root/radiance/ray/src/rt/RtraceSimulManager.h
Revision: 2.8
Committed: Thu May 2 22:10:43 2024 UTC (15 months ago) by greg
fix(rxtrace): Minor fixes
1 /* RCSid $Id: RtraceSimulManager.h,v 2.7 2024/05/01 22:06:09 greg Exp $ */
2 /*
3 * RtraceSimulManager.h
4 *
5 * Rtrace simulation manager class declaration (along with base class)
6 * Enqueuing rays will block caller iff #rays >= ThreadsAvail()
7 * Reporting call-backs made from EnqueBundle() and FlushQueue()
8 *
9 * Created by Greg Ward on 11/10/22.
10 */
11
12 #ifndef RtraceSimulManager_h
13 #define RtraceSimulManager_h
14
15 #include "ray.h"
16
17 extern char * octname; // global octree name
18
19 extern int castonly; // doing ray-casting only?
20
21 /// Ray reporting callback method -- returns # successfully reported, -1 to abort
22 typedef int RayReportCall(RAY *r, void *cd);
23
24 /// Multi-threaded simulation manager base class
25 class RadSimulManager {
26 protected:
27 // Assign ray to subthread (fails if NThreads()<2)
28 bool SplitRay(RAY *r);
29 public:
30 RadSimulManager(const char *octn = NULL) {
31 LoadOctree(octn);
32 }
33 ~RadSimulManager() {
34 Cleanup();
35 }
36 /// Load octree and prepare renderer
37 bool LoadOctree(const char *octn);
38 /// How many cores are available?
39 static int GetNCores();
40 /// Set number of computation threads (0 => #cores)
41 int SetThreadCount(int nt = 0);
42 /// Check thread count (1 means no multi-threading)
43 int NThreads() const {
44 return ray_pnprocs + !ray_pnprocs;
45 }
46 /// How many threads are currently unoccupied?
47 int ThreadsAvailable() const;
48 /// Are we ready?
49 bool Ready() const {
50 return (octname && nobjects > 0);
51 }
52 /// Process a ray (in subthread), optional result
53 bool ProcessRay(RAY *r);
54 /// Wait for next result (or fail)
55 bool WaitResult(RAY *r);
56 /// Close octree, free data, return status
57 int Cleanup(bool everything = false);
58 };
59
60 /// Flags to control rendering operations
61 enum {RTdoFIFO=1, RTtraceSources=2, RTlimDist=4, RTimmIrrad=8, RTmask=15};
62
63 /// rtrace-like simulation manager (at most one such object)
64 class RtraceSimulManager : public RadSimulManager {
65 RayReportCall * cookedCall; // callback for cooked primary rays
66 void * ccData; // client data for cooked primary rays
67 RayReportCall * traceCall; // call for every ray in tree
68 void * tcData; // client data for traced rays
69 int curFlags; // current operating flags
70 // Call-back for global ray-tracing context
71 static void RTracer(RAY *r);
72 // Call-back for FIFO
73 static int Rfifout(RAY *r);
74 // Check for changes to render flags, etc.
75 bool UpdateMode();
76 protected:
77 RNUMBER lastRayID; // last ray ID assigned
78 public:
79 int rtFlags; // operation (RT*) flags
80 RtraceSimulManager(RayReportCall *cb = NULL, void *cd = NULL,
81 const char *octn = NULL) : RadSimulManager(octn) {
82 lastRayID = 0;
83 rtFlags = curFlags = 0;
84 SetCookedCall(cb, cd);
85 traceCall = NULL; tcData = NULL;
86 }
87 ~RtraceSimulManager() {
88 FlushQueue();
89 }
90 /// Set number of computation threads (0 => #cores)
91 int SetThreadCount(int nt = 0) {
92 if (nt <= 0) nt = castonly ? 1 : GetNCores();
93 if (nt == NThreads()) return nt;
94 if (FlushQueue() < 0) return 0;
95 return RadSimulManager::SetThreadCount(nt);
96 }
97 /// Add ray bundle to queue w/ optional 1st ray ID
98 int EnqueueBundle(const FVECT orig_direc[], int n,
99 RNUMBER rID0 = 0);
100 /// Enqueue a single ray w/ optional ray ID
101 bool EnqueueRay(const FVECT org, const FVECT dir,
102 RNUMBER rID = 0) {
103 if (dir == org+1)
104 return(EnqueueBundle((const FVECT *)org, 1, rID) > 0);
105 FVECT orgdir[2];
106 VCOPY(orgdir[0], org); VCOPY(orgdir[1], dir);
107 return(EnqueueBundle(orgdir, 1, rID) > 0);
108 }
109 /// Set/change cooked ray callback
110 void SetCookedCall(RayReportCall *cb, void *cd = NULL) {
111 if (cookedCall && (cookedCall != cb) | (ccData != cd))
112 FlushQueue();
113 cookedCall = cb;
114 ccData = cb ? cd : NULL;
115 }
116 /// Set/change trace callback
117 void SetTraceCall(RayReportCall *cb, void *cd = NULL) {
118 traceCall = cb;
119 tcData = cb ? cd : NULL;
120 }
121 /// Are we ready?
122 bool Ready() const {
123 return (cookedCall != NULL) | (traceCall != NULL) &&
124 RadSimulManager::Ready();
125 }
126 /// Finish pending rays and complete callbacks (return #sent)
127 int FlushQueue();
128 /// Close octree, free data, return status
129 int Cleanup(bool everything = false) {
130 SetCookedCall(NULL);
131 SetTraceCall(NULL);
132 rtFlags = 0;
133 UpdateMode();
134 lastRayID = 0;
135 return RadSimulManager::Cleanup(everything);
136 }
137 };
138
139 /// Determine if vector is all zeroes
140 inline bool
141 IsZeroVec(const FVECT vec)
142 {
143 return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0);
144 }
145
146 #endif /* RtraceSimulManager_h */
