1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: RtraceSimulManager.cpp,v 2.3 2023/07/31 23:14:02 greg Exp $"; |
3 |
#endif |
4 |
5 |
* RtraceSimulManager.cpp |
6 |
7 |
* Rtrace simulation manager class implementation |
8 |
9 |
* Created by Greg Ward on 2/2/2023. |
10 |
11 |
12 |
#include "RtraceSimulManager.h" |
13 |
#include "source.h" |
14 |
15 |
extern int castonly; // doing ray-casting only? |
16 |
17 |
// Load octree and prepare renderer |
18 |
bool |
19 |
RadSimulManager::LoadOctree(const char *octn) |
20 |
21 |
if (octname) { // already running? |
22 |
if (octn && !strcmp(octn, octname)) |
23 |
return true; |
24 |
Cleanup(false); |
25 |
26 |
if (!octn) |
27 |
return false; |
28 |
29 |
ray_init((char *)octn); |
30 |
return true; |
31 |
32 |
33 |
// How many processors are there? |
34 |
int |
35 |
RadSimulManager::GetNCores() |
36 |
37 |
return 1; // XXX temporary |
38 |
39 |
40 |
// Set number of computation threads (0 => #cores) |
41 |
int |
42 |
RadSimulManager::SetThreadCount(int nt) |
43 |
44 |
return nThreads = 1; // XXX temporary |
45 |
46 |
47 |
// Assign ray to subthread (fails if NThreads()<2) |
48 |
bool |
49 |
RadSimulManager::SplitRay(RAY *r) |
50 |
51 |
if (NThreads() < 2 || ThreadsAvailable() < 1) |
52 |
return false; |
53 |
54 |
return false; // UNIMPLEMENTED |
55 |
56 |
57 |
// Process a ray (in subthread), optional result |
58 |
bool |
59 |
RadSimulManager::ProcessRay(RAY *r) |
60 |
61 |
if (!r || !Ready()) return false; |
62 |
if (NThreads() < 2) { // single-threaded mode? |
63 |
samplendx++; |
64 |
rayvalue(r); |
65 |
return true; |
66 |
67 |
if (ThreadsAvailable() >= 1) { |
68 |
SplitRay(r); // queue not yet full |
69 |
return false; |
70 |
71 |
RAY toDo = *r; |
72 |
if (!WaitResult(r)) // need a free thread |
73 |
return false; |
74 |
SplitRay(&toDo); // queue up new ray |
75 |
return true; // return older result |
76 |
77 |
78 |
// Wait for next result (or fail) |
79 |
bool |
80 |
RadSimulManager::WaitResult(RAY *r) |
81 |
82 |
83 |
84 |
85 |
// Close octree, free data, return status |
86 |
int |
87 |
RadSimulManager::Cleanup(bool everything) |
88 |
89 |
ray_done(everything); |
90 |
return 0; |
91 |
92 |
93 |
// How many threads are currently unoccupied? |
94 |
int |
95 |
RadSimulManager::ThreadsAvailable() const |
96 |
97 |
98 |
99 |
100 |
// Global pointer to simulation manager for trace call-back (only one) |
101 |
static const RtraceSimulManager * ourRTsimMan = NULL; |
102 |
103 |
void // static call-back |
104 |
RtraceSimulManager::RTracer(RAY *r) |
105 |
106 |
(*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData); |
107 |
108 |
109 |
// Check for changes to render flags & adjust accordingly |
110 |
bool |
111 |
RtraceSimulManager::UpdateMode() |
112 |
113 |
rtFlags &= RTmask; |
114 |
if (!cookedCall) |
115 |
rtFlags &= ~RTdoFIFO; |
116 |
if (!traceCall) |
117 |
rtFlags &= ~RTtraceSources; |
118 |
if (rtFlags & RTimmIrrad) |
119 |
rtFlags &= ~RTlimDist; |
120 |
121 |
int misMatch = rtFlags ^ curFlags; |
122 |
// updates based on toggled flags |
123 |
if (misMatch & RTtraceSources) { |
124 |
if (rtFlags & RTtraceSources) { |
125 |
for (int sn = 0; sn < nsources; sn++) |
126 |
source[sn].sflags |= SFOLLOW; |
127 |
} else // cannot undo this... |
128 |
rtFlags |= RTtraceSources; |
129 |
130 |
if (misMatch & RTdoFIFO && FlushQueue() < 0) |
131 |
return false; |
132 |
curFlags = rtFlags; |
133 |
// update trace callback |
134 |
if (traceCall) { |
135 |
if (ourRTsimMan && ourRTsimMan != this) |
136 |
error(WARNING, "Competing top-level simulation managers?"); |
137 |
ourRTsimMan = this; |
138 |
trace = RTracer; |
139 |
} else if (ourRTsimMan == this) { |
140 |
trace = NULL; |
141 |
142 |
143 |
return true; |
144 |
145 |
146 |
extern "C" int m_normal(OBJREC *m, RAY *r); |
147 |
148 |
/* compute irradiance rather than radiance */ |
149 |
static void |
150 |
rayirrad(RAY *r) |
151 |
152 |
/* pretend we hit surface */ |
153 |
r->rxt = r->rot = 1e-5; |
154 |
VSUM(r->rop, r->rorg, r->rdir, r->rot); |
155 |
r->ron[0] = -r->rdir[0]; |
156 |
r->ron[1] = -r->rdir[1]; |
157 |
r->ron[2] = -r->rdir[2]; |
158 |
r->rod = 1.0; |
159 |
/* compute result */ |
160 |
r->revf = raytrace; |
161 |
m_normal(&Lamb, r); |
162 |
r->revf = rayirrad; |
163 |
164 |
165 |
/* compute first ray intersection only */ |
166 |
static void |
167 |
raycast(RAY *r) |
168 |
169 |
if (!localhit(r, &thescene)) { |
170 |
if (r->ro == &Aftplane) { /* clipped */ |
171 |
r->ro = NULL; |
172 |
r->rot = FHUGE; |
173 |
} else |
174 |
sourcehit(r); |
175 |
176 |
177 |
178 |
// Add a ray result to FIFO, flushing what we can |
179 |
int |
180 |
RtraceSimulManager::QueueResult(const RAY &ra) |
181 |
182 |
return 0; // UNIMPLEMENTED |
183 |
184 |
185 |
// Add ray bundle to queue w/ optional 1st ray ID |
186 |
int |
187 |
RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0) |
188 |
189 |
int nqueued = 0; |
190 |
RAY res; |
191 |
192 |
if (!Ready()) |
193 |
return -1; |
194 |
195 |
if (castonly && !cookedCall) |
196 |
error(CONSISTENCY, "EnqueueBundle() called in castonly mode without cookedCall"); |
197 |
198 |
if (!UpdateMode()) // update rendering mode if requested |
199 |
return -1; |
200 |
201 |
while (n-- > 0) { // queue each ray |
202 |
VCOPY(res.rorg, orig_direc[0]); |
203 |
VCOPY(res.rdir, orig_direc[1]); |
204 |
orig_direc += 2; |
205 |
rayorigin(&res, PRIMARY, NULL, NULL); |
206 |
if (rID0) res.rno = rID0++; |
207 |
else res.rno = ++lastRayID; |
208 |
if (curFlags & RTimmIrrad) |
209 |
res.revf = rayirrad; |
210 |
else if (castonly) |
211 |
res.revf = raycast; |
212 |
double d = normalize(res.rdir); |
213 |
bool sendRes = (cookedCall != NULL); |
214 |
if (d > 0) { // direction vector is valid? |
215 |
if (curFlags & RTlimDist) |
216 |
res.rmax = d; |
217 |
if ((sendRes &= ProcessRay(&res)) && |
218 |
rtFlags & RTdoFIFO && NThreads() > 1) { |
219 |
if (QueueResult(res) < 0) |
220 |
return -1; |
221 |
sendRes = false; |
222 |
223 |
} else if (ThreadsAvailable() < NThreads() && |
224 |
FlushQueue() < 0) |
225 |
return -1; |
226 |
if (sendRes) // may be dummy ray |
227 |
(*cookedCall)(&res, ccData); |
228 |
nqueued++; |
229 |
230 |
return nqueued; |
231 |
232 |
233 |
// Finish pending rays and complete callbacks |
234 |
int |
235 |
RtraceSimulManager::FlushQueue() |
236 |
237 |
int nsent = 0; |
238 |
RAY res; |
239 |
240 |
while (WaitResult(&res)) { |
241 |
if (!cookedCall) continue; |
242 |
if (rtFlags & RTdoFIFO) { |
243 |
int ns = QueueResult(res); |
244 |
if (ns < 0) return ns; |
245 |
nsent += ns; |
246 |
} else { |
247 |
248 |
nsent++; |
249 |
250 |
251 |
return nsent; |
252 |
