--- ray/src/rt/SConscript 2004/01/01 20:54:46 1.4 +++ ray/src/rt/SConscript 2018/01/09 00:08:57 1.20 @@ -1,4 +1,7 @@ +from __future__ import division, print_function, unicode_literals + import os +from build_utils import vstamp Import('env') # inherit from parent @@ -11,78 +14,106 @@ def radlib(name): return os.path.join(env['RAD_BUILDLI # custom compile flags dielectric = env.Object(source='dielectric.c', CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE']) -# custom C file generation -#env.CFile(target='Version.c', source='VERSION', env=build_radversion) duphead = env.Object(source="duphead.c") persist = env.Object(source="persist.c") ambio = env.Object(source="ambio.c") +rayfifo = env.Object(source="rayfifo.c") +raypwin = env.Object(source="raypwin.c") +raycalls = env.Object(source="raycalls.c") +CCFLAGS = env.get('CCFLAGS',[]) +if env.get('PMAP_OOC', 0) not in (0,'0','','n','no','false',False,None): + PMD = Split('ooccache.c oocnn.c oocmorton.c oococt.c oocsort.c oocbuild.c') + OOC_CCFLAGS = env.get('CCFLAGS',[]) + ['-DPMAP_OOC'] + for src in Split('''pmapdata.c pmapio.c pmapopt.c '''): + obj = env.Object(source=src, CCFLAGS=OOC_CCFLAGS) + PMD.append(obj) + pmaptype = env.Object(source="pmaptype.c", CCFLAGS=OOC_CCFLAGS) + pmapparm = env.Object(source="pmapparm.c", CCFLAGS=OOC_CCFLAGS) +else: + PMD = Split('''pmapdata.c pmapio.c pmapopt.c ''') + OOC_CCFLAGS = env.get('CCFLAGS',[]) + pmaptype = env.Object(source="pmaptype.c") + pmapparm = env.Object(source="pmapparm.c") # source and object dependencies RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c - raytrace.c renderopts.c Version.c''') + [ambio] - + raytrace.c renderopts.c''') + [ambio] +PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c + pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapdiag.c + pmcontrib2.c pmutil.c + ''') + [pmaptype, pmapparm] SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c o_face.c o_cone.c o_instance.c o_mesh.c''') - MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c - m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric] - + m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' + ) + [dielectric] MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') - SUP = Split('func.c noise3.c data.c') # build libraries -rsrc = RAY + SURF + MAT + MOD + SUP -rlib = env.Library(target=radlib('rttrace'), source=rsrc) +rsrc = RAY + PMAP + PMD + SURF + MAT + MOD + SUP +env.Command('Version.c', 'VERSION', vstamp.build_version_c) +env.Depends('Version.c', rsrc) +Version = env.Object(source=['Version.c']) +env.version = Version # make it remotely accessible +tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) -if os.name == 'nt': # XXX until we get around fork() and friends - rcsrc = Split('raycalls.c') -else: rcsrc = Split('raycalls.c raypcalls.c') -rclib = env.Library(target=radlib('raycalls'), source=rcsrc) +rclib = env.Library(target=radlib('raycalls'), + source=Split('raycalls.c $RAD_PCALLS')) Default(rclib) -fullib=['rttrace','rtscene','rtpic','rtfunc','rtproc','rtio','rtmath','rtargs','rtpath','rtcont','rtmem','rterror'] -# build executables -lasrc = ['lookamb.c', ambio] -lookamb = env.Program(target=radbin('lookamb'), source=lasrc, - LIBS=['rtio', 'rtpic']) -Default(lookamb) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], lookamb)]) - rtmain = env.Object(source=['rtmain.c'], CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) -rtsrc = ['rtrace.c', duphead, persist, rtmain] -rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, - LIBS=fullib + ['rtproc'] + mlib) # rtproc for win_nice() -Default(rtrace) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rtrace)]) -rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist] -rpict = env.Program(target=radbin('rpict'), source=rpsrc, - LIBS=fullib+['rtnet']+mlib) -Default(rpict) -env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rpict)]) +# build executables +PROGS = [ +('mkpmap', ['mkpmap.c', Version], CCFLAGS, + ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]), +('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version], OOC_CCFLAGS, + ['rtrad', '$RAD_SOCKETLIB', mlib]), +('lookamb', ['lookamb.c', ambio], CCFLAGS, ['rtrad', mlib]), +('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], CCFLAGS, + ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]), +('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls], + CCFLAGS, ['rttrace', 'rtrad'] + mlib), +('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist], CCFLAGS, + ['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib), +] +for p in PROGS: + prog = env.Program(target=radbin(p[0]), source = p[1], + CCFLAGS = p[2], LIBS = p[3]), + Default(prog) + env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)]) +# we need RVOBJS for any derived viewers, such as winrview +if os.name == 'nt': RV_DEF = ['WIN_RVIEW'] +else: RV_DEF = [] +rvmain = env.Object(source='rvmain.c', + CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) +rvobjs = [rvmain] +for src in Split('''rview.c rv2.c rv3.c + devtable.c devcomm.c colortab.c editline.c'''): + rvobjs.append(env.Object(source=src, + CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF)) +env['RVOBJS'] = rvobjs + if env.has_key('X11LIB'): # lots of special requirements for rvu x11incls = [env['X11INCLUDE']] + env['CPPPATH'] x11 = env.Object(source='x11.c', CPPPATH=x11incls) x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls) - rvmain = env.Object(source='rvmain.c', - CCFLAGS=env['CCFLAGS'] + ['-DNICE=6']) - rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED - CCFLAGS=env['CCFLAGS'] + [env.get('RAD_SPEED', '')]) - - devsrc = Split('devtable.c devcomm.c colortab.c editline.c') - rvobjs = [x11, x11twind, rv3, rvmain, rlib] - rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs + rvxobjs = [x11, x11twind] + rvsrc = rvobjs + rvxobjs rvu = env.Program(target=radbin('rvu'), source=rvsrc, LIBPATH=env['LIBPATH'] + [env['X11LIB']], - LIBS=fullib + ['X11'] + mlib) + LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib) + ) Default(rvu) - env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], rvu)]) + env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)]) LIBFILES = Split('rayinit.cal') -env.Append(RAD_RLIBINSTALL=[env.Install(env['RAD_RLIBDIR'], LIBFILES)]) +env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) +# vim: set syntax=python: +# vi: set ts=4 sw=4 :
