root/radiance/ray/src/rt/RtraceSimulManager.cpp
Wed Nov 20 17:46:25 2024 UTC (8 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.23: +13 -7 lines
Diff to previous 2.23 , to selected 2.8
fix(rxtrace,rxcontrib): Fix in -I+ option for bug pointed out by S. Wasilewski
Wed Nov 13 18:47:01 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.22: +4 -6 lines
Diff to previous 2.22 , to selected 2.8
fix: corrected return value (minor)
Wed Nov 13 02:43:51 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.21: +10 -30 lines
Diff to previous 2.21 , to selected 2.8
feat: Improved error-handling in base simulation manager classes
Sat Nov 9 00:10:49 2024 UTC (8 months, 4 weeks ago) by greg
Changes since 2.20: +9 -2 lines
Diff to previous 2.20 , to selected 2.8
fix: Changes to source-tracing requires child process restart
Thu Nov 7 18:37:11 2024 UTC (8 months, 4 weeks ago) by greg
Changes since 2.19: +2 -3 lines
Diff to previous 2.19 , to selected 2.8
fix(rxcontrib): Was inadvertantly clearing private RCcontrib flag
Wed Nov 6 18:28:52 2024 UTC (9 months ago) by greg
Changes since 2.18: +3 -1 lines
Diff to previous 2.18 , to selected 2.8
perf(rxtrace,rxpict,rxpiece,rxcontrib): Improved exit strategy in children
Thu Oct 10 21:02:52 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.17: +14 -4 lines
Diff to previous 2.17 , to selected 2.8
fix: Allow unsetting of source-ray tracing flag
Mon Sep 16 19:18:32 2024 UTC (10 months, 2 weeks ago) by greg
Changes since 2.16: +30 -1 lines
Diff to previous 2.16 , to selected 2.8
feat: Added method to get a specific string from header
Sun Aug 25 00:17:29 2024 UTC (11 months, 1 week ago) by greg
Changes since 2.15: +2 -1 lines
fix(rxtrace,rxpict): Failed to initialize RAY rmax setting!
Wed Aug 14 20:05:23 2024 UTC (11 months, 3 weeks ago) by greg
Mon Aug 5 19:51:18 2024 UTC (12 months ago) by greg
perf(rxtrace): Eliminated unnecessary queue flushing when adding processes
Sat Aug 3 15:38:06 2024 UTC (12 months ago) by greg
Changes since 2.12: +35 -27 lines
feat(rxtrace): Added command-line for octree in lieu of header
Sat Aug 3 01:54:46 2024 UTC (12 months ago) by greg
Changes since 2.11: +107 -2 lines
feat(rxtrace): Added header manipulation to base class
Mon Jul 8 23:46:04 2024 UTC (12 months, 4 weeks ago) by greg
fix(rxtrace): Called wrong close procedure for single- and multi-processing
Tue Jul 2 23:54:16 2024 UTC (13 months ago) by greg
feat(rpict): Made drawsources() compatible with spectral scanlines
Fri May 3 18:01:20 2024 UTC (15 months ago) by greg
Changes since 2.8: +5 -7 lines
perf: Minor improvement
Thu May 2 22:10:43 2024 UTC (15 months ago) by greg
fix(rxtrace): Minor fixes
Wed May 1 20:28:53 2024 UTC (15 months ago) by greg
Changes since 2.6: +11 -7 lines
fix(rxtrace): Don't call FIFO routines with single process
Tue Apr 30 23:16:23 2024 UTC (15 months, 1 week ago) by greg
Changes since 2.5: +65 -58 lines
feat(rxtrace): Added multi-processing and spectral color
Tue Mar 12 16:54:51 2024 UTC (16 months, 3 weeks ago) by greg
Changes since 2.4: +24 -10 lines
perf: added datavector() call for quicker spectral interpolation
Wed Aug 2 00:04:31 2023 UTC (2 years ago) by greg
Changes since 2.3: +74 -13 lines
feat: further fleshing out thread model
Mon Jul 31 23:14:02 2023 UTC (2 years ago) by greg
refactor: minor code improvements
Wed Jul 26 23:27:44 2023 UTC (2 years ago) by greg
Changes since 2.1: +8 -1 lines
feat: Preparing for multi-threading
Wed Feb 8 17:41:48 2023 UTC (2 years, 5 months ago) by greg
Diff to selected 2.8
feat(ratrace): First working version of new C++ rendering tool
