root/Development/ray/src/rt/SConscript
Revision: 1.8
Committed: Wed Sep 14 09:28:35 2005 UTC (20 years, 1 month ago) by schorsch
1 import os
2 from build_utils import vstamp
3
4 Import('env') # inherit from parent
5
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11
12 # custom compile flags
13 dielectric = env.Object(source='dielectric.c',
14 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16 duphead = env.Object(source="duphead.c")
17 persist = env.Object(source="persist.c")
18 ambio = env.Object(source="ambio.c")
19
20
21 # source and object dependencies
22 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
23 raytrace.c renderopts.c''') + [ambio]
24
25 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
26 o_face.c o_cone.c o_instance.c o_mesh.c''')
27
28 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
29 m_direct.c m_mist.c fprism.c m_alias.c''') + [dielectric]
30
31 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
32
33 SUP = Split('func.c noise3.c data.c')
34
35 # build libraries
36 rsrc = RAY + SURF + MAT + MOD + SUP
37 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
38 env.Depends('Version.c', rsrc)
39 Version = env.Object(source=['Version.c'])
40 rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
41
42 if os.name == 'nt': # XXX until we get around fork() and friends
43 rcsrc = Split('raycalls.c')
44 else: rcsrc = Split('raycalls.c raypcalls.c')
45 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
46 Default(rclib)
47
48 fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtio', 'rtmath',
49 'rtargs', 'rtpath', 'rtcont', 'rtmem', 'rterror']
50 # build executables
51 lasrc = ['lookamb.c', ambio]
52 lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
53 LIBS=['rtio', 'rtpic'])
54 Default(lookamb)
55 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)])
56
57 rtmain = env.Object(source=['rtmain.c'],
58 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
59 rtsrc = ['rtrace.c', duphead, persist, rtmain]
60 rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
61 LIBS=fullib + mlib
62 )
63 Default(rtrace)
64 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)])
65
66 rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
67 rpict = env.Program(target=radbin('rpict'), source=rpsrc,
68 LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib)
69 Default(rpict)
70 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)])
71
72 if env.has_key('X11LIB'): # lots of special requirements for rvu
73 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
74 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
75 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
76 rvmain = env.Object(source='rvmain.c',
77 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
78 rv3 = env.Object(source='rv3.c', # XXX we should get rid of SPEED
79 CCFLAGS=env['CCFLAGS'] + ['$RAD_SPEED']
80 )
81
82 devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
83 rvobjs = [x11, x11twind, rv3, rvmain, rlib]
84 rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
85 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
86 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
87 LIBS=fullib + ['X11'] + mlib)
88 Default(rvu)
89 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
90
91 LIBFILES = Split('rayinit.cal')
92 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
93
