root/radiance/ray/src/rt/SConscript
Revision: 1.12
Committed: Thu May 27 19:32:13 2010 UTC (15 years, 2 months ago) by greg
1 import os
2 from build_utils import vstamp
3
4 Import('env') # inherit from parent
5
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11
12 # custom compile flags
13 dielectric = env.Object(source='dielectric.c',
14 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16 duphead = env.Object(source="duphead.c")
17 persist = env.Object(source="persist.c")
18 ambio = env.Object(source="ambio.c")
19 rayfifo = env.Object(source="rayfifo.c")
20 raypwin = env.Object(source="raypwin.c")
21 raycalls = env.Object(source="raycalls.c')
22
23
24 # source and object dependencies
25 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
26 raytrace.c renderopts.c''') + [ambio]
27
28 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
29 o_face.c o_cone.c o_instance.c o_mesh.c''')
30
31 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
32 m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric]
33
34 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
35
36 SUP = Split('func.c noise3.c data.c')
37
38 # build libraries
39 rsrc = RAY + SURF + MAT + MOD + SUP
40 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
41 env.Depends('Version.c', rsrc)
42 Version = env.Object(source=['Version.c'])
43 rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
44
45 #if os.name == 'nt': # XXX until we get around fork() and friends
46 # rcsrc = Split('raycalls.c')
47 #else: rcsrc = Split('raycalls.c raypcalls.c')
48 rcsrc = Split('raycalls.c $RAD_PCALLS')
49 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
50 Default(rclib)
51
52 fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
53 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror']
54 # build executables
55 lasrc = ['lookamb.c', ambio]
56 lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
57 LIBS=['rtio', 'rtpic'])
58 Default(lookamb)
59 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)])
60
61 rtmain = env.Object(source=['rtmain.c'],
62 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
63 rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls]
64 rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
65 LIBS=fullib + mlib
66 )
67 Default(rtrace)
68 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)])
69
70 rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
71 rpict = env.Program(target=radbin('rpict'), source=rpsrc,
72 LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib)
73 Default(rpict)
74 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)])
75
76 if env.has_key('X11LIB'): # lots of special requirements for rvu
77 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
78 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
79 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
80 rvmain = env.Object(source='rvmain.c',
81 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
82 rv3 = env.Object(source='rv3.c',
83 CCFLAGS=env['CCFLAGS']
84 )
85
86 devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
87 rvobjs = [x11, x11twind, rv3, rvmain, rlib]
88 rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
89 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
90 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
91 LIBS = (['rtscene', rclib, 'rttrace', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
92 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror',
93 'X11'] + mlib)
94 #LIBS=fullib + ['X11', rclib] + mlib
95 )
96 Default(rvu)
97 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
98
99 LIBFILES = Split('rayinit.cal')
100 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
101
