root/radiance/ray/src/rt/Rmakefile
Sat Apr 26 15:59:38 2014 UTC (10 years ago) by greg
Diff to previous 2.71
Revision 2.71 - (view) (download) (annotate) - [selected]
Tue Feb 18 12:13:42 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.70: +3 -1 lines
Diff to previous 2.70
Thu Sep 6 00:07:43 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.69: +9 -9 lines
Diff to previous 2.69 , to selected 2.71
Sun Jul 29 19:01:39 2012 UTC (11 years, 9 months ago) by greg
Changes since 2.68: +5 -3 lines
Diff to previous 2.68 , to selected 2.71
Wed Jun 27 15:32:58 2012 UTC (11 years, 10 months ago) by greg
Diff to previous 2.67 , to selected 2.71
Added check for blocked shadow rays
Fri Jun 22 22:03:02 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.66: +5 -5 lines
Diff to previous 2.66 , to selected 2.71
Moved source initialization
Fri Jun 22 16:52:06 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.65: +15 -2 lines
Diff to previous 2.65 , to selected 2.71
Added missing dependencies for rcontrib modules
Thu Jun 14 22:42:21 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.64: +2 -1 lines
Diff to previous 2.64 , to selected 2.71
Sat Jun 9 07:16:47 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.63: +9 -2 lines
Diff to previous 2.63 , to selected 2.71
Fri Feb 18 02:41:55 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.62: +5 -4 lines
Diff to previous 2.62 , to selected 2.71
Minor fixes and adjustments
Fri Feb 18 00:40:25 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.61: +7 -4 lines
Diff to previous 2.61 , to selected 2.71
Sun Sep 26 15:51:15 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.60: +2 -1 lines
Diff to previous 2.60 , to selected 2.71
Mon Aug 23 15:57:46 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.59: +2 -1 lines
Diff to previous 2.59 , to selected 2.71
Remove libradiance.a to avoid issues with FAT files under OS X
Sat Dec 12 19:00:59 2009 UTC (14 years, 4 months ago) by greg
Diff to previous 2.58 , to selected 2.71
Sat Dec 12 05:20:10 2009 UTC (14 years, 4 months ago) by greg
Changes since 2.57: +4 -4 lines
Diff to previous 2.57 , to selected 2.71
Thu Aug 21 07:05:58 2008 UTC (15 years, 8 months ago) by greg
Diff to previous 2.56 , to selected 2.71
Tue Jun 24 02:01:21 2008 UTC (15 years, 10 months ago) by greg
Changes since 2.55: +3 -3 lines
Diff to previous 2.55 , to selected 2.71
Mon Oct 8 18:07:57 2007 UTC (16 years, 6 months ago) by greg
Diff to previous 2.54 , to selected 2.71
Fri Mar 10 19:40:13 2006 UTC (18 years, 1 month ago) by schorsch
Diff to previous 2.53 , to selected 2.71
Fri Dec 16 04:03:42 2005 UTC (18 years, 4 months ago) by greg
Changes since 2.52: +1 -14 lines
Diff to previous 2.52 , to selected 2.71
Removed NICE macro settings, as this slows programs unduly under some OS's
Thu Jun 23 11:51:47 2005 UTC (18 years, 10 months ago) by greg
Changes since 2.51: +7 -1 lines
Diff to previous 2.51 , to selected 2.71
Tue May 31 18:01:09 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 2.50 , to selected 2.71
Thu Apr 14 04:42:32 2005 UTC (19 years ago) by greg
Diff to previous 2.49 , to selected 2.71
Made it so "trace" command reports material rather than modifier
Fri Nov 5 03:31:38 2004 UTC (19 years, 5 months ago) by greg
Changes since 2.48: +5 -14 lines
Diff to previous 2.48 , to selected 2.71
Wed Oct 27 23:23:48 2004 UTC (19 years, 6 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.47 , to selected 2.71
Tue Oct 26 19:04:32 2004 UTC (19 years, 6 months ago) by greg
Diff to previous 2.46 , to selected 2.71
Thu Oct 21 21:44:59 2004 UTC (19 years, 6 months ago) by greg
Diff to previous 2.45 , to selected 2.71
Fixed typo that caused Version.c to be rebuilt inappropriately
Tue Mar 30 20:40:04 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.44: +3 -2 lines
Diff to previous 2.44 , to selected 2.71
Changes since 2.43: +6 -5 lines
Diff to previous 2.43 , to selected 2.71
Wed Dec 31 19:38:27 2003 UTC (20 years, 4 months ago) by greg
Changes since 2.42: +12 -12 lines
Diff to previous 2.42 , to selected 2.71
Diff to previous 2.41 , to selected 2.71
Tue Nov 11 16:24:06 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.40: +1 -3 lines
Diff to previous 2.40 , to selected 2.71
Mon Nov 10 16:52:24 2003 UTC (20 years, 5 months ago) by greg
Diff to previous 2.39 , to selected 2.71
Wed Aug 20 09:41:25 2003 UTC (20 years, 8 months ago) by schorsch
Changes since 2.38: +2 -3 lines
Diff to previous 2.38 , to selected 2.71
Mon Aug 4 22:37:53 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.37: +4 -2 lines
Diff to previous 2.37 , to selected 2.71
Changes since 2.36: +6 -3 lines
Diff to previous 2.36 , to selected 2.71
Fri Jun 6 18:38:19 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.35: +8 -3 lines
Diff to previous 2.35 , to selected 2.71
Tue Mar 11 19:29:05 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.34 , to selected 2.71
Tue Mar 11 17:08:55 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.33: +7 -5 lines
Diff to previous 2.33 , to selected 2.71
Changes since 2.32: +66 -104 lines
Diff to previous 2.32 , to selected 2.71
Fri Dec 4 18:02:07 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 2.31: +3 -5 lines
Diff to previous 2.31 , to selected 2.71
Thu Nov 12 09:41:49 1998 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 2.30 , to selected 2.71
added -lm to lookamb compile
Thu Sep 3 10:49:31 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 2.29 , to selected 2.71
Tue Jun 9 16:50:49 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 2.28: +1 -1 lines
Diff to previous 2.28 , to selected 2.71
added special compile for ogl (not)
Sat Jan 3 20:07:30 1998 UTC (26 years, 3 months ago) by gregl
Diff to previous 2.27 , to selected 2.71
Mon Dec 1 09:56:27 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 2.26 , to selected 2.71
Fri Nov 14 12:35:45 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 2.25 , to selected 2.71
corrected dependencies for r?main.o
Wed Jul 3 17:19:51 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.24: +4 -1 lines
Diff to previous 2.24 , to selected 2.71
Thu Jun 20 16:57:07 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.23: +6 -5 lines
Diff to previous 2.23 , to selected 2.71
added missing dependencies
Tue May 28 13:42:47 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.22: +2 -0 lines
Diff to previous 2.22 , to selected 2.71
Thu Apr 11 15:59:14 1996 UTC (28 years ago) by greg
Diff to previous 2.21 , to selected 2.71
fixed dependencies
Fri Mar 15 21:02:03 1996 UTC (28 years, 1 month ago) by greg
Changes since 2.20: +8 -6 lines
Diff to previous 2.20 , to selected 2.71
Fri Dec 8 18:22:25 1995 UTC (28 years, 4 months ago) by greg
Diff to previous 2.19 , to selected 2.71
Thu Nov 2 17:35:31 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.18 , to selected 2.71
fixed duphead.o dependencies
Fri Sep 29 11:27:00 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.17 , to selected 2.71
fixed dependencies on otypes.h
Fri Apr 22 11:45:22 1994 UTC (30 years ago) by greg
Diff to previous 2.16 , to selected 2.71
safer placement of malloc.o for makeall
Thu Apr 14 04:50:23 1994 UTC (30 years ago) by greg
Diff to previous 2.15 , to selected 2.71
Thu Dec 9 17:31:10 1993 UTC (30 years, 4 months ago) by greg
Diff to previous 2.14 , to selected 2.71
Wed Sep 29 10:41:25 1993 UTC (30 years, 7 months ago) by greg
Diff to previous 2.13 , to selected 2.71
added fprism
Fri Feb 12 10:38:36 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.12 , to selected 2.71
fixed missing source routine
Wed Feb 10 12:51:37 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.11 , to selected 2.71
Wed Jan 20 15:19:41 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.10 , to selected 2.71
Tue Sep 8 15:35:13 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.9 , to selected 2.71
Tue Sep 8 09:11:17 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.8 , to selected 2.71
Thu Jul 16 12:09:23 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.7: +0 -3 lines
Diff to previous 2.7 , to selected 2.71
Mon Jul 13 16:17:44 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.6 , to selected 2.71
Fri Jul 10 14:55:45 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.5 , to selected 2.71
added ability to print COLRFMT output of values
Thu Mar 19 09:33:59 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 2.71
added vfork.h include
Mon Mar 16 07:40:17 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.71
added missing dependency
Sat Jan 4 19:54:54 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +7 -6 lines
Diff to previous 2.2 , to selected 2.71
Mon Nov 25 09:51:08 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.71
Tue Nov 12 17:10:12 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.70: +0 -0 lines
Diff to previous 1.70 , to selected 2.71
Mon Nov 11 14:02:39 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.69: +4 -1 lines
Diff to previous 1.69 , to selected 2.71
Thu Nov 7 16:34:50 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.68: +7 -1 lines
Diff to previous 1.68 , to selected 2.71
news driver for SGI
Thu Nov 7 11:06:53 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.67: +3 -3 lines
Diff to previous 1.67 , to selected 2.71
removed STRUCTASSIGN macro
Mon Oct 28 09:42:31 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.66: +3 -2 lines
Diff to previous 1.66 , to selected 2.71
added SPECIAL macro
Wed Oct 23 10:47:31 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.65: +3 -3 lines
Diff to previous 1.65 , to selected 2.71
standardized macro settings
Tue Oct 22 15:45:17 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.64: +4 -6 lines
Diff to previous 1.64 , to selected 2.71
Mon Oct 21 12:57:53 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.63: +8 -6 lines
Diff to previous 1.63 , to selected 2.71
Wed Oct 9 12:27:50 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.62: +2 -3 lines
Diff to previous 1.62 , to selected 2.71
changed logic of version control
Wed Oct 9 10:07:47 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.61: +17 -6 lines
Diff to previous 1.61 , to selected 2.71
added Version.c module
Tue Oct 8 15:32:43 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.60: +5 -4 lines
Diff to previous 1.60 , to selected 2.71
removed COMPAT line
Mon Aug 26 10:14:21 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.59: +5 -1 lines
Diff to previous 1.59 , to selected 2.71
added malloc.o with compression
Thu Aug 22 09:25:22 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.58: +5 -5 lines
Diff to previous 1.58 , to selected 2.71
moved librt.a to ../lib
Thu Aug 22 08:59:23 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.57: +3 -1 lines
Diff to previous 1.57 , to selected 2.71
added rayinit.cal to install
Fri Aug 16 12:54:48 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.56: +2 -0 lines
Diff to previous 1.56 , to selected 2.71
added empty entry for tiff
Fri Jul 19 09:32:58 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.55: +9 -9 lines
Diff to previous 1.55 , to selected 2.71
Wed Jul 17 12:15:29 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.54: +3 -3 lines
Diff to previous 1.54 , to selected 2.71
added in dispersion compiles for dielectric.c
Tue Jul 16 15:56:40 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.53: +7 -3 lines
Diff to previous 1.53 , to selected 2.71
added redirecting materials
Tue Jul 16 10:39:25 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.52: +5 -10 lines
Diff to previous 1.52 , to selected 2.71
removed calfunc.o
Mon Jul 15 12:18:13 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.51: +12 -11 lines
Diff to previous 1.51 , to selected 2.71
eliminated many symbolic links to header files
Mon Jul 15 11:50:26 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.50: +29 -47 lines
Diff to previous 1.50 , to selected 2.71
put a lot of routines into a common library
Thu Jun 20 13:43:33 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.49: +10 -10 lines
Diff to previous 1.49 , to selected 2.71
Wed Jun 19 16:36:50 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.48: +7 -7 lines
Diff to previous 1.48 , to selected 2.71
added virtual sources
Wed Jun 19 15:08:41 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.47: +1 -1 lines
Diff to previous 1.47 , to selected 2.71
Fri Jun 7 10:04:23 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.46: +6 -4 lines
Diff to previous 1.46 , to selected 2.71
Tue May 21 17:41:16 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.45: +5 -5 lines
Diff to previous 1.45 , to selected 2.71
Tue May 7 16:14:21 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.44 , to selected 2.71
Wed May 1 11:17:03 1991 UTC (33 years ago) by greg
Changes since 1.43: +2 -0 lines
Diff to previous 1.43 , to selected 2.71
Tue Apr 23 13:01:55 1991 UTC (33 years ago) by greg
Changes since 1.42: +1 -1 lines
Diff to previous 1.42 , to selected 2.71
changed compilation of caldefn.o
Fri Apr 19 15:02:50 1991 UTC (33 years ago) by greg
Diff to previous 1.41 , to selected 2.71
added icon bitmap
Thu Apr 11 09:21:30 1991 UTC (33 years ago) by greg
Changes since 1.40: +1 -1 lines
Diff to previous 1.40 , to selected 2.71
Fri Mar 8 12:55:36 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.39: +8 -2 lines
Diff to previous 1.39 , to selected 2.71
added aed as external driver
Thu Mar 7 15:12:09 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.38: +22 -16 lines
Diff to previous 1.38 , to selected 2.71
Sat Dec 15 15:07:02 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.37: +6 -4 lines
Diff to previous 1.37 , to selected 2.71
added new mat.h dependencies
Thu Dec 13 11:07:28 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.36: +3 -3 lines
Diff to previous 1.36 , to selected 2.71
added .h dependencies for m_brdf.o
Thu Dec 13 10:43:59 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.35: +6 -6 lines
Diff to previous 1.35 , to selected 2.71
Wed Dec 12 22:36:51 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.34: +22 -0 lines
Diff to previous 1.34 , to selected 2.71
added lint compile for rview
Wed Dec 12 22:03:32 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.33: +1 -1 lines
Diff to previous 1.33 , to selected 2.71
added plasfunc, metfunc, plasdata, metdata types in m_brdf.c
Wed Oct 31 14:19:15 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.32: +11 -8 lines
Diff to previous 1.32 , to selected 2.71
changed location of device drivers for rview
Tue Sep 25 19:39:17 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.31 , to selected 2.71
created new malloc() and removed bmalloc() from misc.c
Sat Sep 22 10:52:19 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.30: +5 -8 lines
Diff to previous 1.30 , to selected 2.71
took resolu.c and spec_rgb.c out of color.c
Mon Sep 17 18:02:19 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.29 , to selected 2.71
removed malloc.o from compatibility list since bmalloc() change
Thu Sep 6 23:31:23 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.28 , to selected 2.71
Sat Aug 18 03:59:00 1990 UTC (33 years, 8 months ago) by greg
Diff to previous 1.27 , to selected 2.71
added conditional casting of rays to rtrace
Wed Jul 18 21:43:42 1990 UTC (33 years, 9 months ago) by greg
Changes since 1.26: +10 -4 lines
Diff to previous 1.26 , to selected 2.71
added NeWS driver
Thu Jun 28 13:58:31 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.25: +20 -19 lines
Diff to previous 1.25 , to selected 2.71
added CC variable for compiler
Thu May 31 10:22:48 1990 UTC (33 years, 11 months ago) by greg
Diff to previous 1.24 , to selected 2.71
added -DREDEFW flag when compiling caldefn.c
Thu Mar 29 13:32:31 1990 UTC (34 years, 1 month ago) by greg
Diff to previous 1.23 , to selected 2.71
fixed dependencies related to rmain.c
Thu Mar 8 16:13:41 1990 UTC (34 years, 1 month ago) by greg
Diff to previous 1.22 , to selected 2.71
added missing dependencies for x11.o
Tue Mar 6 17:44:35 1990 UTC (34 years, 2 months ago) by greg
Diff to previous 1.21 , to selected 2.71
Mon Mar 5 10:20:54 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.20: +6 -6 lines
Diff to previous 1.20 , to selected 2.71
added x11 driver
Thu Feb 22 12:39:22 1990 UTC (34 years, 2 months ago) by greg
Diff to previous 1.19 , to selected 2.71
Thu Feb 22 11:35:45 1990 UTC (34 years, 2 months ago) by greg
Diff to previous 1.18 , to selected 2.71
forgot dependency of editline.o on driver.h
Tue Jan 30 10:51:05 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.17 , to selected 2.71
added missing dependencies for devmain.c
Thu Jan 25 08:16:57 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.16 , to selected 2.71
improved portability and efficiency of bcopy()
Fri Jan 12 11:27:22 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.15 , to selected 2.71
Tue Dec 19 13:02:39 1989 UTC (34 years, 4 months ago) by greg
Changes since 1.14: +7 -1 lines
Diff to previous 1.14 , to selected 2.71
added compiles for X11dev
Fri Oct 27 11:48:18 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.13 , to selected 2.71
added repaint command
Wed Oct 25 15:37:10 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.12 , to selected 2.71
Fri Oct 20 16:54:56 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.11 , to selected 2.71
Thu Oct 12 11:35:23 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.10 , to selected 2.71
Changed options to C compiler
Wed Oct 4 16:07:32 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 2.71
added fgetline.o
Mon Oct 2 17:12:32 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.8: +6 -4 lines
Diff to previous 1.8 , to selected 2.71
Fri Jun 9 15:35:18 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.7 , to selected 2.71
Moved separate drivers to INSTDIR
Wed Jun 7 08:35:10 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 2.71
Glow type changed
Spot type eliminated
Mon Jun 5 11:43:47 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.5 , to selected 2.71
eliminated superfluous dependency
Wed Apr 5 09:41:20 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.4 , to selected 2.71
undid last stupid change, install should be cp
Wed Mar 29 11:26:15 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.3 , to selected 2.71
changed install program
Tue Mar 14 11:32:01 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 2.71
changes for texture data
Tue Feb 21 14:56:15 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 2.71
portability fixes
Thu Feb 2 10:41:12 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.71
