root/radiance/ray/src/rt/SConscript
Fri Apr 15 21:52:16 2011 UTC (13 years ago) by greg
Diff to previous 1.13 , to selected 1.8
SCONS fixes for latest build
Wed Jun 2 15:58:30 2010 UTC (13 years, 10 months ago) by greg
Diff to previous 1.12 , to selected 1.8
Fixes to MINGW build
Thu May 27 19:32:13 2010 UTC (13 years, 11 months ago) by greg
Diff to previous 1.11 , to selected 1.8
Tue Dec 23 15:04:01 2008 UTC (15 years, 4 months ago) by schorsch
Changes since 1.10: +5 -1 lines
Diff to previous 1.10 , to selected 1.8
Mon Apr 21 07:31:30 2008 UTC (16 years ago) by schorsch
Changes since 1.9: +6 -5 lines
Diff to previous 1.9 , to selected 1.8
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (18 years, 7 months ago) by schorsch
Diff to previous 1.8
Revision 1.8 - (view) (download) (annotate) - [selected]
Wed Sep 14 09:28:35 2005 UTC (18 years, 7 months ago) by schorsch
Diff to previous 1.7
Fri Nov 5 22:15:43 2004 UTC (19 years, 5 months ago) by schorsch
Diff to previous 1.6 , to selected 1.8
Thu Oct 21 15:47:13 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.5: +10 -8 lines
Diff to previous 1.5 , to selected 1.8
SCons build simplifications.
Sun Jul 4 12:08:48 2004 UTC (19 years, 9 months ago) by schorsch
Changes since 1.4: +6 -4 lines
Diff to previous 1.4 , to selected 1.8
Thu Jan 1 20:54:46 2004 UTC (20 years, 3 months ago) by schorsch
Diff to previous 1.3 , to selected 1.8
Renamed rview to rvu.
Thu Jan 1 10:57:46 2004 UTC (20 years, 4 months ago) by schorsch
Diff to previous 1.2 , to selected 1.8
Integrated new source occlusion testing routines into SCons build.
Mon Oct 27 10:35:43 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +47 -40 lines
Diff to previous 1.1 , to selected 1.8
Tue Oct 21 19:27:29 2003 UTC (20 years, 6 months ago) by schorsch
Diff to selected 1.8
