root/Development/ray/src/rt/RtraceSimulManager.cpp
Revision: 2.25
Committed: Tue Oct 21 16:12:05 2025 UTC (3 weeks ago) by greg
Changes since 2.24: +3 -3 lines
refactor: Consistent capitalization in error messages
2 static const char RCSid[] = "$Id: RtraceSimulManager.cpp,v 2.24 2024/11/20 17:46:25 greg Exp $";
5 * RtraceSimulManager.cpp
6 *
7 * Rtrace simulation manager class implementation
8 *
9 * Created by Greg Ward on 2/2/2023.
10 */
11
12 #include <unistd.h>
13 #include <ctype.h>
14 #include "RtraceSimulManager.h"
15 #include "source.h"
16
17 // Load octree and prepare renderer
18 bool
19 RadSimulManager::LoadOctree(const char *octn)
20 {
21 if (octname) { // already running?
22 if (octn && !strcmp(octn, octname))
23 return true;
24 Cleanup();
25 }
26 if (!octn) // don't support stdin octree
27 return false;
28
29 NewHeader(octn); // get octree header
30 ray_init((char *)octn);
31 return true;
32 }
33
34 // callback function for loading header
35 static int
36 add2header(char *str, void *p)
37 {
38 if (isheadid(str))
39 return 0;
40 if (isformat(str))
41 return 0;
42
43 return (*(RadSimulManager *)p).AddHeader(str);
44 }
45
46 // Prepare header from previous input (or clear)
47 // Normally called during octree load
48 bool
49 RadSimulManager::NewHeader(const char *inspec)
50 {
51 if (hlen) {
52 free(header); header = NULL; hlen = 0;
53 }
54 if (!inspec || !*inspec)
55 return false;
56 if (inspec[0] == '!') // save command as header?
57 return AddHeader(inspec+1);
58 // attempt to read from file
59 FILE *fp = fopen(inspec, "rb");
60 if (!fp) return false;
61 bool ok = (getheader(fp, add2header, this) >= 0);
62 fclose(fp);
63 return ok;
64 }
65
66 // Add a string to header (adds newline if missing)
67 bool
68 RadSimulManager::AddHeader(const char *str)
69 {
70 if (!str) return false;
71 int len = strlen(str);
72 while (len && (str[len-1] == '\n') | (str[len-1] == '\r'))
73 --len; // don't copy EOL(s)
74 if (!len)
75 return false;
76 if (hlen)
77 header = (char *)realloc(header, hlen+len+2);
78 else
79 header = (char *)malloc(len+2);
80 if (!header) {
81 hlen = 0; // XXX should report?
82 return false;
83 }
84 memcpy(header+hlen, str, len);
85 hlen += len;
86 header[hlen++] = '\n'; // add single EOL
87 header[hlen] = '\0';
88 return true;
89 }
90
91 // helper function to check for white-space and quotations
92 static int
93 check_special(const char *s)
94 {
95 int space_found = 0;
96
97 while (*s) {
98 if ((*s == '"') | (*s == '\''))
99 return *s; // quotes have priority
100 if (isspace(*s))
101 space_found = *s;
102 s++;
103 }
104 return space_found;
105 }
106
107 // Append program line to header
108 bool
109 RadSimulManager::AddHeader(int ac, char *av[])
110 {
111 if ((ac <= 0) | !av) return false;
112 int len = 0;
113 int n;
114 for (n = 0; n < ac; n++) {
115 if (!av[n]) return false;
116 len += strlen(av[n]) + 3;
117 }
118 if (hlen) // add to header
119 header = (char *)realloc(header, hlen+len+1);
120 else
121 header = (char *)malloc(len+1);
122
123 for (n = 0; n < ac; n++) {
124 int c = check_special(av[n]);
125 len = strlen(av[n]);
126 if (c | !len) { // need to quote argument?
127 if ((c == '"') | (c == '\n')) c = '\'';
128 else c = '"';
129 header[hlen++] = c;
130 strcpy(header+hlen, av[n]);
131 hlen += len;
132 header[hlen++] = c;
133 } else {
134 strcpy(header+hlen, av[n]);
135 hlen += len;
136 }
137 header[hlen++] = ' ';
138 }
139 header[hlen-1] = '\n'; // terminate line
140 header[hlen] = '\0';
141 return true;
142 }
143
144 // Look for specific header keyword, return value
145 const char *
146 RadSimulManager::GetHeadStr(const char *key, bool inOK) const
147 {
148 if (!key | !hlen || strchr(key, '\n'))
149 return NULL;
150 if (inOK) // skip leading spaces?
151 while (isspace(*key)) key++;
152
153 const int klen = strlen(key);
154 if (!klen)
155 return NULL;
156 const char * cp = header;
157 while (*cp) {
158 if (inOK) { // skip leading spaces?
159 while (isspace(*cp) && *cp++ != '\n')
160 ;
161 if (cp[-1] == '\n')
162 continue;
163 }
164 if (!strncmp(cp, key, klen))
165 return cp+klen; // found it!
166
167 while (*cp && *cp++ != '\n')
168 ;
169 }
170 return NULL;
171 }
172
173 // How many processors are available?
174 int
175 RadSimulManager::GetNCores()
176 {
177 return sysconf(_SC_NPROCESSORS_ONLN);
178 }
179
180 // Set number of computation threads (0 => #cores)
181 int
182 RadSimulManager::SetThreadCount(int nt)
183 {
184 if (!Ready()) return 0;
185
186 if (nt <= 0) nt = castonly ? 1 : GetNCores();
187
188 if (nt == 1)
189 ray_pclose(ray_pnprocs);
190 else if (nt < ray_pnprocs)
191 ray_pclose(ray_pnprocs - nt);
192 else if (nt > ray_pnprocs)
193 ray_popen(nt - ray_pnprocs);
194
195 return NThreads();
196 }
197
198 // Process a ray (in subthread), optional result
199 int
200 RadSimulManager::ProcessRay(RAY *r)
201 {
202 if (!Ready()) return -1;
203
204 if (!ray_pnprocs) { // single-threaded mode?
205 samplendx++;
206 rayvalue(r);
207 return 1;
208 }
209 return ray_pqueue(r);
210 }
211
212 // Wait for next result (or fail)
213 bool
214 RadSimulManager::WaitResult(RAY *r)
215 {
216 if (!ray_pnprocs)
217 return false;
218
219 return (ray_presult(r, 0) > 0);
220 }
221
222 // Close octree, free data, return status
223 int
224 RadSimulManager::Cleanup(bool everything)
225 {
226 if (ray_pnprocs < 0)
227 return 0; // skip in child process
228 NewHeader();
229 if (!ray_pnprocs)
230 ray_done(everything);
231 else
232 ray_pdone(everything);
233 return 0;
234 }
235
236 // Global pointer to simulation manager for trace call-back (only one)
237 static const RtraceSimulManager * ourRTsimMan = NULL;
238
239 // Call-back for trace output
240 void
241 RtraceSimulManager::RTracer(RAY *r)
242 {
243 (*ourRTsimMan->traceCall)(r, ourRTsimMan->tcData);
244 }
245
246 // Call-back for FIFO output
247 int
248 RtraceSimulManager::Rfifout(RAY *r)
249 {
250 return (*ourRTsimMan->cookedCall)(r, ourRTsimMan->ccData);
251 }
252
253 // Check for changes to render flags & adjust accordingly
254 bool
255 RtraceSimulManager::UpdateMode()
256 {
257 if (!cookedCall)
258 rtFlags &= ~RTdoFIFO;
259 if (!traceCall)
260 rtFlags &= ~RTtraceSources;
261 if (rtFlags & RTimmIrrad)
262 rtFlags &= ~RTlimDist;
263
264 int misMatch = (rtFlags ^ curFlags) & RTmask;
265 // updates based on toggled flags
266 if (((misMatch & RTtraceSources) != 0) & (nsources > 0)) {
267 int nt = NThreads();
268 if (nt > 1) {
269 if (FlushQueue() < 0)
270 return false;
271 SetThreadCount(1);
272 }
273 int sn = nsources;
274 if (rtFlags & RTtraceSources) {
275 srcFollowed.NewBitMap(nsources);
276 while (sn--) {
277 if (source[sn].sflags & SFOLLOW)
278 continue;
279 source[sn].sflags |= SFOLLOW;
280 srcFollowed.Set(sn);
281 }
282 } else {
283 while (sn--)
284 if (srcFollowed.Check(sn))
285 source[sn].sflags &= ~SFOLLOW;
286 srcFollowed.NewBitMap(0);
287 }
288 if (nt > 1) SetThreadCount(nt);
289 }
290 if (misMatch & RTdoFIFO && FlushQueue() < 0)
291 return false;
292 curFlags = rtFlags;
293 // update callbacks
294 if (traceCall)
295 trace = RTracer;
296 else if (trace == RTracer)
297 trace = NULL;
298 if (rtFlags & RTdoFIFO)
299 ray_fifo_out = Rfifout;
300 else if (ray_fifo_out == Rfifout)
301 ray_fifo_out = NULL;
302 if ((trace != RTracer) & (ray_fifo_out != Rfifout)) {
303 ourRTsimMan = NULL;
304 } else if (ourRTsimMan != this) {
305 if (ourRTsimMan)
306 error(WARNING, "competing top-level simulation managers?");
307 ourRTsimMan = this;
308 }
309 return true;
310 }
311
312 extern "C" int m_normal(OBJREC *m, RAY *r);
313
314 // compute irradiance rather than radiance
315 static void
316 rayirrad(RAY *r)
317 {
318 /* orientation -> normal */
319 VCOPY(r->ron, r->rdir);
320 /* pretend normal incidence */
321 r->rdir[0] = -r->ron[0];
322 r->rdir[1] = -r->ron[1];
323 r->rdir[2] = -r->ron[2];
324 r->rod = 1.0;
325 /* counterfeit other params */
326 r->rxt = r->rot = 1e-4;
327 /* move comfortably above sample pos. */
328 VSUM(r->rop, r->rorg, r->ron, r->rot);
329 /* leap-frog for pretend origin */
330 VSUM(r->rorg, r->rop, r->ron, r->rot);
331 /* compute result */
332 r->revf = raytrace;
333 m_normal(&Lamb, r);
334 r->revf = rayirrad;
335 }
336
337 // compute first ray intersection only
338 static void
339 raycast(RAY *r)
340 {
341 if (!localhit(r, &thescene)) {
342 if (r->ro == &Aftplane) { /* clipped */
343 r->ro = NULL;
344 r->rot = FHUGE;
345 } else
346 sourcehit(r);
347 }
348 }
349
350 // Add ray bundle to queue w/ optional 1st ray ID
351 int
352 RtraceSimulManager::EnqueueBundle(const FVECT orig_direc[], int n, RNUMBER rID0)
353 {
354 int nqueued = 0;
355 RAY res;
356
357 if (!Ready()) return -1;
358
359 if (castonly && !cookedCall)
360 error(INTERNAL, "EnqueueBundle() called in castonly mode without cookedCall");
361
362 if (!UpdateMode()) // update rendering mode if requested
363 return -1;
364
365 if (rID0 && curFlags&RTdoFIFO)
366 error(INTERNAL, "ray number assignment unsupported with FIFO");
367
368 while (n-- > 0) { // queue each ray
369 VCOPY(res.rorg, orig_direc[0]);
370 VCOPY(res.rdir, orig_direc[1]);
371 res.rmax = .0;
372 orig_direc += 2;
373 rayorigin(&res, PRIMARY, NULL, NULL);
374 res.rno = rID0 ? (lastRayID = rID0++) : ++lastRayID;
375 if (curFlags & RTimmIrrad)
376 res.revf = rayirrad;
377 else if (castonly)
378 res.revf = raycast;
379 double d = normalize(res.rdir);
380 bool sendRes = (cookedCall != NULL);
381 if (d > .0) { // direction vector is valid?
382 if (curFlags & RTlimDist)
383 res.rmax = d;
384 if (((curFlags&RTdoFIFO) != 0) & (ray_pnprocs > 0)) {
385 if (ray_fifo_in(&res) < 0)
386 return -1;
387 sendRes = false;
388 } else {
389 int rv = ProcessRay(&res);
390 if (rv < 0)
391 return -1;
392 sendRes &= (rv > 0);
393 }
394 } else if (ThreadsAvailable() < NThreads() &&
395 FlushQueue() < 0)
396 return -1;
397 // may be dummy ray
398 if (sendRes && (*cookedCall)(&res, ccData) < 0)
399 return -1;
400 nqueued++;
401 }
402 return nqueued;
403 }
404
405 // Finish pending rays and complete callbacks
406 int
407 RtraceSimulManager::FlushQueue()
408 {
409 if (curFlags & RTdoFIFO) {
410 if (ray_pnprocs)
411 return ray_fifo_flush();
412 return 0;
413 }
414 int nsent = 0;
415 RAY res;
416
417 while (WaitResult(&res)) {
418 if (!cookedCall) continue;
419 int rv = (*cookedCall)(&res, ccData);
420 if (rv < 0) return -1;
421 nsent += rv;
422 }
423 return nsent;
424 }
