1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: RdataShareMap.cpp,v 2.2 2024/10/30 01:38:21 greg Exp $"; |
3 |
#endif |
4 |
5 |
* RdataShareMap.cpp |
6 |
7 |
* Shared data using memory-mapped file |
8 |
9 |
* Created by Greg Ward on 10/14/2024 |
10 |
11 |
12 |
#include "rtio.h" |
13 |
#include "rterror.h" |
14 |
#include "RdataShare.h" |
15 |
#include <unistd.h> |
16 |
#include <sys/stat.h> |
17 |
#include <sys/mman.h> |
18 |
19 |
// Create memory-mapped file object |
20 |
RdataShareMap::RdataShareMap(const char *name, int flags, size_t siz) |
21 |
22 |
mmorg = NULL; |
23 |
bufCount = 0; |
24 |
25 |
if (!(flags & (RDSread|RDSwrite))) { |
26 |
error(CONSISTENCY, "RdataShareMap() flags must include RDSread or RDSwrite"); |
27 |
return; |
28 |
29 |
if (name && !*name) name = NULL; |
30 |
if (!name && !siz | ((flags & (RDSextend|RDSread|RDSwrite)) != |
31 |
(RDSextend|RDSread|RDSwrite))) { |
32 |
error(CONSISTENCY, "anonymous memory map must be read/write"); |
33 |
return; |
34 |
35 |
if ((flags & (RDSextend|RDSwrite)) == RDSextend) { |
36 |
error(CONSISTENCY, "bad RDSextend in RdataShareMap()"); |
37 |
return; |
38 |
39 |
int oflags, mmprot; |
40 |
switch (flags & (RDSread|RDSwrite)) { |
41 |
case RDSread|RDSwrite: |
42 |
mmprot = PROT_READ|PROT_WRITE; |
43 |
oflags = O_RDWR|O_CREAT; |
44 |
break; |
45 |
case RDSwrite: |
46 |
mmprot = PROT_WRITE; |
47 |
oflags = O_RDWR|O_CREAT; // XXX system limitation |
48 |
break; |
49 |
case RDSread: |
50 |
mmprot = PROT_READ; |
51 |
oflags = O_RDONLY; |
52 |
break; |
53 |
54 |
int fd = -1; |
55 |
if (name) { // opening a shared file |
56 |
if (flags & RDSexcl) oflags |= O_EXCL; |
57 |
else if (flags & RDSextend && !siz) oflags |= O_TRUNC; |
58 |
fd = open(name, oflags, 0666); |
59 |
if (fd < 0) { |
60 |
sprintf(errmsg, "cannot open '%s'", name); |
61 |
error(SYSTEM, errmsg); |
62 |
return; |
63 |
64 |
if (!(flags & RDSextend)) { |
65 |
struct stat sbuf; |
66 |
if (flags & RDSexcl) |
67 |
siz = 0; |
68 |
else if (fstat(fd, &sbuf) >= 0) |
69 |
siz = sbuf.st_size; |
70 |
else { |
71 |
sprintf(errmsg, "cannot stat '%s'", chName); |
72 |
73 |
close(fd); |
74 |
return; |
75 |
76 |
} else if (siz && ftruncate(fd, siz) < 0) { |
77 |
sprintf(errmsg, "cannot resize '%s'", name); |
78 |
79 |
close(fd); |
80 |
return; |
81 |
82 |
83 |
if (siz) mmorg = (void *)mmap(NULL, siz, mmprot, |
84 |
MAP_SHARED|(name ? MAP_FILE : MAP_ANON), fd, 0); |
85 |
close(fd); |
86 |
if (mmorg == MAP_FAILED) { |
87 |
if (name) |
88 |
sprintf(errmsg, "cannot map '%s' to memory", name); |
89 |
else |
90 |
sprintf(errmsg, "cannot map anonymous map of %ld KBytes", |
91 |
long(siz/1024)); |
92 |
93 |
mmorg = NULL; |
94 |
return; |
95 |
96 |
osiz = siz; |
97 |
if (name) chName = savqstr(name); |
98 |
mode = flags; |
99 |
100 |
101 |
RdataShareMap::~RdataShareMap() |
102 |
103 |
if (mmorg) munmap(mmorg, osiz); |
104 |
105 |
106 |
// Attempt to extend or shrink object (adjust if 0) |
107 |
size_t |
108 |
RdataShareMap::Resize(size_t new_siz) |
109 |
110 |
if (new_siz > 0) { |
111 |
if (new_siz == osiz) |
112 |
return osiz; |
113 |
if (!(mode & RDSwrite)) { |
114 |
error(CONSISTENCY, "cannot resize read-only map"); |
115 |
return 0; |
116 |
117 |
118 |
if (bufCount > 0) { |
119 |
error(INTERNAL, "cannot resize while memory is checked out"); |
120 |
return 0; |
121 |
122 |
if (!chName) { |
123 |
if (!new_siz) // XXX should issue warning? |
124 |
return osiz; |
125 |
if (new_siz > osiz) { |
126 |
error(INTERNAL, "cannot grow anonymous map"); |
127 |
return 0; |
128 |
129 |
return osiz = new_siz; // just pretend we shrank |
130 |
131 |
if (!new_siz) { // sync to current file length? |
132 |
struct stat sbuf; |
133 |
if (stat(chName, &sbuf) < 0) { |
134 |
135 |
136 |
return 0; |
137 |
138 |
if (sbuf.st_size <= osiz) |
139 |
return osiz = sbuf.st_size; |
140 |
141 |
new_siz = sbuf.st_size; |
142 |
143 |
if (new_siz > osiz) { // need to extend & remap |
144 |
int fd = open(chName, mode&RDSread ? O_RDWR : O_WRONLY); |
145 |
if (fd < 0) { |
146 |
sprintf(errmsg, "cannot reopen '%s'", chName); |
147 |
148 |
return 0; |
149 |
150 |
if (ftruncate(fd, new_siz) < 0) { |
151 |
sprintf(errmsg, "cannot grow '%s'", chName); |
152 |
153 |
close(fd); |
154 |
return 0; |
155 |
156 |
157 |
mmorg = mmap(NULL, new_siz, |
158 |
mode&RDSread ? PROT_READ|PROT_WRITE : PROT_WRITE, |
159 |
MAP_SHARED|MAP_FILE, fd, 0); |
160 |
close(fd); |
161 |
162 |
sprintf(errmsg, "mmap() failed on '%s'", chName); |
163 |
164 |
mmorg = NULL; |
165 |
return osiz = 0; |
166 |
167 |
} else if (truncate(chName, new_siz) < 0) { |
168 |
sprintf(errmsg, "cannot truncate '%s'", chName); |
169 |
return 0; |
170 |
171 |
return osiz = new_siz; |
172 |
173 |
174 |
// Get data buffer |
175 |
void * |
176 |
RdataShareMap::GetMemory(size_t offs, size_t len, int fl) |
177 |
178 |
if (chName && fl & RDSextend) { // resize/extend? |
179 |
if (offs + len > osiz ? !Resize(offs + len) : !Resize()) |
180 |
return NULL; |
181 |
182 |
if (offs + len > osiz) { |
183 |
if (chName) |
184 |
sprintf(errmsg, "requested block of %lu bytes outside map '%s'", |
185 |
(unsigned long)len, chName); |
186 |
else |
187 |
sprintf(errmsg, "requested block of %lu bytes outside %lu byte map", |
188 |
(unsigned long)len, (unsigned long)osiz); |
189 |
error(CONSISTENCY, errmsg); |
190 |
return NULL; |
191 |
192 |
++bufCount; |
193 |
return (char *)mmorg + offs; |
194 |
195 |
196 |
// Return data buffer |
197 |
bool |
198 |
RdataShareMap::ReleaseMemory(void *dp, int fl) |
199 |
200 |
if ((dp < mmorg) | ((char *)dp >= (char *)mmorg + osiz)) { |
201 |
if (chName) |
202 |
sprintf(errmsg, "returned block outside map '%s'", chName); |
203 |
else |
204 |
sprintf(errmsg, "returned block outside %lu byte map", |
205 |
206 |
207 |
return false; |
208 |
209 |
bufCount -= (bufCount > 0); |
210 |
return true; |
211 |
