root/radiance/ray/src/rt/SConscript
Revision: 1.20
Committed: Tue Jan 9 00:08:57 2018 UTC (7 years, 4 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 1.19: +26 -15 lines
SCons Option to build Pmap with OOC data on unix
# User Rev Content
1 schorsch 1.19 from __future__ import division, print_function, unicode_literals
2
3 schorsch 1.1 import os
4 schorsch 1.5 from build_utils import vstamp
5 schorsch 1.1
6     Import('env') # inherit from parent
7
8 schorsch 1.2 mlib = env['RAD_MLIB']
9 schorsch 1.1
10     # compose paths
11 schorsch 1.2 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
12     def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
13 schorsch 1.1
14     # custom compile flags
15 schorsch 1.2 dielectric = env.Object(source='dielectric.c',
16     CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
17
18     duphead = env.Object(source="duphead.c")
19     persist = env.Object(source="persist.c")
20     ambio = env.Object(source="ambio.c")
21 greg 1.12 rayfifo = env.Object(source="rayfifo.c")
22     raypwin = env.Object(source="raypwin.c")
23 greg 1.13 raycalls = env.Object(source="raycalls.c")
24 schorsch 1.2
25 schorsch 1.20 CCFLAGS = env.get('CCFLAGS',[])
26     if env.get('PMAP_OOC', 0) not in (0,'0','','n','no','false',False,None):
27     PMD = Split('ooccache.c oocnn.c oocmorton.c oococt.c oocsort.c oocbuild.c')
28     OOC_CCFLAGS = env.get('CCFLAGS',[]) + ['-DPMAP_OOC']
29     for src in Split('''pmapdata.c pmapio.c pmapopt.c '''):
30     obj = env.Object(source=src, CCFLAGS=OOC_CCFLAGS)
31     PMD.append(obj)
32     pmaptype = env.Object(source="pmaptype.c", CCFLAGS=OOC_CCFLAGS)
33     pmapparm = env.Object(source="pmapparm.c", CCFLAGS=OOC_CCFLAGS)
34     else:
35     PMD = Split('''pmapdata.c pmapio.c pmapopt.c ''')
36     OOC_CCFLAGS = env.get('CCFLAGS',[])
37     pmaptype = env.Object(source="pmaptype.c")
38     pmapparm = env.Object(source="pmapparm.c")
39 schorsch 1.1
40     # source and object dependencies
41 schorsch 1.2 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
42 schorsch 1.5 raytrace.c renderopts.c''') + [ambio]
43 schorsch 1.20 PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c
44     pmapbias.c pmapcontrib.c pmapamb.c pmapray.c pmapdiag.c
45     pmcontrib2.c pmutil.c
46 schorsch 1.19 ''') + [pmaptype, pmapparm]
47 schorsch 1.3 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
48     o_face.c o_cone.c o_instance.c o_mesh.c''')
49 schorsch 1.1 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
50 schorsch 1.15 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c '''
51     ) + [dielectric]
52 schorsch 1.1 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
53     SUP = Split('func.c noise3.c data.c')
54
55     # build libraries
56 schorsch 1.20 rsrc = RAY + PMAP + PMD + SURF + MAT + MOD + SUP
57 schorsch 1.5 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
58     env.Depends('Version.c', rsrc)
59 schorsch 1.6 Version = env.Object(source=['Version.c'])
60 schorsch 1.16 env.version = Version # make it remotely accessible
61 schorsch 1.18 tracelib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
62 schorsch 1.1
63 schorsch 1.17 rclib = env.Library(target=radlib('raycalls'),
64     source=Split('raycalls.c $RAD_PCALLS'))
65 schorsch 1.1 Default(rclib)
66
67 schorsch 1.17 rtmain = env.Object(source=['rtmain.c'],
68     CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
69
70 schorsch 1.1 # build executables
71 schorsch 1.17 PROGS = [
72 schorsch 1.20 ('mkpmap', ['mkpmap.c', Version], CCFLAGS,
73 schorsch 1.17 ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
74 schorsch 1.20 ('pmapdump', ['pmapdump.c', pmaptype, pmapparm, Version], OOC_CCFLAGS,
75 schorsch 1.17 ['rtrad', '$RAD_SOCKETLIB', mlib]),
76 schorsch 1.20 ('lookamb', ['lookamb.c', ambio], CCFLAGS, ['rtrad', mlib]),
77     ('rcontrib', Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version], CCFLAGS,
78 schorsch 1.17 ['rttrace', 'rtrad', '$RAD_SOCKETLIB', mlib]),
79     ('rtrace', ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls],
80 schorsch 1.20 CCFLAGS, ['rttrace', 'rtrad'] + mlib),
81     ('rpict', Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist], CCFLAGS,
82 schorsch 1.17 ['rttrace', 'rtrad', '$RAD_SOCKETLIB']+mlib),
83     ]
84     for p in PROGS:
85 schorsch 1.20 prog = env.Program(target=radbin(p[0]), source = p[1],
86     CCFLAGS = p[2], LIBS = p[3]),
87 schorsch 1.17 Default(prog)
88     env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', prog)])
89 schorsch 1.15
90 schorsch 1.18 # we need RVOBJS for any derived viewers, such as winrview
91     if os.name == 'nt': RV_DEF = ['WIN_RVIEW']
92     else: RV_DEF = []
93     rvmain = env.Object(source='rvmain.c',
94     CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
95     rvobjs = [rvmain]
96     for src in Split('''rview.c rv2.c rv3.c
97     devtable.c devcomm.c colortab.c editline.c'''):
98     rvobjs.append(env.Object(source=src,
99     CPPDEFINES=env.get('CPPDEFINES', []) + RV_DEF))
100     env['RVOBJS'] = rvobjs
101 schorsch 1.2
102 schorsch 1.4 if env.has_key('X11LIB'): # lots of special requirements for rvu
103 schorsch 1.2 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
104     x11 = env.Object(source='x11.c', CPPPATH=x11incls)
105     x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
106 schorsch 1.18 rvxobjs = [x11, x11twind]
107     rvsrc = rvobjs + rvxobjs
108 schorsch 1.4 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
109 schorsch 1.2 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
110 schorsch 1.17 LIBS = ([rclib, 'rttrace', 'rtrad', 'X11'] + mlib)
111 schorsch 1.11 )
112 schorsch 1.4 Default(rvu)
113 schorsch 1.6 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
114 schorsch 1.1
115     LIBFILES = Split('rayinit.cal')
116 schorsch 1.6 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
117 schorsch 1.1
118 schorsch 1.16 # vim: set syntax=python:
119 schorsch 1.19 # vi: set ts=4 sw=4 :
