1 |
/* RCSid $Id$ */ |
2 |
3 |
* RdataShare.h |
4 |
5 |
* Radiance classes for interprocess data sharing |
6 |
7 |
* Errors end up calling error() from rterror.h, so |
8 |
* checking return values is not normally needed. |
9 |
10 |
* Created by Greg Ward on 10/14/2024. |
11 |
12 |
13 |
#ifndef RdataShare_h |
14 |
#define RdataShare_h |
15 |
16 |
#include <sys/types.h> |
17 |
18 |
/// Channel creation and i/o flags |
19 |
enum {RDSexcl=1, RDSextend=2, RDSread=4, RDSwrite=8}; |
20 |
21 |
22 |
* When data sharing object is created, flag meanings are: |
23 |
* RDSexcl = Create a new file, or fail if it exists |
24 |
* RDSextend = Set data extent to match size parameter |
25 |
* RDSread = Data may be read |
26 |
* RDSwrite = Data may be written |
27 |
28 |
* The RDSread flag should be given to GetMemory() if a data |
29 |
* read operation is desired. Similarly, the RDSwrite flag |
30 |
* should be given when writing data in ReleaseMemory(). |
31 |
* Memory-mapped files always read *and* write data if opened |
32 |
* in the appropriate mode. (Beware that writing to read-only data |
33 |
* or reading write-only data will generate a system fault.) |
34 |
* The RDSextend flag may be given with RDSread in GetMemory() |
35 |
* and RDSwrite in ReleaseMemory() to allow the file size to |
36 |
* increase as needed for a given operation. |
37 |
* In some implementations, the RDSexcl flag may guarantee |
38 |
* data consistency by placing locks on the requested memory areas. |
39 |
* In such cases, it may make sense to include the RDSwrite flag |
40 |
* in GetMemory() calls if the intention is to write new results |
41 |
* in ReleaseMemory(), so an exclusive lock will be held. |
42 |
43 |
44 |
/// Data share object types returned by GetType() |
45 |
enum RDSType {RDSTanonMap=1, RDSTfileMap, RDSTfile, |
46 |
RDSTcust1, RDSTcust2, RDSTcust3, RDSTcust4}; |
47 |
48 |
extern const char RDSnoname[]; |
49 |
50 |
/// Abstract base class for shared memory object |
51 |
class RdataShare { |
52 |
protected: |
53 |
char * chName; // channel name |
54 |
size_t osiz; // current object size |
55 |
int mode; // open mode |
56 |
public: |
57 |
RdataShare() { |
58 |
chName = NULL; osiz = 0; mode = 0; |
59 |
60 |
virtual ~RdataShare(); |
61 |
/// Get channel name, or RDSnoname if anonymous |
62 |
const char * GetName() const { |
63 |
return chName ? chName : RDSnoname; |
64 |
65 |
/// Get R/W flags |
66 |
int GetMode() const { |
67 |
return mode & (RDSread|RDSwrite); |
68 |
69 |
/// Get current object size |
70 |
size_t GetSize() const { |
71 |
return osiz; |
72 |
73 |
/// Return data sharing type |
74 |
virtual RDSType GetType() const = 0; |
75 |
/// Attempt to extend or shrink object (adjust if 0) |
76 |
virtual size_t Resize(size_t new_siz = 0) = 0; |
77 |
/// Get data buffer |
78 |
virtual void * GetMemory(size_t offs, size_t len, int fl = RDSread) = 0; |
79 |
/// Return data buffer |
80 |
virtual bool ReleaseMemory(void *bp, int fl = RDSwrite) = 0; |
81 |
82 |
83 |
/// Memory sharing implemented with mmap'ed file (or anonymous area) |
84 |
class RdataShareMap : public RdataShare { |
85 |
void * mmorg; // memory-mapped origin |
86 |
int bufCount; // count of allocated buffers |
87 |
public: |
88 |
RdataShareMap(const char *name, int flags, size_t siz = 0); |
89 |
virtual ~RdataShareMap(); |
90 |
RDSType GetType() const { |
91 |
return chName ? RDSTfileMap : RDSTanonMap; |
92 |
93 |
size_t Resize(size_t new_siz = 0); |
94 |
void * GetMemory(size_t offs, size_t len, int fl); |
95 |
bool ReleaseMemory(void *dp, int fl); |
96 |
97 |
98 |
struct RDSbuffer; // Private struct for buffer list |
99 |
100 |
/// Memory sharing implemented with simple file |
101 |
class RdataShareFile : public RdataShare { |
102 |
int fd; // open file descriptor |
103 |
RDSbuffer * blist; // allocated buffer list |
104 |
public: |
105 |
RdataShareFile(const char *name, int flags, size_t siz = 0); |
106 |
virtual ~RdataShareFile(); |
107 |
108 |
return RDSTfile; |
109 |
110 |
111 |
112 |
113 |
114 |
115 |
#endif // RdataShare_h |
