fix: ratmain renamed to rxmain
Renamed ratrace to rxtrace
refactor: minor code improvements
feat(ratrace): First working version of new C++ rendering tool
chore: better error detection if ed fails to build Version.c
chore: no longer important to link rview -> rvu and rtcontrib -> rcontrib
Made picking of visible points in scene more reliable in rvu
Added AR variable to provide a way to override standard library builder
Made proximity test (plugaleak) more robust with transparent surfaces, etc.
Updated rules for photon map modules
Separated creation from use of contribution photon maps
Pulled pmap routines needed during rendering from pmap.c into pmutil.c
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Added Version.c updating with new photon map sources
Removed deprecated ambRayInPmap() macro from code
Added check for blocked shadow rays
Moved source initialization
Added missing dependencies for rcontrib modules
Minor fixes and adjustments
Remove libradiance.a to avoid issues with FAT files under OS X
Removed NICE macro settings, as this slows programs unduly under some OS's
Made it so "trace" command reports material rather than modifier
Fixed typo that caused Version.c to be rebuilt inappropriately
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -lm to lookamb compile
added special compile for ogl (not)
corrected dependencies for r?main.o
added missing dependencies
fixed dependencies
fixed duphead.o dependencies
fixed dependencies on otypes.h
safer placement of malloc.o for makeall
added fprism
fixed missing source routine
added ability to print COLRFMT output of values
added vfork.h include
added missing dependency
news driver for SGI
removed STRUCTASSIGN macro
added SPECIAL macro
standardized macro settings
changed logic of version control
added Version.c module
removed COMPAT line
added malloc.o with compression
moved librt.a to ../lib
added rayinit.cal to install
added empty entry for tiff
added in dispersion compiles for dielectric.c
added redirecting materials
removed calfunc.o
eliminated many symbolic links to header files
put a lot of routines into a common library
added virtual sources
changed compilation of caldefn.o
added icon bitmap
added aed as external driver
added new mat.h dependencies
added .h dependencies for m_brdf.o
added lint compile for rview
added plasfunc, metfunc, plasdata, metdata types in m_brdf.c
changed location of device drivers for rview
created new malloc() and removed bmalloc() from misc.c
took resolu.c and spec_rgb.c out of color.c
removed malloc.o from compatibility list since bmalloc() change
added conditional casting of rays to rtrace
added NeWS driver
added CC variable for compiler
added -DREDEFW flag when compiling caldefn.c
fixed dependencies related to rmain.c
added missing dependencies for x11.o
added x11 driver
forgot dependency of editline.o on driver.h
added missing dependencies for devmain.c
improved portability and efficiency of bcopy()
added compiles for X11dev
added repaint command
Changed options to C compiler
added fgetline.o
Moved separate drivers to INSTDIR
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
eliminated superfluous dependency
undid last stupid change, install should be cp
changed install program
changes for texture data
portability fixes
