root/radiance/ray/src/rt/SConscript
Revision: 1.14
Committed: Fri Apr 15 21:52:16 2011 UTC (14 years, 3 months ago) by greg
CVS Tags: rad5R0, rad4R2, rad4R1, rad4R2P1, rad4R2P2
SCONS fixes for latest build
# User Rev Content
1 schorsch 1.1 import os
2 schorsch 1.5 from build_utils import vstamp
3 schorsch 1.1
4     Import('env') # inherit from parent
5
6 schorsch 1.2 mlib = env['RAD_MLIB']
7 schorsch 1.1
8     # compose paths
9 schorsch 1.2 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11 schorsch 1.1
12     # custom compile flags
13 schorsch 1.2 dielectric = env.Object(source='dielectric.c',
14     CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16     duphead = env.Object(source="duphead.c")
17     persist = env.Object(source="persist.c")
18     ambio = env.Object(source="ambio.c")
19 greg 1.12 rayfifo = env.Object(source="rayfifo.c")
20     raypwin = env.Object(source="raypwin.c")
21 greg 1.13 raycalls = env.Object(source="raycalls.c")
22 schorsch 1.2
23 schorsch 1.1
24     # source and object dependencies
25 schorsch 1.2 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
26 schorsch 1.5 raytrace.c renderopts.c''') + [ambio]
27 schorsch 1.1
28 schorsch 1.3 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
29     o_face.c o_cone.c o_instance.c o_mesh.c''')
30 schorsch 1.1
31     MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
32 greg 1.14 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c''') + [dielectric]
33 schorsch 1.1
34     MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
35
36     SUP = Split('func.c noise3.c data.c')
37
38     # build libraries
39     rsrc = RAY + SURF + MAT + MOD + SUP
40 schorsch 1.5 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
41     env.Depends('Version.c', rsrc)
42 schorsch 1.6 Version = env.Object(source=['Version.c'])
43 schorsch 1.5 rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
44 schorsch 1.1
45 schorsch 1.10 #if os.name == 'nt': # XXX until we get around fork() and friends
46     # rcsrc = Split('raycalls.c')
47     #else: rcsrc = Split('raycalls.c raypcalls.c')
48     rcsrc = Split('raycalls.c $RAD_PCALLS')
49 schorsch 1.2 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
50 schorsch 1.1 Default(rclib)
51
52 schorsch 1.10 fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
53     'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror']
54 schorsch 1.1 # build executables
55 schorsch 1.2 lasrc = ['lookamb.c', ambio]
56     lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
57     LIBS=['rtio', 'rtpic'])
58 schorsch 1.1 Default(lookamb)
59 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)])
60 schorsch 1.1
61 schorsch 1.2 rtmain = env.Object(source=['rtmain.c'],
62     CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
63 greg 1.12 rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls]
64 schorsch 1.2 rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
65 schorsch 1.6 LIBS=fullib + mlib
66     )
67 schorsch 1.2 Default(rtrace)
68 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)])
69 schorsch 1.2
70     rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
71     rpict = env.Program(target=radbin('rpict'), source=rpsrc,
72 schorsch 1.8 LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib)
73 schorsch 1.2 Default(rpict)
74 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)])
75 schorsch 1.2
76 schorsch 1.4 if env.has_key('X11LIB'): # lots of special requirements for rvu
77 schorsch 1.2 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
78     x11 = env.Object(source='x11.c', CPPPATH=x11incls)
79     x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
80     rvmain = env.Object(source='rvmain.c',
81     CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
82 schorsch 1.9 rv3 = env.Object(source='rv3.c',
83     CCFLAGS=env['CCFLAGS']
84 schorsch 1.6 )
85 schorsch 1.1
86     devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
87     rvobjs = [x11, x11twind, rv3, rvmain, rlib]
88     rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
89 schorsch 1.4 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
90 schorsch 1.2 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
91 schorsch 1.11 LIBS = (['rtscene', rclib, 'rttrace', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
92     'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror',
93     'X11'] + mlib)
94     #LIBS=fullib + ['X11', rclib] + mlib
95     )
96 schorsch 1.4 Default(rvu)
97 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
98 schorsch 1.1
99     LIBFILES = Split('rayinit.cal')
100 schorsch 1.6 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
101 schorsch 1.1
