root/Development/ray/src/rt/SConscript
Tue Jan 9 00:08:57 2018 UTC (7 years, 8 months ago) by schorsch
Changes since 1.19: +26 -15 lines
Diff to previous 1.19 , to selected 1.13
SCons Option to build Pmap with OOC data on unix
Mon Jan 8 13:38:37 2018 UTC (7 years, 8 months ago) by schorsch
Changes since 1.18: +8 -2 lines
Diff to previous 1.18 , to selected 1.13
Fri Mar 18 22:58:46 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.17: +14 -10 lines
Diff to previous 1.17 , to selected 1.13
create a seperate grouping for the files needed by rvu display drivers
Thu Mar 10 21:43:23 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.16: +23 -56 lines
Diff to previous 1.16 , to selected 1.13
Sat Mar 5 13:24:58 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.15: +22 -5 lines
Diff to previous 1.15 , to selected 1.13
Sat Mar 5 00:29:28 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.14: +18 -5 lines
Diff to previous 1.14 , to selected 1.13
update SCons
Fri Apr 15 21:52:16 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 1.13
SCONS fixes for latest build
Revision 1.13 - (view) (download) (annotate) - [selected]
Wed Jun 2 15:58:30 2010 UTC (15 years, 4 months ago) by greg
Diff to previous 1.12
Fixes to MINGW build
Thu May 27 19:32:13 2010 UTC (15 years, 4 months ago) by greg
Diff to previous 1.11 , to selected 1.13
Tue Dec 23 15:04:01 2008 UTC (16 years, 9 months ago) by schorsch
Changes since 1.10: +5 -1 lines
Diff to previous 1.10 , to selected 1.13
Mon Apr 21 07:31:30 2008 UTC (17 years, 5 months ago) by schorsch
Changes since 1.9: +6 -5 lines
Diff to previous 1.9 , to selected 1.13
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (20 years ago) by schorsch
Diff to previous 1.8 , to selected 1.13
Wed Sep 14 09:28:35 2005 UTC (20 years ago) by schorsch
Diff to previous 1.7 , to selected 1.13
Fri Nov 5 22:15:43 2004 UTC (20 years, 10 months ago) by schorsch
Diff to previous 1.6 , to selected 1.13
Thu Oct 21 15:47:13 2004 UTC (20 years, 11 months ago) by schorsch
Changes since 1.5: +10 -8 lines
Diff to previous 1.5 , to selected 1.13
SCons build simplifications.
Sun Jul 4 12:08:48 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 1.4: +6 -4 lines
Diff to previous 1.4 , to selected 1.13
Thu Jan 1 20:54:46 2004 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.3 , to selected 1.13
Renamed rview to rvu.
Thu Jan 1 10:57:46 2004 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.2 , to selected 1.13
Integrated new source occlusion testing routines into SCons build.
Mon Oct 27 10:35:43 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.1: +47 -40 lines
Diff to previous 1.1 , to selected 1.13
Tue Oct 21 19:27:29 2003 UTC (21 years, 11 months ago) by schorsch
Diff to selected 1.13
