root/radiance/ray/src/rt/RtraceSimulManager.cpp
Revision: 2.22
Committed: Wed Nov 13 02:43:51 2024 UTC (6 months, 1 week ago) by greg
Changes since 2.21: +10 -30 lines
feat: Improved error-handling in base simulation manager classes
2 static const char RCSid[] = "$Id: RtraceSimulManager.cpp,v 2.21 2024/11/09 00:10:49 greg Exp $";
5 * RtraceSimulManager.cpp
6 *
7 * Rtrace simulation manager class implementation
8 *
9 * Created by Greg Ward on 2/2/2023.
10 */
11
12 #include <unistd.h>
13 #include <ctype.h>
14 #include "RtraceSimulManager.h"
15 #include "source.h"
16
17 // Load octree and prepare renderer
18 bool
19 RadSimulManager::LoadOctree(const char *octn)
20 {
21 if (octname) { // already running?
22 if (octn && !strcmp(octn, octname))
23 return true;
24 Cleanup();
25 }
26 if (!octn) // don't support stdin octree
27 return false;
28
29 NewHeader(octn); // get octree header
30 ray_init((char *)octn);
31 return true;
32 }
33
34 // callback function for loading header
35 static int
36 add2header(char *str, void *p)
37 {
38 if (isheadid(str))
39 return 0;
40 if (isformat(str))
41 return 0;
42
43 return (*(RadSimulManager *)p).AddHeader(str);
44 }
45
46 // Prepare header from previous input (or clear)
47 // Normally called during octree load
48 bool
49 RadSimulManager::NewHeader(const char *inspec)
50 {
51 if (hlen) {
52 free(header); header = NULL; hlen = 0;
53 }
54 if (!inspec || !*inspec)
55 return false;
56 if (inspec[0] == '!') // save command as header?
57 return AddHeader(inspec+1);
58 // attempt to read from file
59 FILE *fp = fopen(inspec, "rb");
60 if (!fp) return false;
61 bool ok = (getheader(fp, add2header, this) >= 0);
62 fclose(fp);
63 return ok;
64 }
65
66 // Add a string to header (adds newline if missing)
67 bool
68 RadSimulManager::AddHeader(const char *str)
69 {
70 if (!str) return false;
71 int len = strlen(str);
72 while (len && (str[len-1] == '\n') | (str[len-1] == '\r'))
73 --len; // don't copy EOL(s)
74 if (!len)
75 return false;
76 if (hlen)
77 header = (char *)realloc(header, hlen+len+2);
78 else
79 header = (char *)malloc(len+2);
80 if (!header) {
81 hlen = 0; // XXX should report?
82 return false;
83 }
84 memcpy(header+hlen, str, len);
85 hlen += len;
86 header[hlen++] = '\n'; // add single EOL
87 header[hlen] = '\0';
88 return true;
89 }
90
91 // helper function to check for white-space and quotations
92 static int
93 check_special(const char *s)
94 {
95 int space_found = 0;
96
97 while (*s) {
98 if ((*s == '"') | (*s == '\''))
99 return *s; // quotes have priority
100 if (isspace(*s))
101 space_found = *s;
102 s++;
103 }
104 return space_found;
105 }
106
107 // Append program line to header
108 bool
109 RadSimulManager::AddHeader(int ac, char *av[])
110 {
111 if ((ac <= 0) | !av) return false;
112 int len = 0;
113 int n;
114 for (n = 0; n < ac; n++) {
115 if (!av[n]) return false;
116 len += strlen(av[n]) + 3;
117 }
118 if (hlen) // add to header
119 header = (char *)realloc(header, hlen+len+1);
120 else
121 header = (char *)malloc(len+1);
122
123 for (n = 0; n < ac; n++) {
124 int c = check_special(av[n]);
125 len = strlen(av[n]);
126 if (c | !len) { // need to quote argument?
127 if ((c == '"') | (c == '\n')) c = '\'';
128 else c = '"';
129 header[hlen++] = c;
130 strcpy(header+hlen, av[n]);
131 hlen += len;
132 header[hlen++] = c;
133 } else {
134 strcpy(header+hlen, av[n]);
135 hlen += len;
136 }
137 header[hlen++] = ' ';
138 }
139 header[hlen-1] = '\n'; // terminate line
140 header[hlen] = '\0';
141 return true;
142 }
143
144 // Look for specific header keyword, return value
145 const char *
146 RadSimulManager::GetHeadStr(const char *key, bool inOK) const
147 {
148 if (!key | !hlen || strchr(key, '\n'))
149 return NULL;
150 if (inOK) // skip leading spaces?
151 while (isspace(*key)) key++;
152
153 const int klen = strlen(key);
154 if (!klen)
155 return NULL;
156 const char * cp = header;
157 while (*cp) {
158 if (inOK) { // skip leading spaces?
159 while (isspace(*cp) && *cp++ != '\n')
160 ;
161 if (cp[-1] == '\n')
162 continue;
163 }
164 if (!strncmp(cp, key, klen))
165 return cp+klen; // found it!
166
167 while (*cp && *cp++ != '\n')
168 ;
169 }
170 return NULL;
171 }
172
173 // How many processors are available?
174 int
175 RadSimulManager::GetNCores()
176 {
177 return sysconf(_SC_NPROCESSORS_ONLN);
178 }
179
180 // Set number of computation threads (0 => #cores)
181 int
182 RadSimulManager::SetThreadCount(int nt)
183 {
184 if (!Ready())
185 return 0;
186
187 if (nt <= 0) nt = castonly ? 1 : GetNCores();
188
189 if (nt == 1)
190 ray_pclose(ray_pnprocs);
191 else if (nt < ray_pnprocs)
192 ray_pclose(ray_pnprocs - nt);
193 else if (nt > ray_pnprocs)
194 ray_popen(nt - ray_pnprocs);
195
196 return NThreads();
197 }
198
199 // Process a ray (in subthread), optional result
200 int
201 RadSimulManager::ProcessRay(RAY *r)
202 {
203 if (!Ready()) return false;
204
205 if (!ray_pnprocs) { // single-threaded mode?
206 samplendx++;
207 rayvalue(r);
208 return 1;
209 }
210 return ray_pqueue(r);
211 }
212
213 // Wait for next result (or fail)
214 bool
215 RadSimulManager::WaitResult(RAY *r)
216 {
217 if (!ray_pnprocs)
218 return false;
219
220 return (ray_presult(r, 0) > 0);
221 }
222
223 // Close octree, free data, return status
224 int
225 RadSimulManager::Cleanup(bool everything)
226 {
227 if (ray_pnprocs < 0)
228 return 0; // skip in child process
229 NewHeader();
230 if (!ray_pnprocs)
231 ray_done(everything);
232 else
233 ray_pdone(everything);
234 return 0;
235 }
236
237 // Global pointer to simulation manager for trace call-back (only one)
238 static const RtraceSimulManager * ourRTsimMan = NULL;
239
240 // Call-back for trace output
241 void
242 RtraceSimulManager::RTracer(RAY *r)
243 {
244 (*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData);
245 }
246
247 // Call-back for FIFO output
248 int
249 RtraceSimulManager::Rfifout(RAY *r)
250 {
251 return (*ourRTsimMan->cookedCall)(r, ourRTsimMan->ccData);
252 }
253
254 // Check for changes to render flags & adjust accordingly
255 bool
256 RtraceSimulManager::UpdateMode()
257 {
258 if (!cookedCall)
259 rtFlags &= ~RTdoFIFO;
260 if (!traceCall)
261 rtFlags &= ~RTtraceSources;
262 if (rtFlags & RTimmIrrad)
263 rtFlags &= ~RTlimDist;
264
265 int misMatch = (rtFlags ^ curFlags) & RTmask;
266 // updates based on toggled flags
267 if (((misMatch & RTtraceSources) != 0) & (nsources > 0)) {
268 int nt = NThreads();
269 if (nt > 1) {
270 if (FlushQueue() < 0)
271 return false;
272 SetThreadCount(1);
273 }
274 int sn = nsources;
275 if (rtFlags & RTtraceSources) {
276 srcFollowed.NewBitMap(nsources);
277 while (sn--) {
278 if (source[sn].sflags & SFOLLOW)
279 continue;
280 source[sn].sflags |= SFOLLOW;
281 srcFollowed.Set(sn);
282 }
283 } else {
284 while (sn--)
285 if (srcFollowed.Check(sn))
286 source[sn].sflags &= ~SFOLLOW;
287 srcFollowed.NewBitMap(0);
288 }
289 if (nt > 1) SetThreadCount(nt);
290 }
291 if (misMatch & RTdoFIFO && FlushQueue() < 0)
292 return false;
293 curFlags = rtFlags;
294 // update callbacks
295 if (traceCall)
296 trace = RTracer;
297 else if (trace == RTracer)
298 trace = NULL;
299 if (rtFlags & RTdoFIFO)
300 ray_fifo_out = Rfifout;
301 else if (ray_fifo_out == Rfifout)
302 ray_fifo_out = NULL;
303 if ((trace != RTracer) & (ray_fifo_out != Rfifout)) {
304 ourRTsimMan = NULL;
305 } else if (ourRTsimMan != this) {
306 if (ourRTsimMan)
307 error(WARNING, "Competing top-level simulation managers?");
308 ourRTsimMan = this;
309 }
310 return true;
311 }
312
313 extern "C" int m_normal(OBJREC *m, RAY *r);
314
315 // compute irradiance rather than radiance
316 static void
317 rayirrad(RAY *r)
318 {
319 /* pretend we hit surface */
320 r->rxt = r->rot = 1e-5;
321 VSUM(r->rop, r->rorg, r->rdir, r->rot);
322 r->ron[0] = -r->rdir[0];
323 r->ron[1] = -r->rdir[1];
324 r->ron[2] = -r->rdir[2];
325 r->rod = 1.0;
326 /* compute result */
327 r->revf = raytrace;
328 m_normal(&Lamb, r);
329 r->revf = rayirrad;
330 }
331
332 // compute first ray intersection only
333 static void
334 raycast(RAY *r)
335 {
336 if (!localhit(r, &thescene)) {
337 if (r->ro == &Aftplane) { /* clipped */
338 r->ro = NULL;
339 r->rot = FHUGE;
340 } else
341 sourcehit(r);
342 }
343 }
344
345 // Add ray bundle to queue w/ optional 1st ray ID
346 int
347 RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0)
348 {
349 int nqueued = 0;
350 RAY res;
351
352 if (!Ready())
353 return -1;
354
355 if (castonly && !cookedCall)
356 error(INTERNAL, "EnqueueBundle() called in castonly mode without cookedCall");
357
358 if (!UpdateMode()) // update rendering mode if requested
359 return -1;
360
361 if (rID0 && curFlags&RTdoFIFO)
362 error(INTERNAL, "Ray number assignment unsupported with FIFO");
363
364 while (n-- > 0) { // queue each ray
365 VCOPY(res.rorg, orig_direc[0]);
366 VCOPY(res.rdir, orig_direc[1]);
367 res.rmax = .0;
368 orig_direc += 2;
369 rayorigin(&res, PRIMARY, NULL, NULL);
370 res.rno = rID0 ? (lastRayID = rID0++) : ++lastRayID;
371 if (curFlags & RTimmIrrad)
372 res.revf = rayirrad;
373 else if (castonly)
374 res.revf = raycast;
375 double d = normalize(res.rdir);
376 bool sendRes = (cookedCall != NULL);
377 if (d > .0) { // direction vector is valid?
378 if (curFlags & RTlimDist)
379 res.rmax = d;
380 if (((curFlags&RTdoFIFO) != 0) & (ray_pnprocs > 0)) {
381 if (ray_fifo_in(&res) < 0)
382 return -1;
383 sendRes = false;
384 } else {
385 int rv = ProcessRay(&res);
386 if (rv < 0)
387 return -1;
388 sendRes &= (rv > 0);
389 }
390 } else if (ThreadsAvailable() < NThreads() &&
391 FlushQueue() < 0)
392 return -1;
393 // may be dummy ray
394 if (sendRes && (*cookedCall)(&res, ccData) < 0)
395 return -1;
396 nqueued++;
397 }
398 return nqueued;
399 }
400
401 // Finish pending rays and complete callbacks
402 int
403 RtraceSimulManager::FlushQueue()
404 {
405 if (curFlags & RTdoFIFO) {
406 if (ray_pnprocs)
407 return ray_fifo_flush();
408 return 0;
409 }
410 int nsent = 0;
411 RAY res;
412
413 while (WaitResult(&res)) {
414 if (!cookedCall) continue;
415 int rv = (*cookedCall)(&res, ccData);
416 if (rv < 0) return -1;
417 nsent += rv;
418 }
419 return nsent;
420 }
