root/radiance/ray/src/rt/SConscript
Mon Apr 21 07:31:30 2008 UTC (16 years ago) by schorsch
Changes since 1.9: +6 -5 lines
Diff to previous 1.9 , to selected 1.2
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (18 years, 7 months ago) by schorsch
Diff to previous 1.8 , to selected 1.2
Wed Sep 14 09:28:35 2005 UTC (18 years, 7 months ago) by schorsch
Diff to previous 1.7 , to selected 1.2
Fri Nov 5 22:15:43 2004 UTC (19 years, 6 months ago) by schorsch
Thu Oct 21 15:47:13 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.5: +10 -8 lines
SCons build simplifications.
Sun Jul 4 12:08:48 2004 UTC (19 years, 10 months ago) by schorsch
Changes since 1.4: +6 -4 lines
Thu Jan 1 20:54:46 2004 UTC (20 years, 4 months ago) by schorsch
Renamed rview to rvu.
Thu Jan 1 10:57:46 2004 UTC (20 years, 4 months ago) by schorsch
Diff to previous 1.2
Integrated new source occlusion testing routines into SCons build.
Mon Oct 27 10:35:43 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +47 -40 lines
Diff to previous 1.1
Tue Oct 21 19:27:29 2003 UTC (20 years, 6 months ago) by schorsch
Diff to selected 1.2
