--- ray/src/rt/SConscript 2011/04/15 21:52:16 1.14 +++ ray/src/rt/SConscript 2016/03/05 13:24:58 1.16 @@ -19,27 +19,34 @@ ambio = env.Object(source="ambio.c") rayfifo = env.Object(source="rayfifo.c") raypwin = env.Object(source="raypwin.c") raycalls = env.Object(source="raycalls.c") +pmaptype = env.Object(source="pmaptype.c") +pmapparm = env.Object(source="pmapparm.c") # source and object dependencies RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c raytrace.c renderopts.c''') + [ambio] +PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c + pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c pmapdiag.c ''' + ) + [pmaptype, pmapparm] SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c o_face.c o_cone.c o_instance.c o_mesh.c''') MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c - m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c''') + [dielectric] + m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c ''' + ) + [dielectric] MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c') SUP = Split('func.c noise3.c data.c') # build libraries -rsrc = RAY + SURF + MAT + MOD + SUP +rsrc = RAY + PMAP + SURF + MAT + MOD + SUP env.Command('Version.c', 'VERSION', vstamp.build_version_c) env.Depends('Version.c', rsrc) Version = env.Object(source=['Version.c']) +env.version = Version # make it remotely accessible rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version]) #if os.name == 'nt': # XXX until we get around fork() and friends @@ -52,17 +59,39 @@ Default(rclib) fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror'] # build executables +mkpmap = env.Program(target=radbin('mkpmap'), + source = Split('mkpmap.c') + [Version], + LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]), +Default(mkpmap) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', mkpmap)]) + +pmapdump = env.Program(target=radbin('pmapdump'), + source = Split('pmapdump.c') + [pmaptype, pmapparm, Version], + LIBS= fullib + ['$RAD_SOCKETLIB', mlib]), +Default(pmapdump) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', pmapdump)]) + lasrc = ['lookamb.c', ambio] lookamb = env.Program(target=radbin('lookamb'), source=lasrc, - LIBS=['rtio', 'rtpic']) + LIBS=['rtio', 'rtpic', 'rtmath', mlib]) Default(lookamb) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)]) +rcontrib = env.Program(target=radbin('rcontrib'), + source = Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], + LIBS= fullib + ['rtnet', '$RAD_SOCKETLIB', mlib]), +# LIBS= ['rttrace','rtscene','rtpic','rtargs','rtfunc','rtio', +# 'rtproc','rtcont', +# 'rtmem', 'rtpath', 'rtmath','rtnet','rterror','$RAD_SOCKETLIB',mlib]), +Default(rcontrib) +env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rcontrib)]) + + rtmain = env.Object(source=['rtmain.c'], CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4']) rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls] rtrace = env.Program(target=radbin('rtrace'), source=rtsrc, - LIBS=fullib + mlib + LIBS=fullib + ['rtnet'] + mlib ) Default(rtrace) env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)]) @@ -88,7 +117,7 @@ if env.has_key('X11LIB'): # lots of special requiremen rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs rvu = env.Program(target=radbin('rvu'), source=rvsrc, LIBPATH=env['LIBPATH'] + [env['X11LIB']], - LIBS = (['rtscene', rclib, 'rttrace', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', + LIBS = (['rtscene', rclib, 'rttrace', 'rtnet', 'rtpic', 'rtfunc', 'rtproc', 'rtmath', 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror', 'X11'] + mlib) #LIBS=fullib + ['X11', rclib] + mlib @@ -99,3 +128,4 @@ if env.has_key('X11LIB'): # lots of special requiremen LIBFILES = Split('rayinit.cal') env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)]) +# vim: set syntax=python:
