root/radiance/ray/src/rt/SConscript
Revision: 1.6
Committed: Thu Oct 21 15:47:13 2004 UTC (20 years, 6 months ago) by schorsch
Changes since 1.5: +10 -8 lines
SCons build simplifications.
# User Rev Content
1 schorsch 1.1 import os
2 schorsch 1.5 from build_utils import vstamp
3 schorsch 1.1
4     Import('env') # inherit from parent
5
6 schorsch 1.2 mlib = env['RAD_MLIB']
7 schorsch 1.1
8     # compose paths
9 schorsch 1.2 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11 schorsch 1.1
12     # custom compile flags
13 schorsch 1.2 dielectric = env.Object(source='dielectric.c',
14     CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16     duphead = env.Object(source="duphead.c")
17     persist = env.Object(source="persist.c")
18     ambio = env.Object(source="ambio.c")
19
20 schorsch 1.1
21     # source and object dependencies
22 schorsch 1.2 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
23 schorsch 1.5 raytrace.c renderopts.c''') + [ambio]
24 schorsch 1.1
25 schorsch 1.3 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
26     o_face.c o_cone.c o_instance.c o_mesh.c''')
27 schorsch 1.1
28     MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
29     m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric]
30
31     MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
32
33     SUP = Split('func.c noise3.c data.c')
34
35     # build libraries
36     rsrc = RAY + SURF + MAT + MOD + SUP
37 schorsch 1.5 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
38     env.Depends('Version.c', rsrc)
39 schorsch 1.6 Version = env.Object(source=['Version.c'])
40 schorsch 1.5 rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
41 schorsch 1.1
42     if os.name == 'nt': # XXX until we get around fork() and friends
43     rcsrc = Split('raycalls.c')
44     else: rcsrc = Split('raycalls.c raypcalls.c')
45 schorsch 1.2 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
46 schorsch 1.1 Default(rclib)
47
48 schorsch 1.2 fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror']
49 schorsch 1.1 # build executables
50 schorsch 1.2 lasrc = ['lookamb.c', ambio]
51     lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
52     LIBS=['rtio', 'rtpic'])
53 schorsch 1.1 Default(lookamb)
54 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)])
55 schorsch 1.1
56 schorsch 1.2 rtmain = env.Object(source=['rtmain.c'],
57     CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
58     rtsrc = ['rtrace.c', duphead, persist, rtmain]
59     rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
60 schorsch 1.6 LIBS=fullib + mlib
61     )
62 schorsch 1.2 Default(rtrace)
63 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)])
64 schorsch 1.2
65     rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
66     rpict = env.Program(target=radbin('rpict'), source=rpsrc,
67     LIBS=fullib+['rtnet']+mlib)
68     Default(rpict)
69 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)])
70 schorsch 1.2
71 schorsch 1.4 if env.has_key('X11LIB'): # lots of special requirements for rvu
72 schorsch 1.2 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
73     x11 = env.Object(source='x11.c', CPPPATH=x11incls)
74     x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
75     rvmain = env.Object(source='rvmain.c',
76     CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
77     rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED
78 schorsch 1.6 CCFLAGS=env['CCFLAGS'] + ['$RAD_SPEED']
79     )
80 schorsch 1.1
81     devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
82     rvobjs = [x11, x11twind, rv3, rvmain, rlib]
83     rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
84 schorsch 1.4 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
85 schorsch 1.2 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
86     LIBS=fullib + ['X11'] + mlib)
87 schorsch 1.4 Default(rvu)
88 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
89 schorsch 1.1
90     LIBFILES = Split('rayinit.cal')
91 schorsch 1.6 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
92 schorsch 1.1
