schorsch 1.1
26     # source and object dependencies
27 schorsch 1.2 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
28 schorsch 1.5 raytrace.c renderopts.c''') + [ambio]
29 schorsch 1.15 PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c
30 schorsch 1.16 pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c '''
31     ) + [pmaptype, pmapparm]
32 schorsch 1.3 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
33     o_face.c o_cone.c o_instance.c o_mesh.c''')
34 schorsch 1.1 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
35 schorsch 1.15 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c '''
36     ) + [dielectric]
37 schorsch 1.1 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
38     SUP = Split('func.c noise3.c data.c')
39
40     # build libraries
41 schorsch 1.15 rsrc = RAY + PMAP + SURF + MAT + MOD + SUP
42 schorsch 1.5 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
43     env.Depends('Version.c', rsrc)
44 schorsch 1.6 Version = env.Object(source=['Version.c'])
45 schorsch 1.16 env.version = Version # make it remotely accessible
46 schorsch 1.18 tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
47 schorsch 1.1
48 schorsch 1.17 rclib = env.Library(target=radlib('raycalls'),
49     source=Split('raycalls.c $RAD_PCALLS'))
50 schorsch 1.1 Default(rclib)
51
52 schorsch 1.17 rtmain = env.Object(source=['rtmain.c'],
53     CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
54
55 schorsch 1.1 # build executables
56 schorsch 1.17 PROGS = [
57     ('mkpmap', ['mkpmap.c', Version],
58     ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
59     ('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version],
60     ['rtrad', '$RAD_SOCKETLIB', mlib]),
61     ('lookamb', ['lookamb.c', ambio], ['rtrad', mlib]),
62     ('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version],
63     ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
64     ('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls],
65     ['rttrace', 'rtrad'] + mlib),
66     ('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist],
67     ['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib),
68     ]
69     for p in PROGS:
70     prog = env.Program(target=radbin(p[0]), source = p[1], LIBS = p[2]),
71     Default(prog)
72     env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)])
73 schorsch 1.15
74 schorsch 1.18 # we need RVOBJS for any derived viewers, such as winrview
75     if os.name == 'nt': RV_DEF = ['WIN_RVIEW']
76     else: RV_DEF = []
77     rvmain = env.Object(source='rvmain.c',
78     CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
79     rvobjs = [rvmain]
80     for src in Split('''rview.c rv2.c rv3.c
81     devtable.c devcomm.c colortab.c editline.c'''):
82     rvobjs.append(env.Object(source=src,
83     CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF))
84     env['RVOBJS'] = rvobjs
85 schorsch 1.2
86 schorsch 1.4 if env.has_key('X11LIB'): # lots of special requirements for rvu
87 schorsch 1.2 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
88     x11 = env.Object(source='x11.c', CPPPATH=x11incls)
89     x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
90 schorsch 1.18 rvxobjs = [x11, x11twind]
91     rvsrc = rvobjs + rvxobjs
92 schorsch 1.4 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
93 schorsch 1.2 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
94 schorsch 1.17 LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib)
95 schorsch 1.11 )
96 schorsch 1.4 Default(rvu)
97 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
98 schorsch 1.1
99     LIBFILES = Split('rayinit.cal')
100 schorsch 1.6 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
101 schorsch 1.1
102 schorsch 1.16 # vim: set syntax=python:
