root/radiance/ray/src/rt/RtraceSimulManager.h
Thu Jan 9 17:25:37 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.21 , to selected 2.11
fix(rxpiece,rxpict): Make sure child processes are waited for
Thu Jan 2 16:16:49 2025 UTC (7 months ago) by greg
Changes since 2.20: +21 -7 lines
Diff to previous 2.20 , to selected 2.11
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
Mon Dec 16 20:18:36 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 2.19: +2 -6 lines
Diff to previous 2.19 , to selected 2.11
fix: Class wasn't updating trace mode for multiprocessing
Tue Nov 19 20:50:36 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.18: +2 -5 lines
fix: Improved last change for case of same callback with different data
Tue Nov 19 20:39:40 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.17: +9 -2 lines
feat: Allow trace call to be changed when children are running
Wed Nov 13 02:43:51 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.16: +10 -7 lines
feat: Improved error-handling in base simulation manager classes
Wed Oct 23 23:40:41 2024 UTC (9 months, 1 week ago) by greg
feat: Added GetHeadLen() method for efficiency
Thu Oct 10 21:02:52 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.14: +5 -3 lines
fix: Allow unsetting of source-ray tracing flag
Mon Sep 16 19:18:32 2024 UTC (10 months, 2 weeks ago) by greg
feat: Added method to get a specific string from header
Wed Aug 14 20:05:23 2024 UTC (11 months, 3 weeks ago) by greg
Mon Aug 5 19:51:18 2024 UTC (12 months ago) by greg
perf(rxtrace): Eliminated unnecessary queue flushing when adding processes
Sat Aug 3 21:33:15 2024 UTC (12 months ago) by greg
feat(rxtrace): changed GetHeader() to return empty string if no header
Sat Aug 3 15:38:06 2024 UTC (12 months ago) by greg
Changes since 2.9: +5 -4 lines
feat(rxtrace): Added command-line for octree in lieu of header
Sat Aug 3 01:54:46 2024 UTC (12 months ago) by greg
Changes since 2.8: +14 -1 lines
feat(rxtrace): Added header manipulation to base class
Thu May 2 22:10:43 2024 UTC (15 months ago) by greg
fix(rxtrace): Minor fixes
Wed May 1 22:06:09 2024 UTC (15 months ago) by greg
fix(rxtrace): Fixed spectral sampling set-up
Tue Apr 30 23:16:23 2024 UTC (15 months, 1 week ago) by greg
Changes since 2.5: +14 -14 lines
feat(rxtrace): Added multi-processing and spectral color
Tue Mar 12 16:54:51 2024 UTC (16 months, 3 weeks ago) by greg
perf: added datavector() call for quicker spectral interpolation
Wed Aug 2 00:04:31 2023 UTC (2 years ago) by greg
Changes since 2.3: +12 -3 lines
feat: further fleshing out thread model
Mon Jul 31 23:14:02 2023 UTC (2 years ago) by greg
Changes since 2.2: +11 -10 lines
refactor: minor code improvements
Wed Jul 26 23:27:44 2023 UTC (2 years ago) by greg
Changes since 2.1: +11 -1 lines
feat: Preparing for multi-threading
Wed Feb 8 17:41:48 2023 UTC (2 years, 5 months ago) by greg
Diff to selected 2.11
feat(ratrace): First working version of new C++ rendering tool
