--- ray/src/rt/SConscript 2003/10/21 19:27:29 1.1 +++ ray/src/rt/SConscript 2004/10/21 15:47:13 1.6 @@ -1,26 +1,29 @@ import os +from build_utils import vstamp Import('env') # inherit from parent -# create a modified local copy of the build environment -rt = env.Copy(LIBS=env['RAD_MLIB'] + ['rt']) +mlib = env['RAD_MLIB'] # compose paths -def radbin(name): return os.path.join(rt['RAD_BUILDBIN'], name) -def radlib(name): return os.path.join(rt['RAD_BUILDLIB'], name) +def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) +def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) # custom compile flags -dielectric = rt.Object(source='dielectric.c', - CCFLAGS=rt['CCFLAGS'] + ['-DDISPERSE']) -# custom C file generation -#rt.CFile(target='Version.c', source='VERSION', rt=build_radversion) +dielectric = env.Object(source='dielectric.c', + CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) +duphead = env.Object(source="duphead.c") +persist = env.Object(source="persist.c") +ambio = env.Object(source="ambio.c") + + # source and object dependencies -RAY = Split('''ambcomp.c ambient.c ambio.c freeobjmem.c - initotypes.c preload.c raytrace.c renderopts.c Version.c''') +RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c + raytrace.c renderopts.c''') + [ambio] -SURF = Split('''sphere.c source.c srcsupp.c virtuals.c o_face.c - srcsamp.c o_cone.c o_instance.c o_mesh.c''') +SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c + o_face.c o_cone.c o_instance.c o_mesh.c''') MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric] @@ -31,51 +34,59 @@ SUP = Split('func.c noise3.c data.c') # build libraries rsrc = RAY + SURF + MAT + MOD + SUP -rlib = rt.Library(target=radlib('radiance'), source=rsrc) +env.Command('Version.c', 'VERSION', vstamp.build_version_c) +env.Depends('Version.c', rsrc) +Version = env.Object(source=['Version.c']) +rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) if os.name == 'nt': # XXX until we get around fork() and friends rcsrc = Split('raycalls.c') else: rcsrc = Split('raycalls.c raypcalls.c') -rclib = rt.Library(target=radlib('raycalls'), source=rcsrc) +rclib = env.Library(target=radlib('raycalls'), source=rcsrc) Default(rclib) +fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror'] # build executables -lasrc = Split('lookamb.c ambio.c') -lookamb = rt.Program(target=radbin('lookamb'), source=lasrc) +lasrc = ['lookamb.c', ambio] +lookamb = env.Program(target=radbin('lookamb'), source=lasrc, + LIBS=['rtio', 'rtpic']) Default(lookamb) -env.Append(RAD_BININSTALL=[rt.Install(rt['RAD_BINDIR'], lookamb)]) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) -if os.name != 'nt': # XXX pending resolution of the free_os() conflict - rtmain = rt.Object(source='rtmain.c', - CCFLAGS=rt['CCFLAGS'] + ['-DNICE=4']) - rtsrc = Split('rtrace.c duphead.c persist.c') + [rtmain, rlib] - rtrace = rt.Program(target=radbin('rtrace'), source=rtsrc,) - Default(rtrace) - env.Append(RAD_BININSTALL=[rt.Install(rt['RAD_BINDIR'], rtrace)]) +rtmain = env.Object(source=['rtmain.c'], + CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) +rtsrc = ['rtrace.c', duphead, persist, rtmain] +rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, + LIBS=fullib + mlib + ) +Default(rtrace) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) - rpsrc = Split('rpmain.c rpict.c srcdraw.c duphead.c persist.c') + [rlib] - rpict = rt.Program(target=radbin('rpict'), source=rpsrc,) - Default(rpict) - env.Append(RAD_BININSTALL=[rt.Install(rt['RAD_BINDIR'], rpict)]) +rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] +rpict = env.Program(target=radbin('rpict'), source=rpsrc, + LIBS=fullib+['rtnet']+mlib) +Default(rpict) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)]) -if rt.has_key('X11LIB'): # lots of special requirements for rview - x11incls = [rt['X11INCLUDE']] + rt['CPPPATH'] - x11 = rt.Object(source='x11.c', CPPPATH=x11incls) - x11twind = rt.Object(source='x11twind.c', CPPPATH=x11incls) - rvmain = rt.Object(source='rvmain.c', - CCFLAGS=rt['CCFLAGS'] + ['-DNICE=6']) - rv3 = rt.Object(source='rv3.c', # XXX we should get rid of SPEED - CCFLAGS=rt['CCFLAGS'] + [rt.get('RAD_SPEED', '')]) +if env.has_key('X11LIB'): # lots of special requirements for rvu + x11incls = [env['X11INCLUDE']] + env['CPPPATH'] + x11 = env.Object(source='x11.c', CPPPATH=x11incls) + x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) + rvmain = env.Object(source='rvmain.c', + CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) + rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED + CCFLAGS=env['CCFLAGS'] + ['$RAD_SPEED'] + ) devsrc = Split('devtable.c devcomm.c colortab.c editline.c') rvobjs = [x11, x11twind, rv3, rvmain, rlib] rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs - rview = rt.Program(target=radbin('rview'), source=rvsrc, - LIBPATH=rt['LIBPATH'] + [rt['X11LIB']], - LIBS=rt['LIBS'] + ['X11']) - Default(rview) - env.Append(RAD_BININSTALL=[rt.Install(rt['RAD_BINDIR'], rview)]) + rvu = env.Program(target=radbin('rvu'), source=rvsrc, + LIBPATH=env['LIBPATH'] + [env['X11LIB']], + LIBS=fullib + ['X11'] + mlib) + Default(rvu) + env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) LIBFILES = Split('rayinit.cal') -env.Append(RAD_RLIBINSTALL=[rt.Install(rt['RAD_RLIBDIR'], LIBFILES)]) +env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
