root/Development/ray/src/rt/RtraceSimulManager.cpp
Revision: 2.16
Committed: Sun Aug 25 00:17:29 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.15: +2 -1 lines
fix(rxtrace,rxpict): Failed to initialize RAY rmax setting!
2 static const char RCSid[] = "$Id: RtraceSimulManager.cpp,v 2.15 2024/08/14 20:05:23 greg Exp $";
5 * RtraceSimulManager.cpp
6 *
7 * Rtrace simulation manager class implementation
8 *
9 * Created by Greg Ward on 2/2/2023.
10 */
11
12 #include <unistd.h>
13 #include <ctype.h>
14 #include "RtraceSimulManager.h"
15 #include "source.h"
16
17 // Load octree and prepare renderer
18 bool
19 RadSimulManager::LoadOctree(const char *octn)
20 {
21 if (octname) { // already running?
22 if (octn && !strcmp(octn, octname))
23 return true;
24 Cleanup();
25 }
26 if (!octn) // don't support stdin octree
27 return false;
28
29 NewHeader(octn); // get octree header
30 ray_init((char *)octn);
31 return true;
32 }
33
34 // callback function for loading header
35 static int
36 add2header(char *str, void *p)
37 {
38 if (isheadid(str))
39 return 0;
40 if (isformat(str))
41 return 0;
42
43 return (*(RadSimulManager *)p).AddHeader(str);
44 }
45
46 // Prepare header from previous input (or clear)
47 // Normally called during octree load
48 bool
49 RadSimulManager::NewHeader(const char *inspec)
50 {
51 if (hlen) {
52 free(header); header = NULL; hlen = 0;
53 }
54 if (!inspec || !*inspec)
55 return false;
56 if (inspec[0] == '!') // save command as header?
57 return AddHeader(inspec+1);
58 // attempt to read from file
59 FILE *fp = fopen(inspec, "rb");
60 if (!fp) return false;
61 bool ok = (getheader(fp, add2header, this) >= 0);
62 fclose(fp);
63 return ok;
64 }
65
66 // Add a string to header (adds newline if missing)
67 bool
68 RadSimulManager::AddHeader(const char *str)
69 {
70 if (!str) return false;
71 int len = strlen(str);
72 while (len && (str[len-1] == '\n') | (str[len-1] == '\r'))
73 --len; // don't copy EOL(s)
74 if (!len)
75 return false;
76 if (hlen)
77 header = (char *)realloc(header, hlen+len+2);
78 else
79 header = (char *)malloc(len+2);
80 if (!header) {
81 hlen = 0; // XXX should report?
82 return false;
83 }
84 memcpy(header+hlen, str, len);
85 hlen += len;
86 header[hlen++] = '\n'; // add single EOL
87 header[hlen] = '\0';
88 return true;
89 }
90
91 // helper function to check for white-space and quotations
92 static int
93 check_special(const char *s)
94 {
95 int space_found = 0;
96
97 while (*s) {
98 if ((*s == '"') | (*s == '\''))
99 return *s; // quotes have priority
100 if (isspace(*s))
101 space_found = *s;
102 s++;
103 }
104 return space_found;
105 }
106
107 // Append program line to header
108 bool
109 RadSimulManager::AddHeader(int ac, char *av[])
110 {
111 if ((ac <= 0) | !av) return false;
112 int len = 0;
113 int n;
114 for (n = 0; n < ac; n++) {
115 if (!av[n]) return false;
116 len += strlen(av[n]) + 3;
117 }
118 if (hlen) // add to header
119 header = (char *)realloc(header, hlen+len+1);
120 else
121 header = (char *)malloc(len+1);
122
123 for (n = 0; n < ac; n++) {
124 int c = check_special(av[n]);
125 len = strlen(av[n]);
126 if (c | !len) { // need to quote argument?
127 if ((c == '"') | (c == '\n')) c = '\'';
128 else c = '"';
129 header[hlen++] = c;
130 strcpy(header+hlen, av[n]);
131 hlen += len;
132 header[hlen++] = c;
133 } else {
134 strcpy(header+hlen, av[n]);
135 hlen += len;
136 }
137 header[hlen++] = ' ';
138 }
139 header[hlen-1] = '\n'; // terminate line
140 header[hlen] = '\0';
141 return true;
142 }
143
144 // How many processors are available?
145 int
146 RadSimulManager::GetNCores()
147 {
148 return sysconf(_SC_NPROCESSORS_ONLN);
149 }
150
151 // Set number of computation threads (0 => #cores)
152 int
153 RadSimulManager::SetThreadCount(int nt)
154 {
155 if (!Ready())
156 return 0;
157
158 if (nt <= 0) nt = castonly ? 1 : GetNCores();
159
160 if (nt == 1)
161 ray_pclose(ray_pnprocs);
162 else if (nt < ray_pnprocs)
163 ray_pclose(ray_pnprocs - nt);
164 else if (nt > ray_pnprocs)
165 ray_popen(nt - ray_pnprocs);
166
167 return NThreads();
168 }
169
170 // Assign ray to subthread (fails if NThreads()<2)
171 bool
172 RadSimulManager::SplitRay(RAY *r)
173 {
174 if (!ray_pnprocs || ThreadsAvailable() < 1)
175 return false;
176
177 return (ray_psend(r) > 0);
178 }
179
180 // Process a ray (in subthread), optional result
181 bool
182 RadSimulManager::ProcessRay(RAY *r)
183 {
184 if (!Ready()) return false;
185
186 if (!ray_pnprocs) { // single-threaded mode?
187 samplendx++;
188 rayvalue(r);
189 return true;
190 }
191 int rv = ray_pqueue(r);
192 if (rv < 0) {
193 error(WARNING, "ray tracing process(es) died");
194 return false;
195 }
196 return (rv > 0);
197 }
198
199 // Wait for next result (or fail)
200 bool
201 RadSimulManager::WaitResult(RAY *r)
202 {
203 if (!ray_pnprocs)
204 return false;
205
206 return (ray_presult(r, 0) > 0);
207 }
208
209 // Close octree, free data, return status
210 int
211 RadSimulManager::Cleanup(bool everything)
212 {
213 NewHeader();
214 if (!ray_pnprocs)
215 ray_done(everything);
216 else
217 ray_pdone(everything);
218 return 0;
219 }
220
221 // How many threads are currently unoccupied?
222 int
223 RadSimulManager::ThreadsAvailable() const
224 {
225 if (!ray_pnprocs) return 1;
226
227 return ray_pnidle;
228 }
229
230 // Global pointer to simulation manager for trace call-back (only one)
231 static const RtraceSimulManager * ourRTsimMan = NULL;
232
233 // Call-back for trace output
234 void
235 RtraceSimulManager::RTracer(RAY *r)
236 {
237 (*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData);
238 }
239
240 // Call-back for FIFO output
241 int
242 RtraceSimulManager::Rfifout(RAY *r)
243 {
244 return (*ourRTsimMan->cookedCall)(r, ourRTsimMan->ccData);
245 }
246
247 // Check for changes to render flags & adjust accordingly
248 bool
249 RtraceSimulManager::UpdateMode()
250 {
251 rtFlags &= RTmask;
252 if (!cookedCall)
253 rtFlags &= ~RTdoFIFO;
254 if (!traceCall)
255 rtFlags &= ~RTtraceSources;
256 if (rtFlags & RTimmIrrad)
257 rtFlags &= ~RTlimDist;
258
259 int misMatch = rtFlags ^ curFlags;
260 // updates based on toggled flags
261 if (misMatch & RTtraceSources) {
262 if (rtFlags & RTtraceSources) {
263 for (int sn = 0; sn < nsources; sn++)
264 source[sn].sflags |= SFOLLOW;
265 } else // cannot undo this...
266 rtFlags |= RTtraceSources;
267 }
268 if (misMatch & RTdoFIFO && FlushQueue() < 0)
269 return false;
270 curFlags = rtFlags;
271 // update callbacks
272 if (traceCall)
273 trace = RTracer;
274 else if (trace == RTracer)
275 trace = NULL;
276 if (rtFlags & RTdoFIFO)
277 ray_fifo_out = Rfifout;
278 else if (ray_fifo_out == Rfifout)
279 ray_fifo_out = NULL;
280 if ((trace != RTracer) & (ray_fifo_out != Rfifout)) {
281 ourRTsimMan = NULL;
282 } else if (ourRTsimMan != this) {
283 if (ourRTsimMan)
284 error(WARNING, "Competing top-level simulation managers?");
285 ourRTsimMan = this;
286 }
287 return true;
288 }
289
290 extern "C" int m_normal(OBJREC *m, RAY *r);
291
292 // compute irradiance rather than radiance
293 static void
294 rayirrad(RAY *r)
295 {
296 /* pretend we hit surface */
297 r->rxt = r->rot = 1e-5;
298 VSUM(r->rop, r->rorg, r->rdir, r->rot);
299 r->ron[0] = -r->rdir[0];
300 r->ron[1] = -r->rdir[1];
301 r->ron[2] = -r->rdir[2];
302 r->rod = 1.0;
303 /* compute result */
304 r->revf = raytrace;
305 m_normal(&Lamb, r);
306 r->revf = rayirrad;
307 }
308
309 // compute first ray intersection only
310 static void
311 raycast(RAY *r)
312 {
313 if (!localhit(r, &thescene)) {
314 if (r->ro == &Aftplane) { /* clipped */
315 r->ro = NULL;
316 r->rot = FHUGE;
317 } else
318 sourcehit(r);
319 }
320 }
321
322 // Add ray bundle to queue w/ optional 1st ray ID
323 int
324 RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0)
325 {
326 int nqueued = 0;
327 RAY res;
328
329 if (!Ready())
330 return -1;
331
332 if (castonly && !cookedCall)
333 error(INTERNAL, "EnqueueBundle() called in castonly mode without cookedCall");
334
335 if (!UpdateMode()) // update rendering mode if requested
336 return -1;
337
338 if (rID0 && curFlags&RTdoFIFO)
339 error(INTERNAL, "Ray number assignment unsupported with FIFO");
340
341 while (n-- > 0) { // queue each ray
342 VCOPY(res.rorg, orig_direc[0]);
343 VCOPY(res.rdir, orig_direc[1]);
344 res.rmax = .0;
345 orig_direc += 2;
346 rayorigin(&res, PRIMARY, NULL, NULL);
347 res.rno = rID0 ? (lastRayID = rID0++) : ++lastRayID;
348 if (curFlags & RTimmIrrad)
349 res.revf = rayirrad;
350 else if (castonly)
351 res.revf = raycast;
352 double d = normalize(res.rdir);
353 bool sendRes = (cookedCall != NULL);
354 if (d > .0) { // direction vector is valid?
355 if (curFlags & RTlimDist)
356 res.rmax = d;
357 if (((curFlags&RTdoFIFO) != 0) & (ray_pnprocs > 0)) {
358 if (ray_fifo_in(&res) < 0)
359 return -1;
360 sendRes = false;
361 } else
362 sendRes &= ProcessRay(&res);
363 } else if (ThreadsAvailable() < NThreads() &&
364 FlushQueue() < 0)
365 return -1;
366 // may be dummy ray
367 if (sendRes && (*cookedCall)(&res, ccData) < 0)
368 return -1;
369 nqueued++;
370 }
371 return nqueued;
372 }
373
374 // Finish pending rays and complete callbacks
375 int
376 RtraceSimulManager::FlushQueue()
377 {
378 if (curFlags & RTdoFIFO) {
379 if (ray_pnprocs)
380 return ray_fifo_flush();
381 return 0;
382 }
383 int nsent = 0;
384 RAY res;
385
386 while (WaitResult(&res)) {
387 if (!cookedCall) continue;
388 int rv = (*cookedCall)(&res, ccData);
389 if (rv < 0) return -1;
390 nsent += rv;
391 }
392 return nsent;
393 }
