--- ray/src/rt/RpictSimulManager.cpp 2024/08/18 17:24:48 2.3 +++ ray/src/rt/RpictSimulManager.cpp 2024/08/25 03:13:07 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: RpictSimulManager.cpp,v 2.3 2024/08/18 17:24:48 greg Exp $"; +static const char RCSid[] = "$Id: RpictSimulManager.cpp,v 2.9 2024/08/25 03:13:07 greg Exp $"; #endif /* * RpictSimulManager.cpp @@ -9,6 +9,8 @@ static const char RCSid[] = "$Id: RpictSimulManager.cp * Created by Greg Ward on 07/11/2024. */ +#define DEBUG 1 // XXX temporary! + #include #include "platform.h" #include "RpictSimulManager.h" @@ -196,14 +198,15 @@ RpictSimulManager::SetTile(const int ti[2]) bool RpictSimulManager::ComputePixel(int x, int y) { - static const SCOLOR scBlack = {0}; + DCHECK(doneMap.OffBitMap(x,y), + CONSISTENCY, "illegal pixel index in ComputPixel()"); int i; FVECT rodir[2]; double hpos = (x+pixjitter())/TWidth(); double vpos = (y+pixjitter())/THeight(); double dlim = viewray(rodir[0], rodir[1], &tvw, hpos, vpos); if (dlim < -FTINY) { // off view? - pacc.SetPixel(x, y, scBlack); + pacc.SetPixel(x, y, scblack); doneMap.Set(x, y); return true; } @@ -268,9 +271,11 @@ RpictSimulManager::FillSquare(const int x, const int y float dist[4]; int i, j; // assumes 4 corners are valid! - for (i = 4; i--; ) + for (i = 4; i--; ) { + DCHECK(!doneMap.Check(x+noff[i][0], y+noff[i][1]), + CONSISTENCY, "inclusion of bad pixel in FillSquare()"); pacc.GetPixel(x+noff[i][0], y+noff[i][1], pval[i], &dist[i]); - + } i = abs(noff[1][0]-noff[0][0]); j = abs(noff[1][1]-noff[0][1]); // i==j for diamond fill const int slen = (i > j) ? i : j; @@ -328,13 +333,9 @@ RpictSimulManager::FillSquare(const int x, const int y // helper function to set up quincunx sampling static void -SetQuincunx(ABitMap2 *bmp2, int noff[4][2], const int spc, const bool odd) +SetQuincunx(ABitMap2 *bmp2, int noff[4][2], const int spc, bool odd, int x0, int y) { - for (int y = 0; y < bmp2->Height(); y += spc>>1) - for (int x = (odd^(y&1))*(spc>>1); x < bmp2->Width(); x += spc) - bmp2->Set(x, y); - // order neighbors CCW - if (odd) { + if (odd) { // order neighbors CCW noff[0][0] = spc>>1; noff[0][1] = 0; noff[1][0] = 0; noff[1][1] = spc>>1; noff[2][0] = -(spc>>1); noff[2][1] = 0; @@ -345,11 +346,27 @@ SetQuincunx(ABitMap2 *bmp2, int noff[4][2], const int noff[2][0] = -(spc>>1); noff[2][1] = -(spc>>1); noff[3][0] = spc>>1; noff[3][1] = -(spc>>1); } + int nsteps; // non-negative range + if (x0 < -(spc>>1)) { + nsteps = (spc-1 - x0 - (spc>>1))/spc; + x0 += nsteps*spc; + } + if (y < 0) { // get past y==0 + nsteps = ((spc>>1)-1 - y)/(spc>>1); + y += nsteps*(spc>>1); + odd ^= nsteps&1; + } + while (y < bmp2->Height()) { + for (int x = x0 + odd*(spc>>1); x < bmp2->Width(); x += spc) + bmp2->Set(x, y); + y += spc>>1; + odd = !odd; + } } // Render (or finish rendering) current tile bool -RpictSimulManager::RenderRect() +RpictSimulManager::RenderRect(const int x0, const int y0) { if (!tvw.type || !Ready()) { error(INTERNAL, "need octree and view for RenderRect()"); @@ -359,14 +376,12 @@ RpictSimulManager::RenderRect() int sp2 = ceil(log2((TWidth()>THeight() ? TWidth() : THeight()) - 1.)); int layer = 0; int x, y; -// fprintf(stderr, "Rendering %dx%d tile with psample=%d, maxdiff=%.3f ...\n", -// TWidth(), THeight(), psample, maxdiff); while (sp2 > 0) { ABitMap2 sampMap(TWidth(), THeight()); int noff[4][2]; if ((prCB != NULL) & (barPix == NULL)) (*prCB)(100.*doneMap.SumTotal()/doneMap.Width()/doneMap.Height()); - SetQuincunx(&sampMap, noff, 1< 0) { -// fprintf(stderr, "At y=%d, source drawing %s...\n", ytop, parr ? "ON" : "OFF"); if (prCB) (*prCB)(100.*(GetHeight()-ytop)/GetHeight()); - if (!RenderRect()) // render this bar + if (!RenderRect(0, THeight()-ytop)) // render this bar return false; int nlines = lastOut - ytop + THeight(); if (nlines > ytop) @@ -628,22 +674,14 @@ RpictSimulManager::RenderBelow(int ytop, const int vst return true; } -/* - * Render and write a frame to the named file - * Include any header lines set prior to call - * Picture file must not already exist - * Write pixels to stdout if !pfname - * Write depth to a command if dfname[0]=='!' - */ +// Open new output picture file (and optional depth file) RenderDataType -RpictSimulManager::RenderFrame(const char *pfname, RenderDataType dt, const char *dfname) +RpictSimulManager::NewOutput(FILE *pdfp[2], const char *pfname, + RenderDataType dt, const char *dfname) { - int fd = 1; - FILE * pfp = NULL; - FILE * dfp = NULL; - + pdfp[0] = pdfp[1] = NULL; if (!RDTcolorT(dt)) - error(INTERNAL, "botched color output type in RenderFrame()"); + error(INTERNAL, "missing color output type in NewOutput()"); if (NCSAMP == 3) { if (RDTcolorT(dt) == RDTscolr) dt = RDTnewCT(dt, prims==xyzprims ? RDTxyze : RDTrgbe); @@ -651,7 +689,8 @@ RpictSimulManager::RenderFrame(const char *pfname, Ren dt = RDTnewCT(dt, prims==xyzprims ? RDTxyz : RDTrgb); } if (!RDTdepthT(dt) ^ !dfname) - error(INTERNAL, "depth output requires file name and type in RenderFrame()"); + error(INTERNAL, "depth output requires file name and type in NewOutput()"); + int fd = 1; if (pfname) { // open picture output file if (pfname[0] == '!') { error(INTERNAL, "writing picture to a command not supported"); @@ -664,102 +703,139 @@ RpictSimulManager::RenderFrame(const char *pfname, Ren sprintf(errmsg, "cannot open picture file '%s'", pfname); error(SYSTEM, errmsg); } - return RDTnone; // expected in parallel sequence + return RDTnone; // may be expected in sequence run } if (fd == 1) - pfp = stdout; - else if (!(pfp = fdopen(fd, "w"))) + pdfp[0] = stdout; + else if (!(pdfp[0] = fdopen(fd, "w"))) error(SYSTEM, "failure calling fdopen()"); - SET_FILE_BINARY(pfp); // write picture header - if ((pfp != stdout) | (frameNo <= 1)) { - newheader("RADIANCE", pfp); - fputs(GetHeader(), pfp); + SET_FILE_BINARY(pdfp[0]); // write picture header + if ((pdfp[0] != stdout) | (frameNo <= 1)) { + newheader("RADIANCE", pdfp[0]); + fputs(GetHeader(), pdfp[0]); } - fputs(VIEWSTR, pfp); fprintview(&vw, pfp); fputc('\n', pfp); + fputs(VIEWSTR, pdfp[0]); fprintview(&vw, pdfp[0]); fputc('\n', pdfp[0]); if (frameNo > 0) - fprintf(pfp, "FRAME=%d\n", frameNo); + fprintf(pdfp[0], "FRAME=%d\n", frameNo); double pasp = viewaspect(&vw) * GetWidth() / GetHeight(); if ((0.99 > pasp) | (pasp > 1.01)) - fputaspect(pasp, pfp); - fputnow(pfp); + fputaspect(pasp, pdfp[0]); + fputnow(pdfp[0]); switch (RDTcolorT(dt)) { // set primaries and picture format case RDTrgbe: if (!prims | (prims == xyzprims)) prims = stdprims; - fputprims(prims, pfp); - fputformat(COLRFMT, pfp); + fputprims(prims, pdfp[0]); + fputformat(COLRFMT, pdfp[0]); break; case RDTxyze: prims = xyzprims; - fputformat(CIEFMT, pfp); + fputformat(CIEFMT, pdfp[0]); break; case RDTscolr: prims = NULL; - fputwlsplit(WLPART, pfp); - fputncomp(NCSAMP, pfp); - fputformat(SPECFMT, pfp); + fputwlsplit(WLPART, pdfp[0]); + fputncomp(NCSAMP, pdfp[0]); + fputformat(SPECFMT, pdfp[0]); break; case RDTrgb: if (!prims | (prims == xyzprims)) prims = stdprims; - fputprims(prims, pfp); - fputncomp(3, pfp); - fputendian(pfp); - fputformat("float", pfp); + fputprims(prims, pdfp[0]); + fputncomp(3, pdfp[0]); + fputendian(pdfp[0]); + fputformat("float", pdfp[0]); break; case RDTxyz: prims = xyzprims; - fputprims(prims, pfp); - fputncomp(3, pfp); - fputendian(pfp); - fputformat("float", pfp); + fputprims(prims, pdfp[0]); + fputncomp(3, pdfp[0]); + fputendian(pdfp[0]); + fputformat("float", pdfp[0]); break; case RDTscolor: prims = NULL; - fputwlsplit(WLPART, pfp); - fputncomp(NCSAMP, pfp); - fputendian(pfp); - fputformat("float", pfp); + fputwlsplit(WLPART, pdfp[0]); + fputncomp(NCSAMP, pdfp[0]); + fputendian(pdfp[0]); + fputformat("float", pdfp[0]); break; - default:; + default:; // pro forma - caught this above } - fputc('\n', pfp); // end picture header - fprtresolu(GetWidth(), GetHeight(), pfp); - if (dfname) { + fputc('\n', pdfp[0]); // flush picture header + if (fflush(pdfp[0]) == EOF) { + sprintf(errmsg, "cannot write header to picture '%s'", pfname); + error(SYSTEM, errmsg); + fclose(pdfp[0]); + pdfp[0] = NULL; + return RDTnone; + } + if (dfname) { // open depth output if (dfname[0] == '!') - dfp = popen(dfname+1, "w"); + pdfp[1] = popen(dfname+1, "w"); else - dfp = fopen(dfname, "w"); - if (!dfp) { + pdfp[1] = fopen(dfname, "w"); + if (!pdfp[1]) { sprintf(errmsg, "cannot open depth output '%s'", dfname); error(SYSTEM, errmsg); + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } - SET_FILE_BINARY(dfp); + SET_FILE_BINARY(pdfp[1]); } if (RDTdepthT(dt) == RDTdshort) { // write header for 16-bit depth? - newheader("RADIANCE", dfp); - fputs(GetHeader(), dfp); - fputs(VIEWSTR, dfp); fprintview(&vw, dfp); fputc('\n', dfp); - fputs(DEPTHSTR, dfp); fputs(dunit, dfp); fputc('\n', dfp); - fputformat(DEPTH16FMT, dfp); - fputc('\n', dfp); // end-of-info - fprtresolu(GetWidth(), GetHeight(), dfp); + newheader("RADIANCE", pdfp[1]); + fputs(GetHeader(), pdfp[1]); + fputs(VIEWSTR, pdfp[1]); fprintview(&vw, pdfp[1]); fputc('\n', pdfp[1]); + fputs(DEPTHSTR, pdfp[1]); fputs(dunit, pdfp[1]); fputc('\n', pdfp[1]); + fputformat(DEPTH16FMT, pdfp[1]); + fputc('\n', pdfp[1]); // end-of-info + if (fflush(pdfp[1]) == EOF) { + sprintf(errmsg, "cannot write header to '%s'", dfname); + error(SYSTEM, errmsg); + fclose(pdfp[0]); fclose(pdfp[1]); + pdfp[0] = pdfp[1] = NULL; + return RDTnone; + } } - const int bheight = (psample > 1) ? int(2*psample+.99) : 4; - const int vstep = bheight >> (psample > 1); + return dt; // ready to roll +} +/* + * Render and write a frame to the named file + * Include any header lines set prior to call + * Picture file must not exist + * Write pixels to stdout if !pfname + * Write depth to a command if dfname[0]=='!' + */ +RenderDataType +RpictSimulManager::RenderFrame(const char *pfname, RenderDataType dt, const char *dfname) +{ + FILE *pdfp[2]; + // prepare output file(s) + dt = NewOutput(pdfp, pfname, dt, dfname); + if (dt == RDTnone) + return RDTnone; + // add resolution string(s) + fprtresolu(GetWidth(), GetHeight(), pdfp[0]); + if (RDTdepthT(dt) == RDTdshort) + fprtresolu(GetWidth(), GetHeight(), pdfp[1]); + + const int bheight = (psample > 1) ? int(4*psample+.99) : 8; + const int vstep = bheight >> (psample > 1); + NewBar(bheight); // render frame if we can - if (!RenderBelow(GetHeight(), vstep, pfp, dt, dfp)) { - fclose(pfp); - if (dfp) (dfname[0] == '!') ? pclose(dfp) : fclose(dfp); + if (!RenderBelow(GetHeight(), vstep, pdfp[0], dt, pdfp[1])) { + fclose(pdfp[0]); + if (pdfp[1]) (dfname[0] == '!') ? pclose(pdfp[1]) : fclose(pdfp[1]); Cleanup(); return RDTnone; } NewBar(); // clean up and return - if (pfp != stdout) - fclose(pfp); - if (dfp) { + if (pdfp[0] != stdout) + fclose(pdfp[0]); + if (pdfp[1]) { if (dfname[0] == '!') { - int status = pclose(dfp); + int status = pclose(pdfp[1]); if (status) { sprintf(errmsg, "depth output (%s) error status: %d", dfname, status); @@ -767,13 +843,13 @@ RpictSimulManager::RenderFrame(const char *pfname, Ren return RDTnone; } } else - fclose(dfp); + fclose(pdfp[1]); } return dt; } // passed struct for header line callback -struct HeaderInfo { +static struct HeaderInfo { char fmt[MAXFMTLEN]; char depth_unit[32]; int ncomp; @@ -794,7 +870,7 @@ struct HeaderInfo { gotview = false; endianMatch = true; } -}; +} hinfo; // XXX single copy to hold custom primitives // helper function checks header line and records req. info. static int @@ -836,50 +912,47 @@ head_check(char *s, void *p) return 0; } -// Resume partially finished rendering -// Picture file must exist +// Reopen output file(s), leaving pointers at end of (each) header RenderDataType -RpictSimulManager::ResumeFrame(const char *pfname, const char *dfname) +RpictSimulManager::ReopenOutput(FILE *pdfp[2], const char *pfname, const char *dfname) { - if (!pfname || pfname[0] == '!') - return RDTnone; + extern const char HDRSTR[]; + if (!pfname || pfname[0] == '!') { + pdfp[0] = pdfp[1] = NULL; + return RDTnone; + } RenderDataType dt = RDTnone; - FILE * dfp = NULL; - FILE * pfp = fopen(pfname, "r+"); - if (!pfp) { + pdfp[1] = NULL; + pdfp[0] = fopen(pfname, "r+"); + if (!pdfp[0]) { sprintf(errmsg, "cannot reopen output picture '%s'", pfname); error(SYSTEM, errmsg); return RDTnone; } - SET_FILE_BINARY(pfp); - HeaderInfo hinfo; // read header information & dimensions - RESOLU res; - if (getheader(pfp, head_check, &hinfo) < 0) { - fclose(pfp); + SET_FILE_BINARY(pdfp[0]); // read header information + if (getheader(pdfp[0], head_check, &hinfo) < 0) { + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } - if (!fgetsresolu(&res, pfp) || res.rt != PIXSTANDARD) { - sprintf(errmsg, "missing/bad resolution for '%s'", pfname); - error(USER, errmsg); - fclose(pfp); - return RDTnone; - } if (!hinfo.gotview) { sprintf(errmsg, "missing view for '%s'", pfname); error(USER, errmsg); - fclose(pfp); + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } if (hinfo.ncomp < 3) { sprintf(errmsg, "bad # components (%d) in '%s'", hinfo.ncomp, pfname); error(USER, errmsg); - fclose(pfp); + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } - int bytesPer = 0; // complicated part to set rendering/output space + // set rendering/output space if (!strcmp(hinfo.fmt, COLRFMT)) { - prims = hinfo.prims; + prims = hinfo.prims; // XXX static array int n = 8*hinfo.gotprims; while (n--) if (!FABSEQ(hinfo.prims[0][n], stdprims[0][n])) @@ -895,27 +968,28 @@ RpictSimulManager::ResumeFrame(const char *pfname, con sprintf(errmsg, "incompatible sample count (%d) in '%s'", hinfo.ncomp, pfname); error(USER, errmsg); - fclose(pfp); + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } - NCSAMP = hinfo.ncomp; // overrides global setting + NCSAMP = hinfo.ncomp; // overrides global setting prims = NULL; dt = RDTnewCT(dt, RDTscolr); - bytesPer = hinfo.ncomp + 1; // XXX assumes no compression } else if (!strcmp(hinfo.fmt, "float")) { if (!hinfo.endianMatch) { sprintf(errmsg, "incompatible byte ordering in '%s'", pfname); error(USER, errmsg); - fclose(pfp); + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } if (hinfo.ncomp == 3) { - prims = hinfo.prims; // custom primaries? + prims = hinfo.prims; // custom primaries? int n = 8*hinfo.gotprims; while (n--) if (!FABSEQ(hinfo.prims[0][n], stdprims[0][n])) break; - if (n < 0) // standard primaries? + if (n < 0) // standard primaries? prims = stdprims; else if (hinfo.gotprims) { // or check if XYZ for (n = 8; n--; ) @@ -933,132 +1007,197 @@ RpictSimulManager::ResumeFrame(const char *pfname, con prims = NULL; dt = RDTnewCT(dt, RDTscolor); } - bytesPer = sizeof(float)*hinfo.ncomp; } else { sprintf(errmsg, "unknown format (%s) for '%s'", hinfo.fmt, pfname); error(USER, errmsg); - fclose(pfp); + fclose(pdfp[0]); + pdfp[0] = NULL; return RDTnone; } + if (!dfname) // no depth file? + return dt; + + if (dfname[0] == '!') { + error(USER, "depth data cannot be reloaded from command"); + fclose(pdfp[0]); + pdfp[0] = NULL; + return RDTnone; + } + pdfp[1] = fopen(dfname, "r+"); + if (!pdfp[1]) { + sprintf(errmsg, "cannot reopen depth file '%s'", dfname); + error(SYSTEM, errmsg); + fclose(pdfp[0]); + pdfp[0] = NULL; + return RDTnone; + } + SET_FILE_BINARY(pdfp[1]); + int n, len = strlen(HDRSTR); + char buf[32]; // sniff for 16-bit header + if (getbinary(buf, 1, len+1, pdfp[1]) < len+1) { + sprintf(errmsg, "empty depth file '%s'", dfname); + error(SYSTEM, errmsg); + fclose(pdfp[0]); fclose(pdfp[1]); + pdfp[0] = pdfp[1] = NULL; + return RDTnone; + } + for (n = 0; n < len; n++) + if (buf[n] != HDRSTR[n]) + break; // not a Radiance header + rewind(pdfp[1]); + if ((n < len) | !isprint(buf[len])) + return RDTnewDT(dt, RDTdfloat); + + HeaderInfo dinfo; // thinking it's 16-bit encoded + if (getheader(pdfp[1], head_check, &dinfo) < 0) + sprintf(errmsg, "bad header in encoded depth file '%s'", + dfname); + else if (strcmp(dinfo.fmt, DEPTH16FMT)) + sprintf(errmsg, "wrong format (%s) for depth file '%s'", + dinfo.fmt, dfname); + else if (!SetReferenceDepth(dinfo.depth_unit)) + sprintf(errmsg, "bad/missing reference depth (%s) in '%s'", + dinfo.depth_unit, dfname); + else + errmsg[0] = '\0'; + + if (errmsg[0]) { + error(USER, errmsg); + fclose(pdfp[1]); fclose(pdfp[0]); + pdfp[0] = pdfp[1] = NULL; + return RDTnone; + } + return RDTnewDT(dt, RDTdshort); +} + +// Resume partially finished rendering +// Picture file must exist +RenderDataType +RpictSimulManager::ResumeFrame(const char *pfname, const char *dfname) +{ + FILE *pdfp[2]; + + RenderDataType dt = ReopenOutput(pdfp, pfname, dfname); + if (dt == RDTnone) + return RDTnone; + + int bytesPer = 0; // figure out how far we got... + switch (RDTcolorT(dt)) { + case RDTrgbe: + case RDTxyze: + break; + case RDTscolr: + bytesPer = hinfo.ncomp + 1; // XXX assumes no compression + break; + case RDTrgb: + case RDTxyz: + bytesPer = sizeof(float)*3; + break; + case RDTscolor: + bytesPer = sizeof(float)*hinfo.ncomp; + break; + default: + sprintf(errmsg, "unknown format (%s) for '%s'", hinfo.fmt, pfname); + error(USER, errmsg); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); + return RDTnone; + } + RESOLU res; + if (!fgetsresolu(&res, pdfp[0]) || res.rt != PIXSTANDARD) { + sprintf(errmsg, "missing/bad resolution for '%s'", pfname); + error(USER, errmsg); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); + return RDTnone; + } vw.type = 0; // set up new (unreferenced) frame frameNo = 0; int hvdim[2] = {res.xr, res.yr}; double noAdj = 0; if (!NewFrame(hinfo.vw, hvdim, &noAdj) || (hvdim[0] != res.xr) | (hvdim[1] != res.yr)) { - fclose(pfp); + error(CONSISTENCY, "unexpected resolution change in ResumeFrame()"); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); return RDTnone; } - long dataStart = ftell(pfp); // picture starting point + long dataStart = ftell(pdfp[0]); // picture starting point if (dataStart < 0) { sprintf(errmsg, "cannot seek on '%s'", pfname); error(SYSTEM, errmsg); - fclose(pfp); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); return RDTnone; } long doneScans = 0; if (bytesPer) { // fixed-width records? - fseek(pfp, 0, SEEK_END); - long dataEnd = ftell(pfp); + fseek(pdfp[0], 0, SEEK_END); + long dataEnd = ftell(pdfp[0]); doneScans = (dataEnd - dataStart)/(bytesPer*GetWidth()); if (dataEnd-dataStart > bytesPer*GetWidth()*doneScans) - fseek(pfp, dataStart + bytesPer*GetWidth()*doneScans, SEEK_SET); + fseek(pdfp[0], dataStart + bytesPer*GetWidth()*doneScans, SEEK_SET); } else { // else get compressed scanlines COLR * scan = (COLR *)tempbuffer(sizeof(COLR)*GetWidth()); - while (freadcolrs(scan, GetWidth(), pfp) >= 0) + while (freadcolrs(scan, GetWidth(), pdfp[0]) >= 0) ++doneScans; - if (!feof(pfp)) { + if (!feof(pdfp[0])) { sprintf(errmsg, "error reading compressed scanline from '%s'", pfname); error(USER, errmsg); - fclose(pfp); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); return RDTnone; } } if (doneScans >= GetHeight()) { // nothing left to do? sprintf(errmsg, "output file '%s' is already complete", pfname); error(WARNING, errmsg); - fclose(pfp); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); return dt; } if (!doneScans) { sprintf(errmsg, "restarting empty frame '%s'", pfname); error(WARNING, errmsg); } - if (dfname) { // append depth file, too? - if (dfname[0] == '!') { - error(USER, "depth data cannot be reloaded from command"); - fclose(pfp); + long toSkip = 0; + switch (RDTdepthT(dt)) { // append depth file, too? + case RDTdfloat: + toSkip = sizeof(float)*GetWidth()*doneScans; + break; + case RDTdshort: + if (!fgetsresolu(&res, pdfp[1]) || (res.rt != PIXSTANDARD) | + (res.xr != GetWidth()) | (res.yr != GetHeight())) { + sprintf(errmsg, "missing/bad resolution for '%s'", dfname); + error(USER, errmsg); + fclose(pdfp[0]); fclose(pdfp[0]); return RDTnone; } - dfp = fopen(dfname, "a"); - if (!dfp) { - sprintf(errmsg, "cannot reopen depth file '%s'", dfname); - error(SYSTEM, errmsg); - fclose(pfp); - return RDTnone; - } - SET_FILE_BINARY(dfp); - const long dflen = ftell(dfp); - if (dflen != sizeof(float)*GetWidth()*doneScans) { - fclose(dfp); - dfp = fopen(dfname, "r+"); - if (!dfp) return RDTnone; // WTH? - SET_FILE_BINARY(dfp); - } - if (dflen < sizeof(float)*GetWidth()*doneScans) { - HeaderInfo dinfo; - if (getheader(dfp, head_check, &dinfo) < 0) - sprintf(errmsg, "bad header in encoded depth file '%s'", - dfname); - else if (strcmp(dinfo.fmt, DEPTH16FMT)) - sprintf(errmsg, "wrong format (%s) for depth file '%s'", - dinfo.fmt, dfname); - else if (!SetReferenceDepth(dinfo.depth_unit)) - sprintf(errmsg, "bad/missing reference depth (%s) in '%s'", - dinfo.depth_unit, dfname); - else if (!fscnresolu(hvdim, hvdim+1, dfp) || - (hvdim[0] != GetWidth()) | (hvdim[1] != GetHeight())) - sprintf(errmsg, "bad/mismatched resolution in '%s'", - dfname); - else - errmsg[0] = '\0'; - - if (errmsg[0]) { - error(USER, errmsg); - fclose(dfp); - fclose(pfp); - return RDTnone; - } - const long dStart = ftell(dfp); - if (dflen-dStart < 2*GetWidth()*doneScans) { - sprintf(errmsg, "missing %ld depths in '%s'", - (long)GetWidth()*doneScans - (dflen-dStart)/2, - dfname); - error(WARNING, errmsg); - } - fseek(dfp, dStart + 2*GetWidth()*doneScans, SEEK_SET); - dt = RDTnewDT(dt, RDTdshort); - } else { - if (dflen > sizeof(float)*GetWidth()*doneScans) - fseek(dfp, sizeof(float)*GetWidth()*doneScans, SEEK_SET); - dt = RDTnewDT(dt, RDTdfloat); - } + toSkip = 2L*GetWidth()*doneScans; + break; + default:; + } // fseek() needed for output + if (pdfp[1] && fseek(pdfp[1], toSkip, SEEK_CUR) < 0) { + sprintf(errmsg, "cannot seek on depth file '%s'", dfname); + error(SYSTEM, errmsg); + fclose(pdfp[0]); fclose(pdfp[1]); + return RDTnone; } - int bheight = (psample > 1) ? int(2*psample+.99) : 4; + int bheight = (psample > 1) ? int(4*psample+.99) : 8; if (bheight > GetHeight()-doneScans) bheight = GetHeight()-doneScans; int vstep = bheight >> (psample > 1); vstep += !vstep; NewBar(bheight); // render remainder if we can - if (!RenderBelow(GetHeight()-doneScans, vstep, pfp, dt, dfp)) { - fclose(pfp); - if (dfp) fclose(dfp); + if (!RenderBelow(GetHeight()-doneScans, vstep, pdfp[0], dt, pdfp[1])) { + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); Cleanup(); return RDTnone; } NewBar(); // close up and return success - fclose(pfp); - if (dfp) fclose(dfp); + fclose(pdfp[0]); + if (pdfp[1]) fclose(pdfp[1]); return dt; }
