root/radiance/ray/src/rt/RtraceSimulManager.h
Revision: 2.10
Committed: Sat Aug 3 15:38:06 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.9: +5 -4 lines
feat(rxtrace): Added command-line for octree in lieu of header
1 /* RCSid $Id: RtraceSimulManager.h,v 2.9 2024/08/03 01:54:46 greg Exp $ */
2 /*
3 * RtraceSimulManager.h
4 *
5 * Rtrace simulation manager class declaration (along with base class)
6 * Enqueuing rays will block caller iff #rays >= ThreadsAvail()
7 * Reporting call-backs made from EnqueBundle() and FlushQueue()
8 *
9 * Created by Greg Ward on 11/10/22.
10 */
11
12 #ifndef RtraceSimulManager_h
13 #define RtraceSimulManager_h
14
15 #include "ray.h"
16
17 extern char * octname; // global octree name
18
19 extern int castonly; // doing ray-casting only?
20
21 /// Ray reporting callback method -- returns # successfully reported, -1 to abort
22 typedef int RayReportCall(RAY *r, void *cd);
23
24 /// Multi-threaded simulation manager base class
25 class RadSimulManager {
26 char * header; // header (less intro and format)
27 int hlen; // header string length
28 protected:
29 // Assign ray to subthread (fails if NThreads()<2)
30 bool SplitRay(RAY *r);
31 public:
32 RadSimulManager(const char *octn = NULL) {
33 header = NULL; hlen = 0;
34 LoadOctree(octn);
35 }
36 ~RadSimulManager() {
37 Cleanup();
38 }
39 /// Load octree and prepare renderer
40 bool LoadOctree(const char *octn);
41 /// Prepare header from previous input (or clear)
42 /// Normally called during octree load
43 bool NewHeader(const char *inspec=NULL);
44 /// Add a line to header (adds newline if none)
45 bool AddHeader(const char *str);
46 /// Append program line to header
47 bool AddHeader(int ac, const char *av[]);
48 /// Get header lines if any
49 const char * GetHeader() const {
50 return header;
51 }
52 /// How many cores are available?
53 static int GetNCores();
54 /// Set number of computation threads (0 => #cores)
55 int SetThreadCount(int nt = 0);
56 /// Check thread count (1 means no multi-threading)
57 int NThreads() const {
58 return ray_pnprocs + !ray_pnprocs;
59 }
60 /// How many threads are currently unoccupied?
61 int ThreadsAvailable() const;
62 /// Are we ready?
63 bool Ready() const {
64 return (octname && nobjects > 0);
65 }
66 /// Process a ray (in subthread), optional result
67 bool ProcessRay(RAY *r);
68 /// Wait for next result (or fail)
69 bool WaitResult(RAY *r);
70 /// Close octree, free data, return status
71 int Cleanup(bool everything = false);
72 };
73
74 /// Flags to control rendering operations
75 enum {RTdoFIFO=1, RTtraceSources=2, RTlimDist=4, RTimmIrrad=8, RTmask=15};
76
77 /// rtrace-like simulation manager (at most one such object)
78 class RtraceSimulManager : public RadSimulManager {
79 RayReportCall * cookedCall; // callback for cooked primary rays
80 void * ccData; // client data for cooked primary rays
81 RayReportCall * traceCall; // call for every ray in tree
82 void * tcData; // client data for traced rays
83 int curFlags; // current operating flags
84 // Call-back for global ray-tracing context
85 static void RTracer(RAY *r);
86 // Call-back for FIFO
87 static int Rfifout(RAY *r);
88 // Check for changes to render flags, etc.
89 bool UpdateMode();
90 protected:
91 RNUMBER lastRayID; // last ray ID assigned
92 public:
93 int rtFlags; // operation (RT*) flags
94 RtraceSimulManager(RayReportCall *cb = NULL, void *cd = NULL,
95 const char *octn = NULL) : RadSimulManager(octn) {
96 lastRayID = 0;
97 rtFlags = curFlags = 0;
98 SetCookedCall(cb, cd);
99 traceCall = NULL; tcData = NULL;
100 }
101 ~RtraceSimulManager() {
102 FlushQueue();
103 }
104 /// Set number of computation threads (0 => #cores)
105 int SetThreadCount(int nt = 0) {
106 if (nt <= 0) nt = castonly ? 1 : GetNCores();
107 if (nt == NThreads()) return nt;
108 if (FlushQueue() < 0) return 0;
109 return RadSimulManager::SetThreadCount(nt);
110 }
111 /// Add ray bundle to queue w/ optional 1st ray ID
112 int EnqueueBundle(const FVECT orig_direc[], int n,
113 RNUMBER rID0 = 0);
114 /// Enqueue a single ray w/ optional ray ID
115 bool EnqueueRay(const FVECT org, const FVECT dir,
116 RNUMBER rID = 0) {
117 if (dir == org+1)
118 return(EnqueueBundle((const FVECT *)org, 1, rID) > 0);
119 FVECT orgdir[2];
120 VCOPY(orgdir[0], org); VCOPY(orgdir[1], dir);
121 return(EnqueueBundle(orgdir, 1, rID) > 0);
122 }
123 /// Set/change cooked ray callback
124 void SetCookedCall(RayReportCall *cb, void *cd = NULL) {
125 if (cookedCall && (cookedCall != cb) | (ccData != cd))
126 FlushQueue();
127 cookedCall = cb;
128 ccData = cb ? cd : NULL;
129 }
130 /// Set/change trace callback
131 void SetTraceCall(RayReportCall *cb, void *cd = NULL) {
132 traceCall = cb;
133 tcData = cb ? cd : NULL;
134 }
135 /// Are we ready?
136 bool Ready() const {
137 return (cookedCall != NULL) | (traceCall != NULL) &&
138 RadSimulManager::Ready();
139 }
140 /// Finish pending rays and complete callbacks (return #sent)
141 int FlushQueue();
142 /// Close octree, free data, return status
143 int Cleanup(bool everything = false) {
144 SetCookedCall(NULL);
145 SetTraceCall(NULL);
146 rtFlags = 0;
147 UpdateMode();
148 lastRayID = 0;
149 return RadSimulManager::Cleanup(everything);
150 }
151 };
152
153 /// Determine if vector is all zeroes
154 inline bool
155 IsZeroVec(const FVECT vec)
156 {
157 return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0);
158 }
159
160 #endif /* RtraceSimulManager_h */
