#ifndef lint static const char RCSid[] = "$Id: RtraceSimulManager.cpp,v 2.25 2025/10/21 16:12:05 greg Exp $"; #endif /* * RtraceSimulManager.cpp * * Rtrace simulation manager class implementation * * Created by Greg Ward on 2/2/2023. */ #include #include #include "RtraceSimulManager.h" #include "source.h" // Load octree and prepare renderer bool RadSimulManager::LoadOctree(const char *octn) { if (octname) { // already running? if (octn && !strcmp(octn, octname)) return true; Cleanup(); } if (!octn) // don't support stdin octree return false; NewHeader(octn); // get octree header ray_init((char *)octn); return true; } // callback function for loading header static int add2header(char *str, void *p) { if (isheadid(str)) return 0; if (isformat(str)) return 0; return (*(RadSimulManager *)p).AddHeader(str); } // Prepare header from previous input (or clear) // Normally called during octree load bool RadSimulManager::NewHeader(const char *inspec) { if (hlen) { free(header); header = NULL; hlen = 0; } if (!inspec || !*inspec) return false; if (inspec[0] == '!') // save command as header? return AddHeader(inspec+1); // attempt to read from file FILE *fp = fopen(inspec, "rb"); if (!fp) return false; bool ok = (getheader(fp, add2header, this) >= 0); fclose(fp); return ok; } // Add a string to header (adds newline if missing) bool RadSimulManager::AddHeader(const char *str) { if (!str) return false; int len = strlen(str); while (len && (str[len-1] == '\n') | (str[len-1] == '\r')) --len; // don't copy EOL(s) if (!len) return false; if (hlen) header = (char *)realloc(header, hlen+len+2); else header = (char *)malloc(len+2); if (!header) { hlen = 0; // XXX should report? return false; } memcpy(header+hlen, str, len); hlen += len; header[hlen++] = '\n'; // add single EOL header[hlen] = '\0'; return true; } // helper function to check for white-space and quotations static int check_special(const char *s) { int space_found = 0; while (*s) { if ((*s == '"') | (*s == '\'')) return *s; // quotes have priority if (isspace(*s)) space_found = *s; s++; } return space_found; } // Append program line to header bool RadSimulManager::AddHeader(int ac, char *av[]) { if ((ac <= 0) | !av) return false; int len = 0; int n; for (n = 0; n < ac; n++) { if (!av[n]) return false; len += strlen(av[n]) + 3; } if (hlen) // add to header header = (char *)realloc(header, hlen+len+1); else header = (char *)malloc(len+1); for (n = 0; n < ac; n++) { int c = check_special(av[n]); len = strlen(av[n]); if (c | !len) { // need to quote argument? if ((c == '"') | (c == '\n')) c = '\''; else c = '"'; header[hlen++] = c; strcpy(header+hlen, av[n]); hlen += len; header[hlen++] = c; } else { strcpy(header+hlen, av[n]); hlen += len; } header[hlen++] = ' '; } header[hlen-1] = '\n'; // terminate line header[hlen] = '\0'; return true; } // Look for specific header keyword, return value const char * RadSimulManager::GetHeadStr(const char *key, bool inOK) const { if (!key | !hlen || strchr(key, '\n')) return NULL; if (inOK) // skip leading spaces? while (isspace(*key)) key++; const int klen = strlen(key); if (!klen) return NULL; const char * cp = header; while (*cp) { if (inOK) { // skip leading spaces? while (isspace(*cp) && *cp++ != '\n') ; if (cp[-1] == '\n') continue; } if (!strncmp(cp, key, klen)) return cp+klen; // found it! while (*cp && *cp++ != '\n') ; } return NULL; } // How many processors are available? int RadSimulManager::GetNCores() { return sysconf(_SC_NPROCESSORS_ONLN); } // Set number of computation threads (0 => #cores) int RadSimulManager::SetThreadCount(int nt) { if (!Ready()) return 0; if (nt <= 0) nt = castonly ? 1 : GetNCores(); if (nt == 1) ray_pclose(ray_pnprocs); else if (nt < ray_pnprocs) ray_pclose(ray_pnprocs - nt); else if (nt > ray_pnprocs) ray_popen(nt - ray_pnprocs); return NThreads(); } // Process a ray (in subthread), optional result int RadSimulManager::ProcessRay(RAY *r) { if (!Ready()) return -1; if (!ray_pnprocs) { // single-threaded mode? samplendx++; rayvalue(r); return 1; } return ray_pqueue(r); } // Wait for next result (or fail) bool RadSimulManager::WaitResult(RAY *r) { if (!ray_pnprocs) return false; return (ray_presult(r, 0) > 0); } // Close octree, free data, return status int RadSimulManager::Cleanup(bool everything) { if (ray_pnprocs < 0) return 0; // skip in child process NewHeader(); if (!ray_pnprocs) ray_done(everything); else ray_pdone(everything); return 0; } // Global pointer to simulation manager for trace call-back (only one) static const RtraceSimulManager * ourRTsimMan = NULL; // Call-back for trace output void RtraceSimulManager::RTracer(RAY *r) { (*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData); } // Call-back for FIFO output int RtraceSimulManager::Rfifout(RAY *r) { return (*ourRTsimMan->cookedCall)(r, ourRTsimMan->ccData); } // Check for changes to render flags & adjust accordingly bool RtraceSimulManager::UpdateMode() { if (!cookedCall) rtFlags &= ~RTdoFIFO; if (!traceCall) rtFlags &= ~RTtraceSources; if (rtFlags & RTimmIrrad) rtFlags &= ~RTlimDist; int misMatch = (rtFlags ^ curFlags) & RTmask; // updates based on toggled flags if (((misMatch & RTtraceSources) != 0) & (nsources > 0)) { int nt = NThreads(); if (nt > 1) { if (FlushQueue() < 0) return false; SetThreadCount(1); } int sn = nsources; if (rtFlags & RTtraceSources) { srcFollowed.NewBitMap(nsources); while (sn--) { if (source[sn].sflags & SFOLLOW) continue; source[sn].sflags |= SFOLLOW; srcFollowed.Set(sn); } } else { while (sn--) if (srcFollowed.Check(sn)) source[sn].sflags &= ~SFOLLOW; srcFollowed.NewBitMap(0); } if (nt > 1) SetThreadCount(nt); } if (misMatch & RTdoFIFO && FlushQueue() < 0) return false; curFlags = rtFlags; // update callbacks if (traceCall) trace = RTracer; else if (trace == RTracer) trace = NULL; if (rtFlags & RTdoFIFO) ray_fifo_out = Rfifout; else if (ray_fifo_out == Rfifout) ray_fifo_out = NULL; if ((trace != RTracer) & (ray_fifo_out != Rfifout)) { ourRTsimMan = NULL; } else if (ourRTsimMan != this) { if (ourRTsimMan) error(WARNING, "competing top-level simulation managers?"); ourRTsimMan = this; } return true; } extern "C" int m_normal(OBJREC *m, RAY *r); // compute irradiance rather than radiance static void rayirrad(RAY *r) { /* orientation -> normal */ VCOPY(r->ron, r->rdir); /* pretend normal incidence */ r->rdir[0] = -r->ron[0]; r->rdir[1] = -r->ron[1]; r->rdir[2] = -r->ron[2]; r->rod = 1.0; /* counterfeit other params */ r->rxt = r->rot = 1e-4; /* move comfortably above sample pos. */ VSUM(r->rop, r->rorg, r->ron, r->rot); /* leap-frog for pretend origin */ VSUM(r->rorg, r->rop, r->ron, r->rot); /* compute result */ r->revf = raytrace; m_normal(&Lamb, r); r->revf = rayirrad; } // compute first ray intersection only static void raycast(RAY *r) { if (!localhit(r, &thescene)) { if (r->ro == &Aftplane) { /* clipped */ r->ro = NULL; r->rot = FHUGE; } else sourcehit(r); } } // Add ray bundle to queue w/ optional 1st ray ID int RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0) { int nqueued = 0; RAY res; if (!Ready()) return -1; if (castonly && !cookedCall) error(INTERNAL, "EnqueueBundle() called in castonly mode without cookedCall"); if (!UpdateMode()) // update rendering mode if requested return -1; if (rID0 && curFlags&RTdoFIFO) error(INTERNAL, "ray number assignment unsupported with FIFO"); while (n-- > 0) { // queue each ray VCOPY(res.rorg, orig_direc[0]); VCOPY(res.rdir, orig_direc[1]); res.rmax = .0; orig_direc += 2; rayorigin(&res, PRIMARY, NULL, NULL); res.rno = rID0 ? (lastRayID = rID0++) : ++lastRayID; if (curFlags & RTimmIrrad) res.revf = rayirrad; else if (castonly) res.revf = raycast; double d = normalize(res.rdir); bool sendRes = (cookedCall != NULL); if (d > .0) { // direction vector is valid? if (curFlags & RTlimDist) res.rmax = d; if (((curFlags&RTdoFIFO) != 0) & (ray_pnprocs > 0)) { if (ray_fifo_in(&res) < 0) return -1; sendRes = false; } else { int rv = ProcessRay(&res); if (rv < 0) return -1; sendRes &= (rv > 0); } } else if (ThreadsAvailable() < NThreads() && FlushQueue() < 0) return -1; // may be dummy ray if (sendRes && (*cookedCall)(&res, ccData) < 0) return -1; nqueued++; } return nqueued; } // Finish pending rays and complete callbacks int RtraceSimulManager::FlushQueue() { if (curFlags & RTdoFIFO) { if (ray_pnprocs) return ray_fifo_flush(); return 0; } int nsent = 0; RAY res; while (WaitResult(&res)) { if (!cookedCall) continue; int rv = (*cookedCall)(&res, ccData); if (rv < 0) return -1; nsent += rv; } return nsent; }
