| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: RtraceSimulManager.cpp,v 2.16 2024/08/25 00:17:29 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* RtraceSimulManager.cpp
| 6 |
| 7 |
* Rtrace simulation manager class implementation
| 8 |
| 9 |
* Created by Greg Ward on 2/2/2023.
| 10 |
| 11 |
| 12 |
#include <unistd.h>
| 13 |
#include <ctype.h>
| 14 |
#include "RtraceSimulManager.h"
| 15 |
#include "source.h"
| 16 |
| 17 |
// Load octree and prepare renderer
| 18 |
bool
| 19 |
RadSimulManager::LoadOctree(const char *octn)
| 20 |
| 21 |
if (octname) { // already running?
| 22 |
if (octn && !strcmp(octn, octname))
| 23 |
return true;
| 24 |
Cleanup();
| 25 |
| 26 |
if (!octn) // don't support stdin octree
| 27 |
return false;
| 28 |
| 29 |
NewHeader(octn); // get octree header
| 30 |
ray_init((char *)octn);
| 31 |
return true;
| 32 |
| 33 |
| 34 |
// callback function for loading header
| 35 |
static int
| 36 |
add2header(char *str, void *p)
| 37 |
| 38 |
if (isheadid(str))
| 39 |
return 0;
| 40 |
if (isformat(str))
| 41 |
return 0;
| 42 |
| 43 |
return (*(RadSimulManager *)p).AddHeader(str);
| 44 |
| 45 |
| 46 |
// Prepare header from previous input (or clear)
| 47 |
// Normally called during octree load
| 48 |
bool
| 49 |
RadSimulManager::NewHeader(const char *inspec)
| 50 |
| 51 |
if (hlen) {
| 52 |
free(header); header = NULL; hlen = 0;
| 53 |
| 54 |
if (!inspec || !*inspec)
| 55 |
return false;
| 56 |
if (inspec[0] == '!') // save command as header?
| 57 |
return AddHeader(inspec+1);
| 58 |
// attempt to read from file
| 59 |
FILE *fp = fopen(inspec, "rb");
| 60 |
if (!fp) return false;
| 61 |
bool ok = (getheader(fp, add2header, this) >= 0);
| 62 |
fclose(fp);
| 63 |
return ok;
| 64 |
| 65 |
| 66 |
// Add a string to header (adds newline if missing)
| 67 |
bool
| 68 |
RadSimulManager::AddHeader(const char *str)
| 69 |
| 70 |
if (!str) return false;
| 71 |
int len = strlen(str);
| 72 |
while (len && (str[len-1] == '\n') | (str[len-1] == '\r'))
| 73 |
--len; // don't copy EOL(s)
| 74 |
if (!len)
| 75 |
return false;
| 76 |
if (hlen)
| 77 |
header = (char *)realloc(header, hlen+len+2);
| 78 |
else
| 79 |
header = (char *)malloc(len+2);
| 80 |
if (!header) {
| 81 |
hlen = 0; // XXX should report?
| 82 |
return false;
| 83 |
| 84 |
memcpy(header+hlen, str, len);
| 85 |
hlen += len;
| 86 |
header[hlen++] = '\n'; // add single EOL
| 87 |
header[hlen] = '\0';
| 88 |
return true;
| 89 |
| 90 |
| 91 |
// helper function to check for white-space and quotations
| 92 |
static int
| 93 |
check_special(const char *s)
| 94 |
| 95 |
int space_found = 0;
| 96 |
| 97 |
while (*s) {
| 98 |
if ((*s == '"') | (*s == '\''))
| 99 |
return *s; // quotes have priority
| 100 |
if (isspace(*s))
| 101 |
space_found = *s;
| 102 |
s++;
| 103 |
| 104 |
return space_found;
| 105 |
| 106 |
| 107 |
// Append program line to header
| 108 |
bool
| 109 |
RadSimulManager::AddHeader(int ac, char *av[])
| 110 |
| 111 |
if ((ac <= 0) | !av) return false;
| 112 |
int len = 0;
| 113 |
int n;
| 114 |
for (n = 0; n < ac; n++) {
| 115 |
if (!av[n]) return false;
| 116 |
len += strlen(av[n]) + 3;
| 117 |
| 118 |
if (hlen) // add to header
| 119 |
header = (char *)realloc(header, hlen+len+1);
| 120 |
else
| 121 |
header = (char *)malloc(len+1);
| 122 |
| 123 |
| 124 |
int c = check_special(av[n]);
| 125 |
len = strlen(av[n]);
| 126 |
if (c | !len) { // need to quote argument?
| 127 |
if ((c == '"') | (c == '\n')) c = '\'';
| 128 |
else c = '"';
| 129 |
header[hlen++] = c;
| 130 |
strcpy(header+hlen, av[n]);
| 131 |
hlen += len;
| 132 |
header[hlen++] = c;
| 133 |
} else {
| 134 |
| 135 |
hlen += len;
| 136 |
| 137 |
header[hlen++] = ' ';
| 138 |
| 139 |
header[hlen-1] = '\n'; // terminate line
| 140 |
| 141 |
return true;
| 142 |
| 143 |
| 144 |
// Look for specific header keyword, return value
| 145 |
const char *
| 146 |
RadSimulManager::GetHeadStr(const char *key, bool inOK) const
| 147 |
| 148 |
if (!key | !hlen || strchr(key, '\n'))
| 149 |
return NULL;
| 150 |
if (inOK) // skip leading spaces?
| 151 |
while (isspace(*key)) key++;
| 152 |
| 153 |
const int klen = strlen(key);
| 154 |
if (!klen)
| 155 |
return NULL;
| 156 |
const char * cp = header;
| 157 |
while (*cp) {
| 158 |
if (inOK) { // skip leading spaces?
| 159 |
while (isspace(*cp) && *cp++ != '\n')
| 160 |
| 161 |
if (cp[-1] == '\n')
| 162 |
continue;
| 163 |
| 164 |
if (!strncmp(cp, key, klen))
| 165 |
return cp+klen; // found it!
| 166 |
| 167 |
while (*cp && *cp++ != '\n')
| 168 |
| 169 |
| 170 |
return NULL;
| 171 |
| 172 |
| 173 |
// How many processors are available?
| 174 |
int
| 175 |
RadSimulManager::GetNCores()
| 176 |
| 177 |
return sysconf(_SC_NPROCESSORS_ONLN);
| 178 |
| 179 |
| 180 |
// Set number of computation threads (0 => #cores)
| 181 |
int
| 182 |
RadSimulManager::SetThreadCount(int nt)
| 183 |
| 184 |
if (!Ready())
| 185 |
return 0;
| 186 |
| 187 |
if (nt <= 0) nt = castonly ? 1 : GetNCores();
| 188 |
| 189 |
if (nt == 1)
| 190 |
ray_pclose(ray_pnprocs);
| 191 |
else if (nt < ray_pnprocs)
| 192 |
ray_pclose(ray_pnprocs - nt);
| 193 |
else if (nt > ray_pnprocs)
| 194 |
ray_popen(nt - ray_pnprocs);
| 195 |
| 196 |
return NThreads();
| 197 |
| 198 |
| 199 |
// Assign ray to subthread (fails if NThreads()<2)
| 200 |
bool
| 201 |
RadSimulManager::SplitRay(RAY *r)
| 202 |
| 203 |
if (!ray_pnprocs || ThreadsAvailable() < 1)
| 204 |
return false;
| 205 |
| 206 |
return (ray_psend(r) > 0);
| 207 |
| 208 |
| 209 |
// Process a ray (in subthread), optional result
| 210 |
bool
| 211 |
RadSimulManager::ProcessRay(RAY *r)
| 212 |
| 213 |
if (!Ready()) return false;
| 214 |
| 215 |
if (!ray_pnprocs) { // single-threaded mode?
| 216 |
samplendx++;
| 217 |
rayvalue(r);
| 218 |
return true;
| 219 |
| 220 |
int rv = ray_pqueue(r);
| 221 |
if (rv < 0) {
| 222 |
error(WARNING, "ray tracing process(es) died");
| 223 |
return false;
| 224 |
| 225 |
return (rv > 0);
| 226 |
| 227 |
| 228 |
// Wait for next result (or fail)
| 229 |
bool
| 230 |
RadSimulManager::WaitResult(RAY *r)
| 231 |
| 232 |
if (!ray_pnprocs)
| 233 |
return false;
| 234 |
| 235 |
return (ray_presult(r, 0) > 0);
| 236 |
| 237 |
| 238 |
// Close octree, free data, return status
| 239 |
int
| 240 |
RadSimulManager::Cleanup(bool everything)
| 241 |
| 242 |
NewHeader();
| 243 |
if (!ray_pnprocs)
| 244 |
ray_done(everything);
| 245 |
else
| 246 |
ray_pdone(everything);
| 247 |
return 0;
| 248 |
| 249 |
| 250 |
// How many threads are currently unoccupied?
| 251 |
int
| 252 |
RadSimulManager::ThreadsAvailable() const
| 253 |
| 254 |
if (!ray_pnprocs) return 1;
| 255 |
| 256 |
return ray_pnidle;
| 257 |
| 258 |
| 259 |
// Global pointer to simulation manager for trace call-back (only one)
| 260 |
static const RtraceSimulManager * ourRTsimMan = NULL;
| 261 |
| 262 |
// Call-back for trace output
| 263 |
void
| 264 |
RtraceSimulManager::RTracer(RAY *r)
| 265 |
| 266 |
(*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData);
| 267 |
| 268 |
| 269 |
// Call-back for FIFO output
| 270 |
int
| 271 |
RtraceSimulManager::Rfifout(RAY *r)
| 272 |
| 273 |
return (*ourRTsimMan->cookedCall)(r, ourRTsimMan->ccData);
| 274 |
| 275 |
| 276 |
// Check for changes to render flags & adjust accordingly
| 277 |
bool
| 278 |
RtraceSimulManager::UpdateMode()
| 279 |
| 280 |
rtFlags &= RTmask;
| 281 |
if (!cookedCall)
| 282 |
rtFlags &= ~RTdoFIFO;
| 283 |
if (!traceCall)
| 284 |
rtFlags &= ~RTtraceSources;
| 285 |
if (rtFlags & RTimmIrrad)
| 286 |
rtFlags &= ~RTlimDist;
| 287 |
| 288 |
int misMatch = rtFlags ^ curFlags;
| 289 |
// updates based on toggled flags
| 290 |
if (misMatch & RTtraceSources) {
| 291 |
if (rtFlags & RTtraceSources) {
| 292 |
for (int sn = 0; sn < nsources; sn++)
| 293 |
source[sn].sflags |= SFOLLOW;
| 294 |
} else // cannot undo this...
| 295 |
rtFlags |= RTtraceSources;
| 296 |
| 297 |
if (misMatch & RTdoFIFO && FlushQueue() < 0)
| 298 |
return false;
| 299 |
curFlags = rtFlags;
| 300 |
// update callbacks
| 301 |
if (traceCall)
| 302 |
trace = RTracer;
| 303 |
else if (trace == RTracer)
| 304 |
trace = NULL;
| 305 |
if (rtFlags & RTdoFIFO)
| 306 |
ray_fifo_out = Rfifout;
| 307 |
else if (ray_fifo_out == Rfifout)
| 308 |
ray_fifo_out = NULL;
| 309 |
if ((trace != RTracer) & (ray_fifo_out != Rfifout)) {
| 310 |
ourRTsimMan = NULL;
| 311 |
} else if (ourRTsimMan != this) {
| 312 |
if (ourRTsimMan)
| 313 |
error(WARNING, "Competing top-level simulation managers?");
| 314 |
ourRTsimMan = this;
| 315 |
| 316 |
return true;
| 317 |
| 318 |
| 319 |
extern "C" int m_normal(OBJREC *m, RAY *r);
| 320 |
| 321 |
// compute irradiance rather than radiance
| 322 |
static void
| 323 |
rayirrad(RAY *r)
| 324 |
| 325 |
/* pretend we hit surface */
| 326 |
r->rxt = r->rot = 1e-5;
| 327 |
VSUM(r->rop, r->rorg, r->rdir, r->rot);
| 328 |
r->ron[0] = -r->rdir[0];
| 329 |
r->ron[1] = -r->rdir[1];
| 330 |
r->ron[2] = -r->rdir[2];
| 331 |
r->rod = 1.0;
| 332 |
/* compute result */
| 333 |
r->revf = raytrace;
| 334 |
m_normal(&Lamb, r);
| 335 |
r->revf = rayirrad;
| 336 |
| 337 |
| 338 |
// compute first ray intersection only
| 339 |
static void
| 340 |
raycast(RAY *r)
| 341 |
| 342 |
if (!localhit(r, &thescene)) {
| 343 |
if (r->ro == &Aftplane) { /* clipped */
| 344 |
r->ro = NULL;
| 345 |
r->rot = FHUGE;
| 346 |
} else
| 347 |
sourcehit(r);
| 348 |
| 349 |
| 350 |
| 351 |
// Add ray bundle to queue w/ optional 1st ray ID
| 352 |
int
| 353 |
RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0)
| 354 |
| 355 |
int nqueued = 0;
| 356 |
RAY res;
| 357 |
| 358 |
if (!Ready())
| 359 |
return -1;
| 360 |
| 361 |
if (castonly && !cookedCall)
| 362 |
error(INTERNAL, "EnqueueBundle() called in castonly mode without cookedCall");
| 363 |
| 364 |
if (!UpdateMode()) // update rendering mode if requested
| 365 |
return -1;
| 366 |
| 367 |
if (rID0 && curFlags&RTdoFIFO)
| 368 |
error(INTERNAL, "Ray number assignment unsupported with FIFO");
| 369 |
| 370 |
while (n-- > 0) { // queue each ray
| 371 |
VCOPY(res.rorg, orig_direc[0]);
| 372 |
VCOPY(res.rdir, orig_direc[1]);
| 373 |
res.rmax = .0;
| 374 |
orig_direc += 2;
| 375 |
rayorigin(&res, PRIMARY, NULL, NULL);
| 376 |
res.rno = rID0 ? (lastRayID = rID0++) : ++lastRayID;
| 377 |
if (curFlags & RTimmIrrad)
| 378 |
res.revf = rayirrad;
| 379 |
else if (castonly)
| 380 |
res.revf = raycast;
| 381 |
double d = normalize(res.rdir);
| 382 |
bool sendRes = (cookedCall != NULL);
| 383 |
if (d > .0) { // direction vector is valid?
| 384 |
if (curFlags & RTlimDist)
| 385 |
res.rmax = d;
| 386 |
if (((curFlags&RTdoFIFO) != 0) & (ray_pnprocs > 0)) {
| 387 |
if (ray_fifo_in(&res) < 0)
| 388 |
return -1;
| 389 |
sendRes = false;
| 390 |
} else
| 391 |
sendRes &= ProcessRay(&res);
| 392 |
} else if (ThreadsAvailable() < NThreads() &&
| 393 |
FlushQueue() < 0)
| 394 |
return -1;
| 395 |
// may be dummy ray
| 396 |
if (sendRes && (*cookedCall)(&res, ccData) < 0)
| 397 |
return -1;
| 398 |
nqueued++;
| 399 |
| 400 |
return nqueued;
| 401 |
| 402 |
| 403 |
// Finish pending rays and complete callbacks
| 404 |
int
| 405 |
RtraceSimulManager::FlushQueue()
| 406 |
| 407 |
if (curFlags & RTdoFIFO) {
| 408 |
if (ray_pnprocs)
| 409 |
return ray_fifo_flush();
| 410 |
return 0;
| 411 |
| 412 |
int nsent = 0;
| 413 |
RAY res;
| 414 |
| 415 |
while (WaitResult(&res)) {
| 416 |
if (!cookedCall) continue;
| 417 |
int rv = (*cookedCall)(&res, ccData);
| 418 |
if (rv < 0) return -1;
| 419 |
nsent += rv;
| 420 |
| 421 |
return nsent;
| 422 |
