root/radiance/ray/src/rt/RpictSimulManager.cpp
Sat Jan 25 04:57:27 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.14: +3 -3 lines
Diff to previous 2.14
fix(rxpict): Removed extra scanlines being written to end of output
Fri Jan 24 19:08:01 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.13: +2 -9 lines
Diff to previous 2.13
fix(rxpict): Eliminated spurious warning about missed pixels and image bottom
Fri Jan 10 19:09:12 2025 UTC (4 months ago) by greg
Changes since 2.12: +5 -4 lines
Diff to previous 2.12
perf(rxpict): Improved error-handling
Mon Sep 16 23:49:13 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 2.11: +24 -17 lines
feat(rxpiece): Initial working version of rxpiece C++ tiling renderer
Tue Aug 27 18:50:01 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.10: +5 -2 lines
fix(rxpict): Allow out-of-visible rendering
Sun Aug 25 17:24:48 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.9: +31 -46 lines
perf(rxpict): Further improvements to sampling pattern
Sun Aug 25 03:13:07 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.8: +19 -13 lines
perf(rxpict): Minor improvement -- still needs work on sampling
Fri Aug 23 02:08:28 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.7: +52 -29 lines
perf(rxpict): Improved quincunx sampling code -- still needs work
Thu Aug 22 00:44:02 2024 UTC (8 months, 2 weeks ago) by greg
perf(rxpict): Minor optimization calling getbinary() rather than read()
Wed Aug 21 23:52:24 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.5: +9 -7 lines
refactor(rxpict): Made NewOutput() and ReopenOutput() more consistent
Wed Aug 21 23:32:24 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 2.4: +260 -169 lines
refactor(rxpict): Made picture/depth file opening public methods
Mon Aug 19 16:41:40 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.3: +18 -1 lines
feat: Added a few new accessor methods to class
Sun Aug 18 17:24:48 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.2: +19 -14 lines
perf(rxpict): Improved adaptive sampling at bottom of frame
Sun Aug 18 00:37:13 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.1: +28 -30 lines
fix(rxpict): Fixed fill algorithm for pixel sampling
Wed Aug 14 20:05:23 2024 UTC (8 months, 3 weeks ago) by greg
