root/radiance/ray/src/rt/RtraceSimulManager.cpp
Revision: 2.1
Committed: Wed Feb 8 17:41:48 2023 UTC (2 years, 3 months ago) by greg
feat(ratrace): First working version of new C++ rendering tool
5 * RtraceSimulManager.cpp
6 *
7 * Rtrace simulation manager class implementation
8 *
9 * Created by Greg Ward on 2/2/2023.
10 */
11
12 #include "RtraceSimulManager.h"
13 #include "source.h"
14
15 extern int castonly; // doing ray-casting only?
16
17 // Load octree and prepare renderer
18 bool
19 RadSimulManager::LoadOctree(const char *octn)
20 {
21 if (octname) { // already running?
22 if (octn && !strcmp(octn, octname))
23 return true;
24 Cleanup();
25 }
26 if (!octn)
27 return false;
28
29 ray_init((char *)octn);
30 return true;
31 }
32
33 // Set number of computation threads (0 => #cores)
34 int
35 RadSimulManager::SetThreadCount(int nt)
36 {
37 return nThreads = 1; // XXX temporary
38 }
39
40 // Close octree, free data, return status
41 int
42 RadSimulManager::Cleanup()
43 {
44 ray_done(0);
45 return 0;
46 }
47
48 // How many threads are currently unoccupied?
49 int
50 RadSimulManager::ThreadsAvailable() const
51 {
52 return 1; // XXX temporary
53 }
54
55 // Global pointer to simulation manager for trace call-back (only one)
56 static const RtraceSimulManager * ourRTsimMan = NULL;
57
58 void // static call-back
59 RtraceSimulManager::RTracer(RAY *r)
60 {
61 (*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData);
62 }
63
64 // Check for changes to render flags & adjust accordingly
65 bool
66 RtraceSimulManager::UpdateMode()
67 {
68 rtFlags &= RTmask;
69 if (!cookedCall)
70 rtFlags &= ~RTdoFIFO;
71 if (!traceCall)
72 rtFlags &= ~RTtraceSources;
73 if (rtFlags & RTimmIrrad)
74 rtFlags &= ~RTlimDist;
75
76 int misMatch = rtFlags ^ curFlags;
77 // updates based on toggled flags
78 if (misMatch & RTtraceSources) {
79 if (rtFlags & RTtraceSources) {
80 for (int sn = 0; sn < nsources; sn++)
81 source[sn].sflags |= SFOLLOW;
82 } else // cannot undo this...
83 rtFlags |= RTtraceSources;
84 }
85 if (misMatch & RTdoFIFO) {
86 if (!FlushQueue())
87 return false;
88 }
89 curFlags = rtFlags;
90 // update trace callback
91 if (traceCall) {
92 if (ourRTsimMan && ourRTsimMan != this)
93 error(WARNING, "Competing top-level simulation managers?");
94 ourRTsimMan = this;
95 trace = RTracer;
96 } else if (ourRTsimMan == this) {
97 trace = NULL;
98 ourRTsimMan = NULL;
99 }
100 return true;
101 }
102
103 extern "C" int m_normal(OBJREC *m, RAY *r);
104
105 /* compute irradiance rather than radiance */
106 static void
107 rayirrad(RAY *r)
108 {
109 /* pretend we hit surface */
110 r->rxt = r->rot = 1e-5;
111 VSUM(r->rop, r->rorg, r->rdir, r->rot);
112 r->ron[0] = -r->rdir[0];
113 r->ron[1] = -r->rdir[1];
114 r->ron[2] = -r->rdir[2];
115 r->rod = 1.0;
116 /* compute result */
117 r->revf = raytrace;
118 m_normal(&Lamb, r);
119 r->revf = rayirrad;
120 }
121
122 /* compute first ray intersection only */
123 static void
124 raycast(RAY *r)
125 {
126 if (!localhit(r, &thescene)) {
127 if (r->ro == &Aftplane) { /* clipped */
128 r->ro = NULL;
129 r->rot = FHUGE;
130 } else
131 sourcehit(r);
132 }
133 }
134
135 // Add ray bundle to queue w/ optional 1st ray ID
136 int
137 RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0)
138 {
139 int nqueued = 0;
140 RAY res;
141
142 if (!Ready())
143 return -1;
144
145 if (castonly && !cookedCall)
146 error(CONSISTENCY, "EnqueueBundle() called in castonly mode without cookedCall");
147
148 if (!UpdateMode()) // update rendering mode if requested
149 return -1;
150
151 while (n-- > 0) { // queue each ray
152 double d;
153 VCOPY(res.rorg, orig_direc[0]);
154 VCOPY(res.rdir, orig_direc[1]);
155 orig_direc += 2;
156 rayorigin(&res, PRIMARY, NULL, NULL);
157 if (rID0) res.rno = rID0++;
158 else res.rno = ++lastRayID;
159 if (curFlags & RTimmIrrad)
160 res.revf = rayirrad;
161 else if (castonly)
162 res.revf = raycast;
163 d = normalize(res.rdir);
164 if (d > 0) { // direction vector is valid?
165 if (curFlags & RTlimDist)
166 res.rmax = d;
167 samplendx++;
168 rayvalue(&res); // XXX single-threaded for now
169 ++nqueued;
170 } else if (ThreadsAvailable() < NThreads() &&
171 !FlushQueue())
172 return -1;
173 if (cookedCall)
174 (*cookedCall)(&res, ccData);
175 }
176 return nqueued;
177 }
178
179 // Finish pending rays and complete callbacks
180 bool
181 RtraceSimulManager::FlushQueue()
182 {
183 return true; // XXX no-op for now
184 }
