--- ray/src/rt/RpictSimulManager.cpp 2024/09/16 23:49:13 2.12 +++ ray/src/rt/RpictSimulManager.cpp 2025/01/25 04:57:27 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: RpictSimulManager.cpp,v 2.12 2024/09/16 23:49:13 greg Exp $"; +static const char RCSid[] = "$Id: RpictSimulManager.cpp,v 2.15 2025/01/25 04:57:27 greg Exp $"; #endif /* * RpictSimulManager.cpp @@ -418,20 +418,16 @@ RpictSimulManager::RenderRect(const int x0, const int doneSamples |= doneMap; } // compute required ray samples for (x = y = 0; sampMap.Find(&x, &y); x++) - if (!ComputePixel(x, y)) + if (!ComputePixel(x, y)) { + sprintf(errmsg, "ComputePixel(%d,%d) failed", x, y); + error(WARNING, errmsg); return false; + } doneSamples |= sampMap; // samples now done or at least queued sp2 -= layer++ & 1; // next denser sampling } - if (FlushQueue() < 0) // make sure we got everyone + if (FlushQueue() < 0) // compute stragglers return false; - x = y = 0; - if (doneMap.Find(&x, &y, false)) { - sprintf(errmsg, "missed %.4f%% of pixels in rectangle\n", - 100. - 100.*doneMap.SumTotal() / - doneMap.Width() / doneMap.Height()); - error(WARNING, errmsg); - } if ((prCB != NULL) & (barPix == NULL)) (*prCB)(100.); return true; @@ -593,7 +589,7 @@ RpictSimulManager::RenderBelow(int ytop, const int vst error(WARNING, "spectral range incompatible with color output"); COLORV ** parr = NULL; // set up tiny source drawing float ** zarr = NULL; - if (!ptvw.type && directvis && dblur <= FTINY) { + if (!ptvw.type && directvis && (dblur <= FTINY) & (mblur <= FTINY)) { parr = new COLORV * [THeight()]; zarr = new float * [THeight()]; for (int n = THeight(); n-- > 0; ) { @@ -609,7 +605,7 @@ RpictSimulManager::RenderBelow(int ytop, const int vst (*prCB)(100.*(GetHeight()-ytop)/GetHeight()); if (!RenderRect(0, THeight()-ytop)) // render this bar return false; - int nlines = lastOut - ytop + THeight(); + int nlines = lastOut - ytop + vstep; if (nlines > ytop) nlines = ytop; else if (parr) // drawing sources? @@ -819,7 +815,6 @@ RpictSimulManager::RenderFrame(const char *pfname, Ren if (!RenderBelow(GetHeight(), vstep, pdfp[0], dt, pdfp[1])) { fclose(pdfp[0]); if (pdfp[1]) (dfname[0] == '!') ? pclose(pdfp[1]) : fclose(pdfp[1]); - Cleanup(); return RDTnone; } NewBar(); // clean up and return @@ -1188,7 +1183,6 @@ RpictSimulManager::ResumeFrame(const char *pfname, con if (!RenderBelow(GetHeight()-doneScans, vstep, pdfp[0], dt, pdfp[1])) { fclose(pdfp[0]); if (pdfp[1]) fclose(pdfp[1]); - Cleanup(); return RDTnone; } NewBar(); // close up and return success
