root/radiance/ray/src/rt/RdataShare.h
Revision: 2.1
Committed: Tue Oct 29 00:36:54 2024 UTC (9 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
# User Rev Content
1 greg 2.1 /* RCSid $Id$ */
2     /*
3     * RdataShare.h
4     *
5     * Radiance classes for interprocess data sharing
6     *
7     * Errors end up calling error() from rterror.h, so
8     * checking return values is not normally needed.
9     *
10     * Created by Greg Ward on 10/14/2024.
11     */
12
13     #ifndef RdataShare_h
14     #define RdataShare_h
15
16     #include <sys/types.h>
17
18     /// Channel creation and i/o flags
19     enum {RDSexcl=1, RDSextend=2, RDSread=4, RDSwrite=8};
20
21     /*
22     * When data sharing object is created, flag meanings are:
23     * RDSexcl = Create a new file, or fail if it exists
24     * RDSextend = Set data extent to match size parameter
25     * RDSread = Data may be read
26     * RDSwrite = Data may be written
27     *
28     * The RDSread flag should be given to GetMemory() if a data
29     * read operation is desired. Similarly, the RDSwrite flag
30     * should be given when writing data in ReleaseMemory().
31     * Memory-mapped files always read *and* write data if opened
32     * in the appropriate mode. (Beware that writing to read-only data
33     * or reading write-only data will generate a system fault.)
34     * The RDSextend flag may be given with RDSread in GetMemory()
35     * and RDSwrite in ReleaseMemory() to allow the file size to
36     * increase as needed for a given operation.
37     * In some implementations, the RDSexcl flag may guarantee
38     * data consistency by placing locks on the requested memory areas.
39     * In such cases, it may make sense to include the RDSwrite flag
40     * in GetMemory() calls if the intention is to write new results
41     * in ReleaseMemory(), so an exclusive lock will be held.
42     */
43
44     /// Data share object types returned by GetType()
45     enum RDSType {RDSTanonMap=1, RDSTfileMap, RDSTfile,
46     RDSTcust1, RDSTcust2, RDSTcust3, RDSTcust4};
47
48     extern const char RDSnoname[];
49
50     /// Abstract base class for shared memory object
51     class RdataShare {
52     protected:
53     char * chName; // channel name
54     size_t osiz; // current object size
55     int mode; // open mode
56     public:
57     RdataShare() {
58     chName = NULL; osiz = 0; mode = 0;
59     }
60     virtual ~RdataShare();
61     /// Get channel name, or RDSnoname if anonymous
62     const char * GetName() const {
63     return chName ? chName : RDSnoname;
64     }
65     /// Get R/W flags
66     int GetMode() const {
67     return mode & (RDSread|RDSwrite);
68     }
69     /// Get current object size
70     size_t GetSize() const {
71     return osiz;
72     }
73     /// Return data sharing type
74     virtual RDSType GetType() const = 0;
75     /// Attempt to extend or shrink object (adjust if 0)
76     virtual size_t Resize(size_t new_siz = 0) = 0;
77     /// Get data buffer
78     virtual void * GetMemory(size_t offs, size_t len, int fl = RDSread) = 0;
79     /// Return data buffer
80     virtual bool ReleaseMemory(void *bp, int fl = RDSwrite) = 0;
81     };
82
83     /// Memory sharing implemented with mmap'ed file (or anonymous area)
84     class RdataShareMap : public RdataShare {
85     void * mmorg; // memory-mapped origin
86     int bufCount; // count of allocated buffers
87     public:
88     RdataShareMap(const char *name, int flags, size_t siz = 0);
89     virtual ~RdataShareMap();
90     RDSType GetType() const {
91     return chName ? RDSTfileMap : RDSTanonMap;
92     }
93     size_t Resize(size_t new_siz = 0);
94     void * GetMemory(size_t offs, size_t len, int fl);
95     bool ReleaseMemory(void *dp, int fl);
96     };
97
98     struct RDSbuffer; // Private struct for buffer list
99
100     /// Memory sharing implemented with simple file
101     class RdataShareFile : public RdataShare {
102     int fd; // open file descriptor
103     RDSbuffer * blist; // allocated buffer list
104     public:
105     RdataShareFile(const char *name, int flags, size_t siz = 0);
106     virtual ~RdataShareFile();
107     RDSType GetType() const {
108     return RDSTfile;
109     }
110     size_t Resize(size_t new_siz = 0);
111     void * GetMemory(size_t offs, size_t len, int fl);
112     bool ReleaseMemory(void *dp, int fl);
113     };
114
115     #endif // RdataShare_h
