--- ray/src/rt/RpictSimulManager.cpp 2024/08/14 20:05:23 2.1 +++ ray/src/rt/RpictSimulManager.cpp 2024/08/18 00:37:13 2.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: RpictSimulManager.cpp,v 2.1 2024/08/14 20:05:23 greg Exp $"; +static const char RCSid[] = "$Id: RpictSimulManager.cpp,v 2.2 2024/08/18 00:37:13 greg Exp $"; #endif /* * RpictSimulManager.cpp @@ -50,7 +50,7 @@ PixelAccess::SetPixel(int x, int y, const RAY *rp) scolor_out(col, primp, rp->rcol); return SetPixel(x, y, col, zv); default: - error(INTERNAL, "missing color space type in SetPixel()"); + error(INTERNAL, "botched color space type in SetPixel()"); } return false; } @@ -79,13 +79,14 @@ PixelAccess::SetColorSpace(RenderDataType cs, RGBPRIMP case RDTrgb: primp = pr ? pr : stdprims; break; - default: // RDTscolr | RDTscolor + case RDTscolr: + case RDTscolor: primp = NULL; break; + default: + error(INTERNAL, "botched color space type in SetColorSpace()"); } dtyp = RDTnewCT(dtyp, cs); - if (primp) - xyz2myrgbmat[0][0] = 0; return true; } @@ -138,8 +139,8 @@ int RpictSimulManager::RtCall(RAY *r, void *cd) { RpictSimulManager * rsp = (RpictSimulManager *)cd; - const int ty = r->rno / rsp->TWidth(); - const int tx = r->rno - (RNUMBER)ty*rsp->TWidth(); + const int ty = (r->rno-1) / rsp->TWidth(); + const int tx = r->rno-1 - (RNUMBER)ty*rsp->TWidth(); if (ty >= rsp->THeight()) { error(INTERNAL, "bad pixel calculation position in RtCall()"); @@ -227,7 +228,7 @@ RpictSimulManager::ComputePixel(int x, int y) for (i = (dlim > FTINY)*3; i--; ) rodir[1][i] *= dlim; - return EnqueueRay(rodir[0], rodir[1], (RNUMBER)y*TWidth()+x); + return EnqueueRay(rodir[0], rodir[1], (RNUMBER)y*TWidth()+x+1); } // Check if neighbor differences are below pixel sampling threshold @@ -261,7 +262,7 @@ RpictSimulManager::BelowSampThresh(int x, int y, const // Fill an interior square patch with interpolated values void -RpictSimulManager::FillSquare(int x, int y, const int noff[4][2]) +RpictSimulManager::FillSquare(const int x, const int y, const int noff[4][2]) { SCOLOR pval[4]; float dist[4]; @@ -271,14 +272,13 @@ RpictSimulManager::FillSquare(int x, int y, const int pacc.GetPixel(x+noff[i][0], y+noff[i][1], pval[i], &dist[i]); i = abs(noff[1][0]-noff[0][0]); - j = abs(noff[1][1]-noff[0][1]); - const int slen = i > j ? i : j; - const double sf = 1./slen; + j = abs(noff[1][1]-noff[0][1]); // i==j for diamond fill + const int slen = (i > j) ? i : j; const bool spectr = (pacc.NC() > 3); - for (i = 0; i <= slen; i++) { // bilinear interpolant - const double c1 = i*sf; - for (j = 0; j <= slen; j++) { - const double c2 = j*sf; + for (i = slen+1 + (i==j)*slen; i--; ) { + const double c1 = (i>slen ? i-slen-.5 : (double)i)/slen; + for (j = slen + (i<=slen); j--; ) { + const double c2 = (j + (i>slen)*.5)/slen; const int px = int(x + (1.-c1)*(1.-c2)*noff[0][0] + c1*(1.-c2)*noff[1][0] + (1.-c1)*c2*noff[2][0] + @@ -331,7 +331,7 @@ static void SetQuincunx(ABitMap2 *bmp2, int noff[4][2], const int spc, const bool odd) { for (int y = 0; y < bmp2->Height(); y += spc>>1) - for (int x = odd*(spc>>1); x < bmp2->Width(); x += spc) + for (int x = (odd^(y&1))*(spc>>1); x < bmp2->Width(); x += spc) bmp2->Set(x, y); // order neighbors CCW if (odd) { @@ -370,7 +370,7 @@ TWidth(), THeight(), psample, maxdiff); sampMap -= doneSamples; // avoid resampling pixels // Are we into adaptive sampling realm? if (noff[0][0]*noff[0][0] + noff[0][1]*noff[0][1] < psample*psample) { - if (FlushQueue() < 0) // need results to check threshold + if (FlushQueue() < 0) // need results to check thresholds return false; ABitMap2 fillMap = sampMap; for (x = y = 0; sampMap.Find(&x, &y); x++) @@ -378,12 +378,9 @@ TWidth(), THeight(), psample, maxdiff); sampMap.Reset(x, y); // spread sampling to neighbors... const ABitMap2 origSampMap = sampMap; - for (int yoff = -(1<<(sp2-1)); - yoff <= 1<<(sp2-1); yoff += 1< THeight()) | !tvw.type) return false; - tvw.voff -= double(v)/GetHeight(); - ptvw.voff -= double(v)/GetHeight(); + tvw.voff -= double(v)/THeight(); + ptvw.voff -= double(v)/THeight(); if (v == THeight()) { doneMap.ClearBitMap(); return true; @@ -562,6 +559,7 @@ RpictSimulManager::RenderBelow(int ytop, const int vst } int lastOut = ytop; // render down frame while (ytop > 0) { +fprintf(stderr, "At y=%d, source drawing %s...\n", ytop, parr ? "ON" : "OFF"); if (ytop < THeight()) // mark what we won't do as finished doneMap.ClearRect(0, 0, TWidth(), THeight()-ytop, true); if (prCB) @@ -605,7 +603,7 @@ RpictSimulManager::RenderBelow(int ytop, const int vst error(SYSTEM, "cannot write SCOLOR output"); break; default: - error(INTERNAL, "missing output color type in RenderBelow()"); + error(INTERNAL, "botched output color type in RenderBelow()"); break; } bpos += pacc.NC()*TWidth(); @@ -629,8 +627,8 @@ RpictSimulManager::RenderBelow(int ytop, const int vst * Render and write a frame to the named file * Include any header lines set prior to call * Picture file must not already exist - * Picture to stdout if pfname==NULL - * Depth written to a command if dfname[0]=='!' + * Write pixels to stdout if !pfname + * Write depth to a command if dfname[0]=='!' */ RenderDataType RpictSimulManager::RenderFrame(const char *pfname, RenderDataType dt, const char *dfname) @@ -640,7 +638,7 @@ RpictSimulManager::RenderFrame(const char *pfname, Ren FILE * dfp = NULL; if (!RDTcolorT(dt)) - error(INTERNAL, "missing pixel output type in RenderFrame()"); + error(INTERNAL, "botched color output type in RenderFrame()"); if (NCSAMP == 3) { if (RDTcolorT(dt) == RDTscolr) dt = RDTnewCT(dt, prims==xyzprims ? RDTxyze : RDTrgbe); @@ -676,7 +674,7 @@ RpictSimulManager::RenderFrame(const char *pfname, Ren if (frameNo > 0) fprintf(pfp, "FRAME=%d\n", frameNo); double pasp = viewaspect(&vw) * GetWidth() / GetHeight(); - if (!FABSEQ(pasp, 1.0)) + if ((0.99 > pasp) | (pasp > 1.01)) fputaspect(pasp, pfp); fputnow(pfp); switch (RDTcolorT(dt)) { // set primaries and picture format
